lock nut tools - which ones, how many?
hi there forum-ers. I'm working on a Specialized HotRock kids bike. The crank arms had some wobble. When I tried to loosen the lock ring with my Park tool HCW5, the tool tooth is too big for this lock ring notch. See image. I used a hammer and dull nosed chisel to loosen it. That's not optimal. I checked my LBS they have about 10 lock ring wrenches. What do home mechanics use for odd sized lock ring notches? Can you measure the notch and get a suitable wrench? I don't see measurements on lock ring wrenches. How are you supposed to decide on which one(s) to buy? TIA
Quoted: 996 Post(s)
Liked 1,667 Times
Over the years I have gotten about 4 or 5 lock nut wrenches. I have to say that none of them really fit that well and at least three of them are good quality Park Tools. More often I go for my Large Cresent Wrench for the Lock Nut.
Wrenches for the Cups can also be a bugger to fit. I found a Bottom Bracket Cup Wrench that perfectly fits old French bicycles in the parts bin of a motorcycle shop. I dont know who made it. I dont know what size it is. But it works.
I guess the best way to get the proper wrench for old Lock Nuts would be to take the Nut and try it on difference wrenches till you found the proper one.
Do note that taking Bottom Brackets completely apart on old bicycles can be a real art form. Take your time and enjoy the challenge...
Likes For zandoval:
Quoted: 6303 Post(s)
Liked 4,899 Times
For that lock nut, you should be able to use most any standard open end wrench of the correct size.
For other locknuts, it's going to depend.
Judging by the tool you used, you are obviously confused what is the locknut in that picture.
Likes For Iride01:
Likes For bike_forum_geek:
Liked 4,899 Times
Okay. But the locknut on the picture is the hex nut on the left. That single piece crank requires no special tools to remove or to adjust.
If you only work on a few bikes, I'd just get the tool you need as you have the need. Otherwise you'll have a bunch of stuff you might not use before it becomes part of your estate left to your heirs.
Likes For Iride01:
Quoted: 2559 Post(s)
Liked 3,057 Times
If I remember correctly from my bike shop days, that's not a lock ring. It's an adjustable cone. You turn it in by hand until the play in the bearings is mostly gone, and then tighten the lock nut. If it's then a bit too tight or too loose, repeat. You definitely don't want to be smacking the adjustable cone with a hammer and chisel, though.
Tightening the lock nut while holding the adjustable nut in place is a bit awkward, though. You might want to get a pin spanner to make the adjustment easier. Park makes them, among other manufacturers.
Likes For Trakhak:
Quoted: 544 Post(s)
Liked 478 Times
Likes For grumpus:
Quoted: 544 Post(s)
Liked 478 Times
Likes For grumpus:
Quoted: 5893 Post(s)
Liked 2,755 Times
I never bothered with lockring tools for the cone on these BBs.
Adjust it close by pushing it around with a punch. Tightening the lockout will push the cone inward because of thread slop.
After a few tries you'll get a sense of touch about this. If it ends up loose, back off, adjust in a bit, and try again. OTOH, if it ends up a hair tight, use the punch to force the cone back against the lockout.
If you do three of these, you'll be nailing it every time afterwards.
Likes For FBinNY:
Likes For bboy314:
Likes For soyabean:
Bikes: '80's Centerion Iron Man (purchased New) , ~'91 Specialized ($50 FaceBook Find), '?? Specialized Cross roads ($20 thrift Store Find)
Liked 18 Times
that crank is super clean
Liked 4,899 Times
On my one piece cranks, once the lock nut was loosened that part, the adjustment cone, could be moved with my fingers. Maybe sometimes needing a initial prod with the point of something. Punch, screwdriver and etc.
Likes For Iride01:
Likes For Hondo6:
thanks all, very helpful, the hcw-18 looks promising, as does the Sheldon Brown link. excellent advice here, much appreciated.
Quoted: 393 Post(s)
Liked 887 Times
In case it’s still not clear, you don’t actually need a specific tool for that cone. Once you loosen the locknut (easily done with an adjustable wrench) you can loosen the cone with a quick tap from a punch and then move it by hand.
Likes For bboy314:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 681 Post(s)
Liked 755 Times
The one advantage of those BBs is that they can be adjusted without any special tools. An adjustable wrench, a screwdriver and occasionally a hammer are all that's needed.
Likes For andrewclaus:
