Shallow Fork Crown - potential issues
Quoted: 103 Post(s)
Liked 28 Times
Some time ago I remember reading a thread about a fork that had demonstrated a potential failure point. If I recall correctly it was a specific Trek fork that was subject to failure at the fork crown. The remedy for the issue was the interior of the crown had a finger/arrow that extended down the fork tube to resolve this issue. When I was doing some work on my brakes I noticed the fork crown I am using is very similar to this and I was wondering if this was a one specific fork/year/model issue, or the design in general? Is this a non issue, or something to be concerned about?
Untitled by bisonmn1, on Flickr
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 17 Times
You should be fine. That Trek fork that had so many cracking issues was an Ishiwata product, and only seemed to affect one or two years. I doubt it was entirely due to the shape of the fork crown - lots of perfectly serviceable forks used crowns without reinforcement like yours. It was probably due to a bad batch of fork blades, or even more likely, overzealous heating of the blade/crown during the automated brazing process.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
This thread comes up every 6-12 months, it would seem, with the same exact discussion, btw.
Quoted: 1639 Post(s)
Liked 829 Times
Possibly so, but that wasn't the root cause. There are tons of tons of bikes that used a stamped steel fork crown that didn't have this issue. If indeed the "bad" Ishiwata forks were all stamped steel, that wasn't the cause, just coincidence.
Liked 5,795 Times
Funny, not seeing many pictures of fork crowns cracking...it's usually the fork blades.
Disraeli Gears
OP: Is that a Trek? What model? If it is a Trek, did you look up the easily available Trek catalog for this model to see if it had one of the supposedly defective fork crowns, before coming here and posting one photo with nothing else other than your angst?
Liked 829 Times
https://www.bikeforums.net/classic-v...ork-crown.html
Maybe the question is, did the fork blade crack first or did the crown crack first??.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 5,795 Times
Well here's one posted on our forums.....
You get strength from two things: material and design. More material is stronger, stronger material is stronger, both obviously. Overheating material can reduce strength. It's been well documented in this forum by people who worked in the industry as framebuilders that the fear is greater than the reality.
It's really a moot point, however. If I'm riding a bike, all I want to know is if the fork is going to hold up beneath me. I was taught that it's a good idea to pull your wheels off and wipe down your bike on a regular basis. Doing so will get your eyes on most or all of your frame and fork so you can check for issues before they become problems. More than once I've found what looked like it could have been a crack - only to find out it was either a scratch in the paint or something that could be cleaned off.
