Go Back  Bike Forums > Bike Forums > Triathlon
Saddle recommendations...
Triathlon Swim / Bike / Run your thing? Drop in our new triathlon forum for the latest in training & gear. From beginner to expert, and sprint to ironman.
Old 04-09-19, 04:11 PM
ccinnz
Bikes: Guru Praemio, Colnago CLX, 80's Avanti Giro
Quoted: 24 Post(s)
Liked 6 Times in 4 Posts
Hi All
I am training for an the Taupo Ironman 70.3 this December, and will be doing the bike leg on a Trek Speed Concept 7, circa 2012 vintage. Have never been comfortable on aero bars, but have decided that this will be the way to go on the day so am putting the training in on this machine.
I also, don't find the stock saddle comfortable at all, and am wanting to replace it. My other bikes are fitted with Brooks saddles, but cant really see these working for me for circa 3 hours on aeros.
Any advice on the best type of saddle to go for would be greatly appreciated.
Many thanks
Carlton
ccinnz is offline
Old 05-23-19, 07:19 PM
fraba
Bikes: 1973 Raleigh Super Course - 1981 Velo Sport Criterium - c.1988 Colnago Master Piu - 1991 Merlin Road - 1991 Eddy Merckx Corsa Extra - 1995 Pinarello Cromovan - c.1999 Lemond Maillot Jaune Team Saturn - 2002 Colnago C-40 - Also modern stuff
Quoted: 51 Post(s)
Liked 38 Times in 22 Posts
For me it's ISM saddle all the way (https://ismseat.com). I started with a Selle Italia with padded nose but the first day I tried my ISM Adamo Time Trial saddle, I knew there was no going back. The Adamo Time Trial is now replaced by the PS 1.0 I think.
Having said that, you can't choose a saddle based on reviews from other. Confort is something personal and what's good for my sensible areas is not necessarily good for yours. My best advice is to try different saddles.
fraba is offline
Likes For fraba:
Old 05-24-19, 07:29 AM
_ForceD_
Sr Member on Sr bikes
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 1003 Post(s)
Liked 744 Times in 400 Posts
Concur with fraba. But...it could simply be a matter of adjustment. The Brooks saddles that you like on your other bikes might work in the aero position with a simple adjustment of height and/or tilt. Just a thought.
Dan
_ForceD_ is offline
Old 05-24-19, 07:37 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
Noseless is the only answer. The catch is, even noseless saddles are pretty particular to the rider, and none of them are especially cheap. ISM has a starter guide. I ended up with a PN 1.1 (partially due to the expense,) which might not be perfect, but it absolutely serves me for 3-4 hours.
DrIsotope is offline
Old 05-26-19, 11:37 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,354 Times in 861 Posts
probably plastic covered since you will put your wet from swimming back side on it..
Fizik Is a maker of professional race bike saddles and they use a synthetic cover..
but I'm not going to sit on any saddle I have been OK with, with your hips..
fietsbob is offline
Old 05-26-19, 06:56 PM
ccinnz
Quoted: 24 Post(s)
Thanks... I did just buy an ISM PN2.1 on our NZ auction site a couple of days ago. Hopefully it will work out.
ccinnz is offline
Old 05-26-19, 07:50 PM
fraba
Quoted: 51 Post(s)
Note that you have to be patient. At the beginning, you may feel uncomfortable. It is because the saddle does not support your body the same way as more standard saddles do. The "nose" of the saddle is wider and support wider in order to relieve the soft tissues.
Also follow carefully the instruction about the positioning. Even some LBS do not know that it has to be positioned further back compared to a standard saddle. And a bit lower also.
fraba is offline
Old 06-21-19, 12:22 PM
TheRiles
I'm in the market for a new tri saddle too. Posting to watch this thread.
Thanks
TheRiles is offline
Old 07-31-19, 11:29 AM
daudino
I definitely recommend trying ISM . I struggled with this for years until I got on a split nose!
daudino is offline
Likes For daudino:
Old 08-20-19, 05:44 AM
Trilite
fizik saddle are a great option
Trilite is offline
Old 08-29-19, 08:03 PM
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
Liked 178 Times in 105 Posts
I have an Avenir saddle that I like. It took me a long time to find it but it works for me. I found that tilt angle was more important than the actual saddle in my case. I'm female. (because that really matters.)
TriBiker19 is offline
Brooke1687
9
11-28-17 07:17 AM
spectastic
Touring
23
12-28-15 02:59 PM
Bluestraveler
Fifty Plus (50+)
7
04-16-12 04:04 PM
skycomag
Commuting
29
10-28-11 04:04 PM
horatio
Fifty Plus (50+)
15
06-21-10 09:58 AM
