Production Frames with Dynamo Wiring
Old 07-02-19, 08:20 PM
Va1984
Quoted: 12 Post(s)
I’m trying to compile a list of all the production frames that came with holes to route the dynamo wire inside the down tube. By “production” I mean not custom- or hand-made frames, but those available from shops in various sizes. I’m thinking primarily of the US market in the 1980s, but by all means help me expand the list with whatever you can name.
I’ve got:
Centurion Pro Tour 15 from 1984 to ?
Centurion Elite GT from 1984?
Specialized Expedition 1984
also several Koga-Miyata models in Europe including the Randonneur and the Traveller... (I don’t know the years of those...)
what else?
Va1984 is offline
Old 07-03-19, 08:10 AM
fliplap
Quoted: 97 Post(s)
Liked 328 Times in 105 Posts
The Miyata 1000 had it until 1990 I believe.
Koga Miyata started doing it in either as soon as they started using bottom bracket dynamos ~1981 or soon there after in 1983 or so with the GentsTouring and Traveller. The Randonneur replaced the GentsTouring in 1985 but by then the Koga Miyata model line has exploded and like half of their frames had internal dynamo wiring.
fliplap is offline
Old 07-03-19, 08:12 AM
Va1984
Quoted: 12 Post(s)
Neat info about the Koga-Miyata line-up!
I know that the Miyata 1000 did not have it 1983 and 1984 -- unless I somehow ended up with copies that omitted that feature!
Can anyone corroborate if it's true that sometime between 1985 and 1990 the 1000s had dynamo wires?
Thanks!!
Va1984 is offline
Old 07-03-19, 08:21 AM
Kuromori
Quoted: 237 Post(s)
Liked 83 Times in 64 Posts
How do you define hand-made? Many factories used similar methods employed by custom builders, just scaled up and organized more like an assembly line. Where is the cutoff between hand made and not when it comes to jigs? More often than not this kind of information isn't readily available either. I don't know how much robot welding has taken over, but not long ago, many Chinese frames were hand welded or hand brazed, not to mention CF.
Kuromori is offline
Old 07-03-19, 08:32 AM
Va1984
Quoted: 12 Post(s)
Good point -- I'm just being lazy with my wording. All I mean is "not a unique, custom-made frame" but rather something that was available off the peg, or on a catalogue, mass- or nearly-mass-produced, or however you want to put it.
I am aware that until the 1960s countless artisanal frame builders in France, for example, ran dynamo wiring inside their frames. Today, countless $2000+ custom made frame sets can be had with dynamo wiring. But I am trying to trace the everyman, relatively cheap, mass-produced frames (especially touring frames) that had this feature in the bike boom era.
There is no special reason for this curiosity either: simply, I like rebuilding 1980s touring frames (usually Miyatas and Univegas) with modern components and I had always just accepted that I had to run the dynamo wire externally. Then recently I acquired a Centurion Pro Tour frame and I was shocked to see the dynamo holes. Then I noticed it on the Specialized Expedition. So now I am wondering what else have I been missing out on...
Va1984 is offline
Old 07-03-19, 10:54 AM
bertinjim
bertinjim's Avatar
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1970s Carlton Kermesse, 1982 Peugeot PB 12
Quoted: 343 Post(s)
Liked 264 Times in 155 Posts
Va1984-
My '80s Canadian built Peugeot PF 40 Gentleman was wired internally to the termination at the generator braze-on. The Peugeot PA 60 and the PX 60 were also internally wired.
bertinjim is offline
Old 07-03-19, 11:36 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
Raleigh RSW-16 Deluxe, in the mid-60's, had a dynamo hub and both headlight and the Raleitaillight and built into/onto the fenders, wires hidden inside the fenders and in the frame. The Superbe also had dynamo hub and lights, but I'm not sure the wires were so well hidden.
But these were not cheap bikes. Heavy and clunky by today's standards, they were the most expensive bikes Raleigh offered at the time.
rhm is offline
Old 07-03-19, 06:07 PM
fliplap
Quoted: 97 Post(s)
Thanks!!
I was making that 1990 guess based on a T-Mar post from a long time ago that I might've misread.
I went back and flipped through the catalogs. There's a chance that the 1986 was the only year that received the internal wiring harness. You can just barely see the grommet for it in this picture from the 1986 catalog. I couldn't spot it in any other years
You can see the same grommet bump, and hanging wire while I fix the light, on this 1989 Koga Miyata Randonneur Extra, which I will some day take better photos of.
fliplap is offline
Likes For fliplap:
Old 07-04-19, 10:30 AM
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
For the two Centurions the Elite GT and the Pro Tour.
Elite GT: was one year only model, 1984
Pro Tour: Stopped after 1984 and 84 catalog mentions the wiring but the 1983 does not. my guess 1984 Only.
fleslider is offline
Likes For fleslider:
Old 07-04-19, 10:39 AM
bark_eater
Quoted: 753 Post(s)
Liked 735 Times in 421 Posts
My Koga Miyata Cityliner has a wire in the down tube , along with mounts for both a tire dynamo and a bottom bracket dynamo.
bark_eater is offline
Old 07-04-19, 11:43 AM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
I had a '70s gitane that must have had some wiring, came with a sidewall dyno. I was a racer wannabe at the time and took all of that stuff off. Someone here has identified the model, it had front and rear racks, fenders, and a dyno.
Lots of Dutch city bikes have built in wiring. I have one in the attic that has wires running through the frame.
unterhausen is offline
Likes For unterhausen:
Old 07-04-19, 02:22 PM
bertinjim
bertinjim's Avatar
Quoted: 343 Post(s)
unterhausen-
The Gitane Hosteller, perhaps?
Old 07-04-19, 06:31 PM
BikeWonder
Quoted: 160 Post(s)
Liked 75 Times in 52 Posts
Late 80s or early 90s Nishiki International Touring Series. Really well built bike.
And regarding the Miyata 1000, I checked my 1982, 89, and 91 models and neither have holes for dynamo wiring, for clarification.
BikeWonder is offline
Old 07-04-19, 09:33 PM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 885 Post(s)
Liked 985 Times in 518 Posts
Neither my 81 nor my 83 Centurion Pro-tours have internal wiring.
Most of the Gazelle Opa/Oma Fiets have internal wiring
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
bwilli88 is offline
Likes For bwilli88:
Old 07-05-19, 07:29 AM
Va1984
Quoted: 12 Post(s)
Thanks for the great info... so far we've got:
US market touring bikes:
Centurion Pro Tour (1984 only)
Centurion Elite GT (1984 only)
Miyata 1000 (1986 only -- I still can't believe this one!! Are we 100% sure?)
Nishiki Internation (late 1980s...? Can this be confirmed? I've never seen one)
Specialized Expedition (1984)
--> no reports of any Fuji ever coming with dynamo wiring?
Lots of European bikes including:
Gazelle (lots)
Gitane Hosteller (year?)
Koga-Miyata CityLiner
Koga-Miyata GentsTouring
Koga-Miyata Randonneur
Koga-Miyata Randonneur Extra (1989)
Koga-Miyata Traveller
Peugeot PF 40
Peugeot PA 60
Peugeot PX 60
Raleigh RSW-16 Deluxe (mid-1960)
please feel free to copy/paste, edit, correct and expand!
Va1984 is offline
Old 07-05-19, 08:15 AM
Cl904
Quoted: 106 Post(s)
Liked 36 Times in 23 Posts
Both of these have internal wiring
Cl904 is offline
Old 07-05-19, 10:51 AM
BikeWonder
Quoted: 160 Post(s)
Gazelle (lots)
Peugeot PF 40
Peugeot PA 60
Peugeot PX 60
You can take my word for it. I recently sold one. Unfortunately I didn't get a picture of them, but it's located underneath the starting of the downtube and exits near the bottom bracket.
Old 07-05-19, 12:03 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
had a through the down tube wired Expedition , BITD,
Sanyo BB Generator was the thing then, so wire was to the headlight.. ...
Herse /Singer were hand made Constructeurs in France not mass producers for your list.
fietsbob is offline
Old 07-05-19, 12:25 PM
simmonsgc
simmonsgc's Avatar
Quoted: 83 Post(s)
Liked 14 Times in 8 Posts
My ProTour 15 -- I don't have the serial here. I've forgotten, but I think it is an '83.
Centurion ProTour 15
simmonsgc is offline
Old 07-06-19, 06:58 PM
Va1984
Quoted: 12 Post(s)
I have an identical one... I think it’s ‘84. As bwilli88 said above, I think in 1983 they came without...
Va1984 is offline
Old 07-06-19, 07:00 PM
Va1984
Quoted: 12 Post(s)
I like Nishiki and I would love to figure out exactly which model-years had it!
Va1984 is offline
Old 07-06-19, 07:02 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,380 Times in 2,045 Posts
I had to cut the wires today on Koga-Miyata Traveller to fit a cartridge BB in the shell.
dedhed is offline
Old 07-06-19, 07:11 PM
simmonsgc
simmonsgc's Avatar
Quoted: 83 Post(s)
I'd certainly defer to that! Thanks for the correction...I don't want to put any mis-information out there.
Old 07-06-19, 10:15 PM
BikeWonder
Quoted: 160 Post(s)
After some research, I think only the 89 model year had it. Then they switched back to road-only from which the model was derived from. I highly recommend this one.Athough it looks like it could reach only 28mm with fenders, the geometry and ride quality was comparable to my Miyata 1000. If felt more responsive. I sold it due to some repair challenges (internal rust sucks to get rid of). Anywho, if I ever come across another one, I'm going to take it and build it into a rando bike. But they are getting harder to find and they are so under appreciated and luckily undervalued. So to anyone looking for one... get em!
These were the specs if you wanted to ID the year better:
Old 07-07-19, 07:27 AM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Giant Expedition "trekking" bike in this market from about 1990 had the remote lever-operated Sanyo BB generator and internal wiring.
thumpism is offline
