I guess I need more tools...
#51
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
#52
$45 to overhaul a hub may be high for a front, low for a rear. $90/pair seems fair.
I have spare Park cone wrenches and some freewheel tools, as well as a spare dishing tool. Pm if you want to own them.
Likes For jethin:
#54
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
The rim in question literally probably has one if not two adjacent spokes that are not quite right - only a slight wobble on one side.
Thanks for the list. I already have a grand majority of those things - I even have a little spoke wrench already. I just don't have a truing stand and I have no other frame set with the same size dropouts to set this wheel into, and the one it will be used on does not have brakes or pads attached yet. So I figured I could not true it decently just having it mounted on the frame right now.
https://www.dailymotion.com/video/x6t5g46
#55
Strong Walker
Different versions of this story keep popping up in this thread, and I get the point. It may apply for many. I'm not an incompetent, though. I've rebuilt carburetors, changed brake rotors and replaced flywheels and re-wired headlights, etc, etc... Much more intense and knowledge-based stuff than the practically intuitive work required for bicycle maintenance. I know how to true a few spokes, I just don't have a proper stand or much time to fiddle with things right now.
I would happily pay someone some cash to do some of this work for me because I'm very busy right now, but have decided I'd rather do it myself when I find time than pay someone a quarter of my daily wages to fix a couple spokes.
-Gregory
-Gregory
There is a guy in my home town of Munich who offered *affordable* bike fixes, using salvaged parts. Get your brakes adjusted and the lights fixed for 20.- €. Started as a hole in the wall mini-shop, now expanded and seems to be very successful. There definitely is a market for that kinsd of thing.
#56
Strong Walker
another version of the story involves a retired computer expert for mainframe systems. My hopes of actually becoming one of those lucky fellas went down the drain, sadly... backed the wrong horse
#57
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
-Gregory
-Gregory
Edit: Ah, I see I replied after reading the first page w/o noticing the second and third...already covered.
#58
Quoted: 2338 Post(s)
Liked 2,827 Times
doesn't have to be park, but get good quality
#59
Quoted: 4512 Post(s)
Liked 6,386 Times
I would disagree...buy good tools. they last and work better. as as simple example the difference between the chain tool in one of the 50 buck or so kits and a park is night and day. I used the cheap one for years and cursed my self for doing so when I got a park.
Good tools will up your game, poor ones will cause you more trouble when you are already ill equipped.
#60
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Recently I was looking over my inventory of personal belongings for my home owner's insurance. I spent over $7200 on Snap-on tools back in 1972-73.
I also have several thousand in bike specific tools that I've acquired over the years including a fairly complete set of VAR tools in a case.
verktyg
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#61
Quoted: 2363 Post(s)
Liked 1,749 Times
#62
Liked 6,386 Times
#63
Quoted: 3241 Post(s)
Liked 2,512 Times
What is up with the idea that the less something costs or is valued at, the less the labor should be to repair it?
Now let's look at the other side. For every repair that takes five minutes, there is one that takes an hour and 20 minutes that they charge for only an hour. You also have plenty of the repairs where you spend 1/2 - 1 hour working up the repair estimate. You call up the customer, give the estimate and they don't want it repaired. You're out the labor of working up the estimate. There's also the, "I looked online and that is a $5 part. Why are you charging me $25?"
"Well, you think it's free shipping to get it here? Shipping was $16.45."
#64
Liked 2,512 Times
As for tools, that is one thing that the labor charge is paying for. One of the best examples is replacing a front CV joint/axle. It's an easy job...................if you have a cv axle puller. If you don't, don't even attempt it until you get the tool, period.
#65
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
#66
Quoted: 981 Post(s)
Liked 1,844 Times
Because of the amount of expertise and the cost of the necessary equipment/facilities to make the repair possible. Do you think that a bicycle mechanic is as qualified to earn $X per hour as a Ferrari technician?
#67
Quoted: 3015 Post(s)
Liked 3,804 Times
Did you ever think that sometimes it can be an absolute ***** to remove a freewheel? Have you ever done a search here? Threads about soaking freewheels in Kroil for weeks? Stripped notches? Are bike mechanics psychic and just know everything about a job before it starts? They should believe you, Mr. I Have Done Hardly Any Bike Wrenching, that the job will be easy?
2 weeks wait at this point in the season seems about right for a good shop. In May, early June, expect to wait 3-4 weeks. Why? Because people are stupid and get tune ups when the weather is nice instead of January when the wait is a day, maybe two.
So Mr. Craftsman, you are slammed with work, do you offer discounts? Do you allow people to jump the line? All of your jobs go smooth? Do regale us with tales of a perfect 60 hour week. (Hint, no such thing)
#68
Liked 3,804 Times
#69
Quoted: 981 Post(s)
Liked 1,844 Times
The rest of your commentary makes little sense to me, because it has nothing to do with what I said. Changing the fuel pump on a vintage GT40 back in the day has little in common with working as a technician in a Ferrari dealership today.
I have no delusions, but if you think you're worth as much as the fellow working in the Ferrari dealership and can get the job done, then more power to you!
-Gregory
#70
Quoted: 981 Post(s)
Liked 1,844 Times
I was only pointing out that I'm not some incompetent who can't learn how to use tools. I have some confidence in my capabilities. I don't think that's a bad thing.
-Gregory
#71
Quoted: 767 Post(s)
Liked 1,898 Times
The best takeaway here is that you shouldn't have been "confounded" by both the price and timeframe for the service. Nothing wrong with learning that. No argument about the value of labor necessary.
It's not like bike shops are high profit businesses.
Some pay the price happily. Some gasp and then invest in tools, which can often be purchased from the same shop. Or not.
Whatever you decide to do is a choice, and it's great to have options available.
All is good.
All is good.
#72
Quoted: 981 Post(s)
Liked 1,844 Times
These men make about $20-30 per hour average in this region (the San Joaquin Valley).
I think I have every right to make an argument about the value of labor in a case like this. Sure, a bicycle shop has plenty of overhead compared to an industrial mechanic, but they also have two or three technicians working on different orders at the same time, accumulating to perhaps two hundred dollars or more per hour. To tinker on bicycles! I do think it's bull, honestly.
More power to them, of course, but I've decided to do it myself instead.
-Gregory
#74
Quoted: 7348 Post(s)
Liked 2,473 Times
You are a good craftsman, as your flickr stream shows. Do you charge for your skill? If so, you would know that your rates sometimes seem strange to your clients. Pricing your labor can be tricky, and there will always be clients who think your figuring is off. And you'll know you're right, especially if you keep getting business.
#75
Quoted: 981 Post(s)
Liked 1,844 Times
I really don't mean to come off as being offensive here, and in fact a lot of the responses have echoed some or most of my sentiments. I understand I'm treading on sacred ground given the forum where the discussion is taking place, and mean no slight to bicycle mechanics in general.
@noglider I do such work as a hobby and with whimsy. I have some clients who I low ball my quotes for in order to make something I would actually like to make, and sometimes I ask much more because I'm not particularly in the mood to make what's being asked for. Above all, I need to be having fun while doing the work and I have never expected to make a living wage at such things. I'll be the first to admit that I don't have the tenacity or patience for it. So whatever comments I could make about the prices of my handiwork (which can sometimes reach into four figures but might still break down to less than minimum wage) would not be applicable to the labor arguments presented here.
I much prefer to be a hard-working employee with a reliable source of income.
@BFisher If I'd known what I'd be charged (definitely should have called first) then I'm pretty sure I would have ordered the tools straight away and had them in hand well before the two weeks went by. Perhaps my bicycle wouldn't be broken so long after all... In this particular case I'm still gathering components anyway and won't be riding for months, so it's a moot point!
-Gregory
-Gregory
