Will a 26x1.9 tube work in a 26x2.0 tire?
Bikes: Trek tandem, Specialized road bike, Specialized cyclocross, Schwinn Varsity, Schwinn Jaguar, Schwinn Frankenbike Commuter,Fixie of unknown origin
I sure hope so, because I really need to replace the rear tube in my tandem tonight. Will it at least work temporarily until I can get to the LBS and buy the proper size?
Thanks,
Sprayman
Thanks,
Sprayman
Quoted: 5781 Post(s)
Liked 2,578 Times
Yes.
An inner tube is simply a balloon. It'll inflate to fill all available space withing the tire. You can very safely use a tube to roughly 1-1/2 times it's nominal size. Most tubes sold today are sold as fitting size ranges, ie. 1.5-2.0
FB
Chain-L site
FB
Chain-L site
Slightly smaller= good. Slightly larger= bad. The larger tube can crease and cause a flat. Still OK to use if you have to.
-SP
-SP
