Thoughts on my fit?
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
Thoughts on my fit?
So I may or may not have crushed the front end on this bike. Seth Snyder is willing to rebuild the front triangle for me, and I can make some changes if I want to. I've been telling myself that I want a longer top tube, but I'm not honestly sure if I really do. I'm currently using a 110mm stem and still have the option of keeping original dimensions and running a 120-130mm stem to add length. I'm also running a pretty shallow bar to. I'll be going with a steeper headtube angle, but what do you guys think in regards to effective top tube length? Stay the same and try longer stems or stretch it out a little more?
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
I think you need a TT that is 3-4 cm longer. What size is your TT now?
Also, you should consider running shallow bars with a long stem OR deep reach bars with a normal stem. But don't rely on bars and stem to address a top tube problem. Currently, it looks like your hands are well behind the front axle. The purpose of the bar/stem combo is to put your hands in the right position with horizontal relation to the front axle and vertical relationship to the saddle (saddle-to-bar drop).
VeloSIRraptor
holy smokes are you ever cramped up in there - yikes.
Get that thing longer, much longer. At least 3 cm? 4cm is probably fine, but certainly no less than 3.
Correct me if I'm wrong (I haven't been paying much attention on the board this year), but if memory serves, you are a 3, enduro-trending-to-sprinter stuff?
What long-term goals do you have for this track racing stuff? Trying to get to some NTC races for sprints, trying to get a category upgrade, grow up to be like Carleton-the-big-flossa and set your track's record in the F200?
Are you pretty flexy? Can you generate legit power in a tight position, what happens if you bring your position up a bit - do you get a magical +30w?... asking, as many people go to the end of their possible physical positions without checking to see where the |power vs aero =speed| tradeoff actually happens.
The following advice is based on the assumption that you want your bike to work for both sprints and enduro stuff- and that you won't be doing races longer than 30' in your track position.
As a personal annecdote, this matters as I can promise you that races of +35' will make any of us rethink our track positions in a BIG way... so, yeah- there's one of my take-aways from last season
Getting more drop is tricky to figure from that photo as you are so cramped that you can't really go further down and generate any power (at least, it doesn't look like it to me). More drop may well be helpful, but this "perfect internet fitting from a single action photo" is really an art not a science.
The photo angle doesn't help much, but are you sitting pretty far back on your saddle?
I'd love to see some photos of what you look like rotated further forward on your sitzbonez- it'll lengthen your position (a positive) while getting you lower in front while opening your hip angle (double positives!!)... but theoretically changing your fit and then (re)building a custom bike around that position is a tricky proposition, no?
Anyhow- with a bit more info, I'd love to throw yet more advice of dubious quality at you.
~Cheers
~Cheers
Elitist
Liked 92 Times
What long-term goals do you have for this track racing stuff? Trying to get to some NTC races for sprints, trying to get a category upgrade, grow up to be like Carleton-the-big-flossa and set your track's record in the F200?...
bullet, hopefully Seth has a fit-bike. You'll see that if you get on the fit-bike and simply extend the TT forward (and the bars don't even have to go down) it will change a lot. It will feel awkward at first, but you'll adjust quickly. So think "out" not necessarily "down".
VeloSIRraptor
again, this is quite dependent on what you want to do with your racing- If you want to do 80 lap scratch/points races, you can't get too extended or the arm/back muscular fatigue will catch up to you and it'll be lights-out.
Handling can get fine-tuned quite a bit by lengthening the wheelbase/Front Center of your setup, I now have quite different opinions about wheelbase/stability then I did previously... so, there's that.
Also, changing your handlebar can shift your position around by several CM... that's Massive, if you are thinking about changing handlebars, this is the time to do it and talk it over with your frame guy - makes no sense to change the bike without including the stem/handlebar in the calculation.
Are you on a setback or straight seatpost?
VeloSIRraptor
aka mattio
It's hard to tell from a static picture, but it also seems like you could stand to have the saddle come up and forward, and help get your body into that longer reach by rotating forward and down from your arse/saddle.
you can test by hopping on a fit cycle, replicating your dimensions, or just by putting a 130mm stem on there and fiddling around - to come to some ideas about what will feel good before your builder goes and builds you a new triangle.
Bikes: Bianchi Pista, Bianchi Vigorelli
Elitist
Liked 92 Times
If Seth doesn't have a fit bike, maybe you guys can find a gym that uses Cycleops spin bikes (or something similar). Pay the daily fee and both of you do an impromptu fitting there. That would be MUCH cheaper than a $200-300 Retul or Specialized fit.
That way you can adjust the resistance and see what differnt positions feel like when you are laying down torque or spinning. They come with 170mm cranks. Take your own pedals.
You won't be able to measure TT length as you would a fit bike, but he'll be able to measure:
- Pedal spindle to top of saddle
- Tip of saddle to hand position
- Hand position to pedal spindle
These are 3 of the key measurements that Tiemeyer uses. That triangle is the key to it all.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
~Cheers
~Cheers
I'd really love to play around with a powermeter one day, but I don't currently have access to one.
I don't have many pictures with the hips rotated forward, but I do feel my aero bar position helps a bit with that.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
currently has a straight seatpost with saddle clamped in the middle of the rails. I have discussed rotating the rear triangle forward to give it a steeper seat angle. Gonna run some calculations to see what kind of bb height difference we would get by changing that. I will look for a fit bike or play around with some stems on the road bike.
Being as though no one has given any advice that can mess you up for a while here it goes.
My wife keeps saying skinsuits need a cape or a tutu to complete the outfit. With toes en pointe in the picture you look closer to the tutu than the cape.
It looks like you are riding toes down with your leg extended at the bottom and more so over the top. If you try riding heels down/ more level you can drop your seat a couple of inches , then replace the short/shallow handlebars with traditional track bars like Deda or Nitto 123 which will put your hands a couple of inches down and forward. The other advantage of getting lower overall is you get more draft in the pack instead of being a head above everyone else. Get rid of the pointy toes and extend the arms to convert the tutu to a superman cape.
Use the picture Carlton posted as an example of the lower foot angle compared to yours.
Bikes: S-1 :-D
Quoted: 17 Post(s)
i was interested in the comment from Slindell re your toe-down pedal style, as it was also immediately noticeable to me in the first photo. In that pic it looks like you still have enough bend in the knee to indicate that you are a natural toe-downer, and not 'stretching' for the pedal. In the one on the aerobars, although your back-angle looks pretty similar (??), its looks more like you are stretching/ reaching for the pedal more - generally a sign of a slightly-too-high saddle (which would make more sense if your hips were indeed rotated forward as queerpunk notes... even though it doesn't look like it referencing your back angle.).
Anyway, although not directly related to your bike - sizing, perhaps some things to look at re your bike fit. Also, a video would be really helpful to give comment on; far more so than on a static pic as others have mentioned. :-)
The toe down does look natural and can come from a running background where toes down increases the stride length (same as bigger gear on a bike) or to get better pull up with toe clips without pulling out of road level of strap tightness. Here it looks like the raised seat to accommodate may be leading to choosing bars with less drop (might also be to get narrow) but as a side effect less reach causing the cramped position. Bike sizes do not seem to scale well with height so taller riders will be more cramped on the top tube than short riders, but with bars and stem there is room to go forward in the pictures here.
But as I mentioned - trying to change your natural foot position is not a trivial change and will take time to get used to. If it can be done it should help with higher cadences and reduced drag so may be worth a try.
Elitist
Liked 92 Times
I agree that it's hard to reach or maintain higher cadences with the "toe-dipper" foot position.
Now (winter off-season) is the time to reevaluate and change one's fit.
i'll never forget how cramped donkey kong looked in his kart. a little humor =D
i'm interested in your power output difference if you ever get a chance to measure. from the looks of it, an optimal position will unlock considerable gains. keep us updated.
Divebrian
Track Cycling: Velodrome Racing and Training Area
26
07-16-17 07:16 AM
indybiker01
Bicycle Mechanics
19
03-21-10 01:47 AM
