Pallets/Work Benches!
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Traded in my bike tools for my demo tools.
Started the tear down rebuild...stopped! Too d——m cold! Forty mph breeze!
I found these three 8’3” pallets outside of a commercial building here in town.
I went in to assure that these pallets were actually for nada!
Yup!
These are going to be my outside work benches!
I have 4 + bench stands with different angles that are going on the benches!
There will weathertight storage areas underneath.
That is where the bicycle excess and my under utilized wood working tool will reside.
24’9” of work benches!
Boom!
Quoted: 350 Post(s)
Liked 782 Times
Work Benches
These are usually filled on the weekends...
Couple of the bench stands...
Couple of different angles...
If I were you I would lay down 2" x 8" boards the length of the pallets as a top. Then you've got a work bench you can beat on. wink.
Quoted: 1363 Post(s)
Liked 1,674 Times
Keep us updated.
Quoted: 350 Post(s)
Liked 782 Times
I have 3 pieces of 3/4”, 37”x8’, plywood that I have been using to replace a blown out garage door.
They should be able to take any punishment that I will be dishing out...
Already painted to match the shutters and some trim, too.
Easier to convince my wife to accept a project of this scale...
I will be using the benches for wood working, bicycle work, etc.
I’ll be building the table saw and the router into the benches as time goes on...and the weather is more conducive to working outside.
Bench placement will take advantage of the sun and dealing with the persistent Cape Cod “breeze”.
My wife will be able to start refinishing furniture again... my hobby kinda took over the garage...
Sr Member on Sr bikes
If for no other reason...I like the 3R mentality...or as I like to say 4R mentality...'reduce, reuse, repurpose, recycle'. Post pics of finished product.
Dan
Quoted: 6934 Post(s)
Liked 10,938 Times
Alternatively, Home Depot (and probably other big box building supply stores, too) sells pre-made workbenches: 6' long, with a lower shelf, and they set up in about 30 seconds. The price is not much more than the materials cost, and the only work involved is opening the box.
Quoted: 350 Post(s)
Liked 782 Times
These benches are gonna be used for everything from lawn mower service to wheel truing...there may be as many as two MTB bikes hanging at once, may one or two tandems, seperatly.
The Misses and I will be doing furniture rebuilding/refinishing on these benches, too.
Overbuilt...may just add legs...big ass legs!
Bikes: Still have a few left!
Quoted: 465 Post(s)
Liked 526 Times
30 years ago, I was building our home in Olympia, WA and my wife wanted a hardwood countertop between the fridge and gas cooktop. I used some Jatoba "Brazilian Cherry" leftovers from a local flooring business that was working on a nearby home. They offered me, for free, all the pallets the wood came on. Same stuff, but rough cut & was frame was thicker dimension. This wood was about twice as hard as oak, but beautiful dark red/brown and takes a nice finish. You might check locally to see if Jatoba flooring still comes on Jatoba pallets that are free or low cost. Don
Quoted: 1182 Post(s)
Liked 833 Times
I have a Douglas-fir workbench top that measures 5' long, 25 1/2" wide , and 5" thick. I lived near a company that made laminated beams, and this was a "scrap" produced during trimming. I am a woodworker/woodcarver, and this bench is rock solid.
Quoted: 350 Post(s)
Liked 782 Times
Well, weather not cooperating.
Doing an exploratory pallet tear down.
Started stripping down, streamling one of the pallets.
These pallets were built to not be taken apart...too many nails cause the boards to break at them.
One pallet reduced to kindling, wood chips and minimal useful, remaining boards.
New plan...just add legs and whack tops on the remaining two.
Done!
Boom! (Sound of a 16mm cone wrench hitting the floor!)
Done!
Quoted: 350 Post(s)
Liked 782 Times
Built!
Framed! Next will be the top, then the floors, then the front and back walls. There will be doors for sercurity. Hope to make it as weather and pest proof as possible. I’m also thinking that the pre-built situation actually made it more difficult than it had to be! I’ll use the last pallet as another bench using my experience from this one...then build one from scratch. Made it up as I went today. My wife likes the smell of wood better than my bikes greases and lubes!
Quoted: 350 Post(s)
Liked 782 Times
Finally got to start and finish my second bench...in one day!
Rebuilding the pallets into a bench not as easy as I thought it was going to be...2x4s were 3.5” longer than the normal 8 footers. Threw everything off!
Just gotta do the sides and front doors.
Gonna throw in a surprise with the top!
Likes For billnuke1:
With a mighty wind
Quoted: 1084 Post(s)
Liked 854 Times
I built a really large compost bin out of pallets a couple years ago. It’s a great thing and I will have it for many years. It was a total pain to tear a bunch of pallets apart. For the time and effort, if i ever do something like that again, i’m just going to Lowe’s.
Liked 1,674 Times
Likes For BobbyG:
Quoted: 350 Post(s)
Liked 782 Times
Promised surprise!
As I was making sure that the top fit, I was surprised to feel how much wasted space there was going to be under the top...So I made another floor for under what will be a hinged/ sliding top.
I was going to make a sliding/hinged the top anyway.
That was a lot of dead space!
Ta da!
Our bathroom vanity has a drawer where there use to just be a kick plate...just a great ah hah moment!
So much reclaimed space!
Ta da!
Quoted: 350 Post(s)
Liked 782 Times
Yay!
I’m going to lower the floor of my new found space even lower next time!
I can either slide open or lift the lid to access this hiding spot!
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Here's a workbench I made for my son. It's similar to the one I have in my basement.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
Quoted: 350 Post(s)
Liked 782 Times
Done-ish!
Just need the missus to paint them...after I finalize the front door design and add the face boards on one of them.
Already using this substantial horizontal surface!
Should disappear as soon as they are painted.
Side bench for the trailer stuff and wood working tools...
Back bench for bikes, wood working, and mechanical jobs, lawn mowers, and other gas powered equipment.
