Modern racks for old 10 speed?
Hi All - I'm trying to set up a 70s Dawes Galaxy to do some bike camping this summer. I'd like to put on a decent modern rear rack, but I was wondering if there are modern racks that work better than others on older bikes. My bike frame has rack mounting holes on the dropouts but not on the seat stays. Should I just get a rack that is made for seat stay mounting holes and rig something up with p clamps? Or is there a better solution?
Thanks,
Clark
Thanks,
Clark
There are those racks which have a single mounting point on the brake bridge. Do-able if you are using the centerpull brakes the Dawes came with. bTW, pics of the Dawes, pls!
How much gear are we carrying and in what sort of bags?
I don't suppose you have a link to such a rack? All of the ones I'm seeing on Amazon use two seat stay mounts.
Here's the bike as found - it is currently in a mostly disassembled state.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
I'd vote for P-clamps, two connection points are better than one. I'd also use a steel rack vs an aluminum one. I've had two aluminum racks break ove the years, both times my handy roll of duct tape was used to get me home.
The one thing on that Dawes I'd worry about are the wheels, specifically the spokes. It's very similar to the Raleigh Super Course MkII that I toured on when I was younger. Two long trips in a row I broke a drive side spoke and had to limp into the next town to get it fixed. For a regular rider it would be ok, but loading down a rear wheel with panniers, sleeping bag and tent along with your weight puts a lot of stress on those old spokes. Consider a set of new wheels with modern stainless steel spokes.
Quoted: 1136 Post(s)
Liked 650 Times
P clamps will be totally sufficient if you get some good quality ones. Nitto makes some you can buy, and a lot of racks come with them.
This is a prime opportunity to visit your local bike shop. You will be able to get their advice and be able to see what hardware comes with the racks they have in stock. They might even test fit it for you. Unless it's something you absolutely can't find or get on order locally, I would skip Amazon and support your neighbors' small businesses.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
I use the Tubus lowrider adapters. They’re really well-built and I wouldn’t hesitate to load them up.
Peter White has excellent info here: https://www.peterwhitecycles.com/tubus_racks.php
Quoted: 2363 Post(s)
Liked 1,749 Times
Those ^^^^^ look robust, moreso than p-clamps. But I reckon they're for fork blades, right? They'd be a bit big for seat stays, and I think major use of spacers would compromise the robustness some. Do they make adapters of this design, but sized for seat stays?
To the OP's question about a single central brake bridge mount, look at just about any modern MTB rack. The kind that uses stainless steel straps, rather than the seat stay mounts being integral parts of the rack. Typically you see three rows of mounting holes. The outer ones are for the straps that go to seat stay braze-ons (or P-clamps), and the center holes are for a steel strap that goes to the brake bridge. On the one hand, it's a more direct method of mounting than using P-clamps on the stays, and of course it can't slip. OTOH, it's one mount point rather than two, as said.
Quoted: 796 Post(s)
Liked 522 Times
My 78 Motobecane Grand touring has a blackburn rack with single attachment "arm" that goes to the brake bridge. If you live near a bike co-op they can be a good source of older racks, the can also be found on eBay. Be careful though as those early Blackburn rack were frame size specific i.e. not much adjustability but great if its the right size.
Pletscher! If you are brave and want to be period correct. That's all that was around until the later half of the 70s. The new ones supposedly have improved. They have twin stays now. Only exotic customs like Singer or Jack Taylor or whatever would have upper braze ons for racks. Everyone else ran a Pletscher, or a Blackburn after 1976 or so.
While I'm not entirely joking, for a serious camping bike, I'd suggest Nitto big rack or similar. That's what I use. Mount with P clamps. There is nothing wrong with P clamps, especially the Nitto ones, and they were really the only option circa the 70s. I think it's going to be more rugged than a rack with a single upper mounting strut at the brake bolt.
Be careful of some modern racks. They assume sloping top tube modern design, and they won't fit on larger sized traditional diamond frames. IE the Tubus logo Evo. I have one in my junk box because of this.
Bad example
Quoted: 823 Post(s)
Liked 205 Times
I have several old bikes and use the two-arm Blackburn racks with p-clamps on the rear, and Blackburn Low-rider front racks. They work perfectly well as designed, and seem plenty robust. This is a 1986 Peugeot Corbier with Blackburn racks, although I have since replaced the front rack with a matching black Low-rider. You can see the p-clamps on the seat stays.
Quoted: 387 Post(s)
Liked 692 Times
I’m in danger of sounding like a Tubus shill, but they also make very sturdy seat-stay adapters, which I would trust far more than rubberized p-clamps:
Available in 14mm, 16mm, 19mm, 22mm, and 25mm.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3882 Post(s)
Liked 6,475 Times
What I'm seeing on youtube from modern touring is they're getting away from loading the rear of the bike, especially with panniers. More folks are using front bags, larger saddle bags, and frame bags.
If you do go with a rear rack, I would suggest a blackburn rack as shown in post 8. That's what I use on my grocery getter. I would hate to attach anything to my stays.
Quoted: 237 Post(s)
Liked 83 Times
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I like the old brake bridge mount blackburns too but i wouldnt discount the tubus fly. It will mount on the brake bridge, is quite strong and weighs next to nothing.
For those that fear the P clamp or think it's a hack solution, it's really not. This was the correct way to do it before rack braze ons started being added to production bikes. I worked in a touring specialty shop in the pre braze on era, and we mounted racks with P clips all the time. A twin stay rack with P clips is much more reliable than any single stay to the brake bridge type rack, especially if you are setting it up for actual bike camping gear. P clamps were even used to install low riders for the first 2 or 3 years, before manufacturers were convinced to add mid fork braze ons.
Thanks for all of the input - this gives me a more informed starting point to pick something appropriate.
My 13 year old son will be joining me on this trip, and will be piloting a modern mountain bike (he rolls his eyes at my old bikes, and my old stereo stuff, and my old woodworking stuff, etc. etc.). Maybe the best answer is to make him bear most of the load for camping gear
