700 x 38c tires on a vintage bike?
Old 05-03-19, 08:03 AM
bikemig
bikemig's Avatar
Quoted: 3607 Post(s)
Liked 62 Times in 55 Posts
Anyone running 700 x 38c tires on a C&V bike? I picked up a nice set of of 700 x 38c Hutchinson tires and now I'm jonesing to buy a frame or a bike that can handle these tires. I know that's so wrong (using new tires as an excuse to buy another bike) but I figure C&V is a safe space when it comes N + 1,
I also know there is a lot of variation on tire width and volume depending on how manufacturers measure, rim width etc. But show me what you got. Oh and I don't want any crazy long brakes either because I want the bike to stop eventually. So I guess I'm willing to go as long as Weinman/Dia Compe 750s.
Or were there touring bikes with cantilevers that could take that fat a tire back in the day? I don't really want a touring bike so I'm hoping to get away from cantilevers.
Pics would be helpful if you have them.
bikemig is offline
Old 05-03-19, 08:17 AM
wgscott
Occam's Rotor
wgscott's Avatar
Bikes: Steel
Quoted: 2366 Post(s)
Liked 209 Times in 129 Posts
Is 2014 vintage yet? (My 38mm Compasses fit with mm to spare.) I was able to cram 28mm tires into my 1987 Bianchi frame.
wgscott is offline
Old 05-03-19, 08:44 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 338 Post(s)
Liked 13 Times in 10 Posts
You've got a better chance they'll fit on bikes that were originally equipped with 27" wheels. Converting to 700c gets you a bit more wiggle room.
Hudson308 is online now
Old 05-03-19, 08:45 AM
tiredhands
Sempiternal Newb
tiredhands's Avatar
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 226 Post(s)
Liked 4 Times in 4 Posts
I'm not sure about frames without cantilevers, I believe a Super Course might have room for 700x38c if you crimped the chainstay. I had 700x35c and fenders on mine.
Touring bikes don't have to just "tour," I've used my Univega Gran Turismo for some singletrack and gravel grinding. It just clears these 700x43c (actual width around 40mm on Sun CR-18 rims) Panaracer GravelKing SKs.
tiredhands is offline
Old 05-03-19, 09:02 AM
Classtime
Classtime's Avatar
Bikes: 69 PX-10, 81 Medici, 84 Turbo, 87 IM, 2010 Milwaukee Road, 2011 RS
Quoted: 542 Post(s)
Liked 21 Times in 18 Posts
My '69 PX-10 fit 35mm CX tires. Sorry, no pics.
Classtime is offline
Old 05-03-19, 09:04 AM
ksryder
Bikes: yes
Quoted: 724 Post(s)
Liked 60 Times in 33 Posts
I'd guess touring or randonneur bikes would be your best bet... but it's not like vintage rando bikes just pop on CL every day... or ever... in the U.S.
ksryder is offline
Old 05-03-19, 09:16 AM
88Tempo
Quoted: 76 Post(s)
Liked 19 Times in 15 Posts
I remember a thread on here where someone set up up a Schwinn World Sport with 700x42? tires.
I know an 88 Letour clears 700x32 easily, but never got around to checking any bigger.
88Tempo is offline
Old 05-03-19, 09:38 AM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 695 Post(s)
Liked 8 Times in 8 Posts
1971 Raleigh Super Course - recently repainted and reconfigured with 81 speeds and 700c x 38mm Panaracer Pro-Tites. They ride quite nicely.
USAZorro is offline
Old 05-03-19, 09:39 AM
TenGrainBread
TenGrainBread's Avatar
Quoted: 651 Post(s)
Liked 51 Times in 38 Posts
I am running 700x38 on my '73 Schwinn Sports Tourer. On skinny Wolber rims they measure out to 35mm, which is probably the max I'd go. 38 would fit but pretty close to the chainstays. I needed to use long reach Dia Compe centerpulls on the back to reach the rim. They work fine.
Fitting 38s usually means a 700C or 650B conversion on a 70s bike, with long reach brakes. If you don't want to use long reach brakes, a dedicated randonneur frame is your best bet. I will be building up a Japanese randonneur bike soon that was originally made to fit 650Ax42mm with cantilevers.
TenGrainBread is online now
Old 05-03-19, 09:44 AM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac
Quoted: 587 Post(s)
Liked 27 Times in 25 Posts
Just did a couple of thousand kilometers, or more, on my 1982 Bianchi Touring which I had to fit with the only tires that I could find in Jamaica. Less than $30.00 US for the set. They just barely clear the chain stays and are a near bullet proof treat to ride (for cheap tires, that is)...
Learn how to find, restore and maintain vintage road bicycles at... MY "TEN SPEEDS"
randyjawa is online now
Old 05-03-19, 09:50 AM
deephate
D. Pate
deephate's Avatar
Bikes: Motobecane, Peugeot, Gitane, Fuji, Nishiki, Centurion, Panasonic, Giant, Trek, Cannondale, Raleigh, Bianchi, Winsor
Quoted: 101 Post(s)
32’s not big enough? That is what I am running on that sweet Gitane. I even have room for some tight fitting fenders with minimal toe overlap.
deephate is offline
Old 05-03-19, 09:59 AM
bikemig
bikemig's Avatar
32c is pretty easy to fit on a lot of vintage bikes. I'm thinking of making a gravel bike with 700 x 38c tires. The alternative is to go 650b.
bikemig is offline
Old 05-03-19, 10:00 AM
retrodude
Bikes: 1984 & 1990 Marinoni Specials - 2008 Kona Dogma - 1976 Schwinn Suburban
Quoted: 5 Post(s)
Liked 8 Times in 5 Posts
Depends on the chainstay lenght, rear brake bridge placement & fork crown design I guess. This 1984 Marinoni is now back to full Campy 12 speed with drop bars but at one time it was a great single speed with flat bars and 35mm 700C knobby tires:
retrodude is offline
Old 05-03-19, 10:03 AM
mrv
BIKE RIDE
Bikes: 198? Specialized RockHopper / 2013 KONA JtS / 1985 Asian Modification / and that's not ALL!
Quoted: 161 Post(s)
Trek 420
I've run 700c x 37 CONTIs in a 56cm TREK 420. The tight point is the chainstays.
I've also run a 700Cx38 in an old NISHIKI. The limit there was the brake bridge.
A great deal of the fit depends on the rim width. A wider rim is going to make the tire "taller", as in closer to the brake bridge.
If you are looking for a bike to run your tires on, the TREK 420 will soon be posted FOR SALE in the C&V pages. (on eBay i see them selling for thousands and thousands of dollars!! .... no, not really....)
Here's some pics. The one with the 'DETROIT BIKES' headbadge is the NISHIKI. It could be for sale, but it's in another city waiting for me to visit the in-laws, so more complicated....
trek
trek
trek
nishiki
nishiki
mrv is offline
Old 05-03-19, 10:06 AM
mrv
BIKE RIDE
Quoted: 161 Post(s)
https://www.bikeforums.net/general-c...700c-650b.html
- if that helps.....
mrv is offline
Old 05-03-19, 10:13 AM
63rickert
Quoted: 477 Post(s)
Liked 18 Times in 15 Posts
The eponymous '63 Rickert was used a lot with Challenge Grifo (now labeled Almanzo) clinchers that stretched out to a measured 35mm. Still good clearance all around. Was necessary to deflate rear tire to remove or install back wheel. That was a completely normal road bike. Tight spot with 38 would be the rear brake bridge. It would make it, not sure I'd do it. Real 35 as opposed to 35 label is a big tire.
Current 1950 Bates has older single spring Weinmann 750 with pad at bottom of slot. Stops fast. The Bates would not take 38. Or 35.
Look at older frames. Old means old. Not 70s or 80s production frames.
63rickert is offline
Old 05-03-19, 10:22 AM
bikemig
bikemig's Avatar
Yeah, I was thinking about this as well. It might mean a really old bike . . . which is kind of cool, right?
bikemig is offline
Old 05-03-19, 10:23 AM
TenGrainBread
Quoted: 651 Post(s)
Isn't it the other way around?
Old 05-03-19, 10:36 AM
bikemig
bikemig's Avatar
trek
trek
trek
nishiki
nishiki
Nice pics. Yeah I am thinking that an older Japanese bike originally built around 27 inch wheels might be the way to go. I like vintage Fujis.
bikemig is offline
Likes For bikemig:
Old 05-03-19, 10:46 AM
phtomita
Bikes: '86 Nishiki Tri-A, '84 Centurion PT15, '87 Centurion IM Master
Quoted: 147 Post(s)
Liked 11 Times in 10 Posts
ProTour15 with Conti GP4SII 700x28c. If there were a wider one I would have tried.
Don't have pics, but I think the narrower spot is between the the bar connecting the chain stays close to the seat tube and the tire.
On my Tri-A I couldn't fit the 700x28c because it was rubbing the seat stay bar where you attach the rear caliper.
phtomita is offline
Old 05-03-19, 10:47 AM
gugie
Crapmaster Emeritus
gugie's Avatar
Bikes: JP Weigle'd Raleigh Competition reconstruct, 73 Raleigh Competition 650b'ed, 96 Bike Friday NWT, 83 Lotus Classique, 78 Centurion ProTour, 73 Raleigh Grand Sports
Quoted: 2214 Post(s)
Liked 39 Times in 32 Posts
Whoa, whoa, whoa, 81 speeds?
Front 3, rear 9 + 3 speed IGH? Thatsa lotta shift levers in the cockpit!
gugie is offline
Old 05-03-19, 10:55 AM
ascherer
ascherer's Avatar
Bikes: 1987 Mercian Pro, 1971 Raleigh International, 1971 Peugeot PX-10E, 1966 Raleigh Sports
Quoted: 254 Post(s)
Liked 16 Times in 10 Posts
Compass 700x35 on my 71 International and my wife's 84 Lotus Eclair:
ascherer is offline
Old 05-03-19, 11:54 AM
noglider
noglider's Avatar
Quoted: 5360 Post(s)
Liked 77 Times in 60 Posts
I'm about to put 700c x 37mm tires on my 1971 Raleigh Super Course.
I already have 650b x 38mm tires on my Lemond which previously had 700c x 25 tires. It's fun, because I can roll over bumps and ask myself if I really rolled over them.
noglider is offline
Old 05-03-19, 12:03 PM
CO_Hoya
Señor Member
Bikes: Yes
Quoted: 127 Post(s)
Liked 3 Times in 3 Posts
Not really. If you think of cross-section of the tire/rim system as a circle, then the rim contributes a portion of that circle's circumference.
When the rim gets wider, it causes the circumference to larger and therefore the circle to get bigger. Thus a larger diameter and effectively a taller tire.
N.B. - Once the rim is contributing as much to the circumference as the tire, this simple analogy falls apart
CO_Hoya is offline
Likes For CO_Hoya:
Old 05-03-19, 12:15 PM
Hobbiano
Quoted: 136 Post(s)
Liked 10 Times in 8 Posts
I have a not too vintage '96 Trek 520 touring. It came with a 7-speed cassette but the rear dropouts are 135mm spacing. I'm running a 9-speed cassette now.
I have 700x28 Marathon Plus tires on it that measure 27.75 actual width. There is a minimum of 15mm clearance on each side as well as on the outside diameter of the tire, front and rear, on this bike. I'm sure you could run tires even larger than 38mm on it easily.
I have a Miyata 610, and an '86 Schwinn Voyageur fhat I could measure if you want me to, but while they fit 27x1-1/4 Paselas, they don't have a ton of extra clearance.
Hobbiano is offline
