A cautionary tale for old derailleurs
Old 05-23-19, 12:37 PM
Aubergine
Bad example
Quoted: 771 Post(s)
Liked 17 Times in 14 Posts
It is a gooood idea to check the limit screws and add a coat of loctite if they are at all loose. I am off today to the bike shop to replace the nine rear drive side spokes that sheared when the chain dropped.
Aubergine is offline
Likes For Aubergine:
Old 05-23-19, 12:40 PM
katsup
katsup's Avatar
Bikes: 2017 Salsa Vaya Deore, 90 Trek 520, 91 Fuji Sundance, 1991 Kona Explosif
Quoted: 214 Post(s)
Liked 28 Times in 14 Posts
If only they made a piece of plastic or something to help prevent this....
katsup is offline
Likes For katsup:
Old 05-23-19, 12:43 PM
bikemig
bikemig's Avatar
Quoted: 3613 Post(s)
Liked 68 Times in 60 Posts
I think there's a thread here, or there should be one, called show me your bike with a dork disc which is perfect for you.
You can post pics of your bikes there and chide BF members for not having the smarts to run them.
bikemig is offline
Old 05-23-19, 12:46 PM
Honusms
Honusms's Avatar
Bikes: More than my husband knows about
Quoted: 85 Post(s)
Liked 10 Times in 7 Posts
The new/old Sachs freewheel I just installed on my Motobecane Grand Record came complete with one!
Honusms is offline
katsup
katsup's Avatar
Quoted: 214 Post(s)
I'm aware of that thread.
I visited a closing bike shop and asked about their dork disks. They gave me a box of various sizes that they removed over the years, so now all my bikes have them.
katsup is offline
Old 05-23-19, 12:59 PM
bikemig
bikemig's Avatar
Some of them are beautiful. I have a few bikes that proudly wear their dork discs.
bikemig is offline
Old 05-23-19, 01:02 PM
SurferRosa
SurferRosa's Avatar
Quoted: 369 Post(s)
Liked 47 Times in 33 Posts
The limit screws have springs to keep them in place. If that's not working, try different screws. Then use loctite blue.
If my chain drops from the big rear cog, physics pulls it down to my next smaller cog, not toward the spokes.
For all my rebuilds, the dork disk always goes with the reflectors, steel components, kickstands, and turkey levers: straight in the trash.
SurferRosa is offline
Likes For SurferRosa:
Old 05-23-19, 01:03 PM
Weresquatch
Bikes: Just the normal stuff, cruisers, duilies, fatbike, road bikes, single speeds...
Quoted: 16 Post(s)
Liked 10 Times in 9 Posts
Oh, that BLOOOWWS. I've never run a dork disc but I've also never had that happen. With that said, I do have purple that I usually use on small, fiddley screws.
Weresquatch is offline
Likes For Weresquatch:
Old 05-23-19, 01:16 PM
Aubergine
Bad example
Quoted: 771 Post(s)
Not all limit screws have springs. Mine did not.
Old 05-23-19, 01:57 PM
seedsbelize
Refugee
Quoted: 4727 Post(s)
Liked 33 Times in 26 Posts
I use dork discs. And I use helmets.
seedsbelize is offline
Likes For seedsbelize:
Old 05-23-19, 03:04 PM
SurferRosa
SurferRosa's Avatar
Quoted: 369 Post(s)
What kind of rear derailleur?
Old 05-23-19, 03:09 PM
Kuromori
Quoted: 107 Post(s)
Liked 15 Times in 12 Posts
There's also a piece of plastic on most modern derailleurs that turns the the threaded limit screw holes into nyloc nuts. Much stealthier.
Kuromori is online now
Old 05-23-19, 03:21 PM
Aubergine
Bad example
Quoted: 771 Post(s)
An old Huret Duopar Eco.
Old 05-23-19, 03:40 PM
SurferRosa
SurferRosa's Avatar
Quoted: 369 Post(s)
Ooh. That's a real clunker.
For the bored, take a drink every time RJ says "here."
Aubergine, if you have a Campy-style hanger, best to use almost any Suntour mech in place of that Eco.
Old 05-23-19, 03:49 PM
Aubergine
Bad example
Quoted: 771 Post(s)
https://youtu.be/0WMdgPrgZdw
Hmph! I am offended. I love my DuoPars!! They are better than even the best Suntour friction derailleurs. So there, Nyah Nyah.
Seriously, the DuoPars work very very well, but I acknowledge they need attention. Which is why it really is on me that I did not notice the limit screws were loose enough to unscrew. And @SurferRosa, the derailleur is on a 1973 Motobécane Jubile with Huret dropouts, so it fits perfectly with the age and character of the bike.
I have another DuoPar on my Old Peugeot #1, an AO8 from 1974 or thereabouts. It has been a standout. So I am confident that these work well when cared for.
Old 05-23-19, 03:57 PM
SurferRosa
SurferRosa's Avatar
Quoted: 369 Post(s)
I take that back. Don't do that. I had to count 'em. 86 times. 86 drinks will kill a man. No matter how clunky your derailleur, you shouldn't have to die for it.
I think he says "there" about half as many times, but I didn't count.
Old 05-23-19, 03:58 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 658 Post(s)
Liked 55 Times in 41 Posts
@SurferRosa Nothing wrong with Duopars. Not many mechs can compare to the chain wrap capacity of an Eco or Titane. Nor is the Eco (steel cage version) even that heavy for a nice long cage touring derailleur.
Also, if you really do throw all steel components in the trash, there would be quite a few Campy and Suntour mechs in the trash as well. Read up on Disraeli Gears and you'll see the nicer rear mechs didn't start going to alloy bodies until the 60s/70s. Even then and still today, rear and front mech cages are still made from steel as it is an application that requires it. No use making blanket statements throwing things in the trash.
TenGrainBread is online now
Likes For TenGrainBread:
Old 05-23-19, 04:03 PM
SurferRosa
SurferRosa's Avatar
Quoted: 369 Post(s)
If you really do throw all steel components in the trash, there would be quite a few Campy and Suntour mechs in the trash as well.
Yes and no. I haven't come across that many campy steel derailleurs. Three, I guess. But you're right. Unless they're campy or suntour, the steel bits go in the trash.
Old 05-23-19, 04:54 PM
ryansu
Ride.Smile.Repeat
ryansu's Avatar
Quoted: 464 Post(s)
Liked 40 Times in 33 Posts
I am sorry for your spoke shearing incident, early in my bike fiddling days I "adjusted" my RD to accommodate a bigger Cassette (yes before I went full on C&V) and ended up trashing the derailleur hanger which fortunately was replaceable. I have to say your Nyah Nyah retort made me laugh out loud, just glad I hadn't taken a drink or it would have been spit take city.
ryansu is offline
Old 05-23-19, 05:12 PM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Palo-Alto/Falcon
Quoted: 171 Post(s)
Liked 11 Times in 7 Posts
I'd rather risk replacing the spokes. Or risk walking home 20 miles.
YMMV
(OTOH, it's been a while since I've even been in the lowest sprocket, so I wouldn't be risking much)
tiger1964 is offline
Likes For tiger1964:
Old 05-23-19, 05:32 PM
BFisher
Quoted: 47 Post(s)
Liked 31 Times in 27 Posts
Ha ha! Steely good Suntour Honor, Nervar cranks, and a dork disk. Yeah, baby!
@Aubergine, sorry to hear about your limit screw up. I nearly did the same thing once. Only caught it as I checked the shifting in the stand before I set out. Hope you get things squared away quickly.
BFisher is offline
Likes For BFisher:
Old 05-23-19, 05:35 PM
Aubergine
Bad example
Quoted: 771 Post(s)
Ha. Well, I figure that arguing over C&V equipment shouldn’t become too serious. :-) I like Suntour dérailleurs a lot as well — I have a VGT on Old Peugeot #2 — so I actually would have been content to use one on the Motobécane if it had had Campagnolo standard dropouts.
Old 05-23-19, 06:45 PM
Kent T
Quoted: 31 Post(s)
Liked 7 Times in 5 Posts
I love Suntour friction era derailleurs a lot, never met a VGT, AR, or ARx I didn't like. Never had issues with them. Shifted impeccably every time. Run one on the Rolling Stone (my 1982 Bridgestone Spica, aka the $20 wonder).
Kent T is offline
Likes For Kent T:
Old 05-23-19, 06:49 PM
katsup
katsup's Avatar
Quoted: 214 Post(s)
I've always wondered why the hate. I like the look as long as they are not oversized, faded, or broken.
In my opinion, compared to a helmet and lycra, a spoke protector is low on the dork scale.
katsup is offline
Likes For katsup:
Old 05-23-19, 06:56 PM
t_e_r_r_y
t_e_r_r_y's Avatar
Quoted: 40 Post(s)
Liked 17 Times in 11 Posts
to add another layer to your game, or if you're just bored, use youtube's speed up/slow down feature to put rj at half speed and he sounds just as drunk as you're going to be playing the "here" or "there" game
t_e_r_r_y is online now
Likes For t_e_r_r_y:
