Shifters for Shimano 1x10?
Quoted: 136 Post(s)
Liked 57 Times
My wife's bike has a worn out XT 780 shifter (ratchet misses on index finger pull to higher gears). That shifter was from my old 1 x 10 set up before I went to 11-speed so it's seen some use. Anyway, I found her a lightly used 10 speed Deore shifter in my parts box. That should work ok with it, right? The RD is an older XT if that matters (780? not sure of its model number).
you have parts to mount try them ..
I don't get the you guys first tell me if it works , before doing it , 1st hand , learning..
Internet is weakening the mechanical skills ..
Quoted: 136 Post(s)
Liked 57 Times
Your logic is flawed. Me asking here doesn't weaken my mechanical skills--I already know how to swap these parts, tune, etc. What I lack is compatibility info, which you obviously don't have. Yes, I could buy a new cable, lube it up, install the shifter to "test it", possibly find it doesn't work, take it all off if it doesn't, wipe off the lube, coil up the unneeded cable, buy a new XT shifter that comes with a cable (which means I went to my LBS and bought the other cable for no reason), install it and be happy. On an aside, I knew I could count on you showing up and posting one of your typical snarky comments. Yes, we could go back and forth here but I will stop here. I have a bike to fix.
Even if an expert here knows, there is a chance it is the opposite or some misunderstanding. So trying is the best way if you already have the parts.
The situation would be different if you had to order the part to try.
