What water bottle do you use?
Old 06-01-19, 07:58 AM
RVH
Bob in the mountains
Bikes: Trek Madone 5.9 (2004 model bought used)
Quoted: 16 Post(s)
Liked 9 Times in 2 Posts
I need new water bottles and I can't find anything like my old, very simple, very light bottles. What do you recommend?
RVH is offline
Old 06-01-19, 08:31 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I have a lined aluminum Zefal at my bedside , I have has plastic one burst when squeezed ..
cap airflow is excellent on those important on metal waster bottles ...
Camelback Podium on 2 bikes..
fietsbob is offline
Old 06-01-19, 08:43 AM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 697 Times in 435 Posts
Nothing fancy, just regular plastic Polar bottles work for me. Not super light tho.
freeranger is offline
Old 06-01-19, 09:59 AM
Jim from Boston
Jim from Boston's Avatar
Quoted: 800 Post(s)
Liked 218 Times in 171 Posts
I have previously posted:
Originally Posted by Jim from Boston
My preference for water is flavored carbonated water. [The local brand here around Boston is Polar Seltzer and it comes in a lot of flavors.] It comes in one liter bottles with a screw top cap to contain the carbonation.
It's inconvenient to open especially while riding, but it's so much more refreshing than plain water, even and especially when warm…
The liter bottles fit tightly in the cages and I secure them with a rubber band to prevent them from popping out.
...The first two swills have a kick to them, and even at the end of the ride after the bottle has been opened a couple times and it's warmed up, it still is more satisfying than tap water.
The downside is that I do have to unscrew the cap, so I have to slow my riding down to do that maneuver; or take a drink when I stop.
This year during the hot weather, I have begun bringing a smaller bottle of tap water, just for the purpose of dousing myself, refilling and repeating as necessary. In a pinch I have used the seltzer water too.
These bottles IMO are quite lightweight, made of rather thin guage thickness, pliable plastic, and the screw top caps nicely hold the pressure in. One winter, for example:
…I use a plastic liter carbonated soda bottle for my water supply, and it was only partially full.
At about mile 3, going up my steepest hill, the air in the bottle had contracted so much that the bottle was almost limp, and popped out of the holder, but the water did not freeze.
However,
Speaking of winter I have on a few posts repeated the suggestion of the definition of a cold ride as one where the water bottle freezes solid, as a function of temperature and time. For my 14 mile commute of slightly over an hour that occurs at about 15º F.
Jim from Boston is offline
Likes For Jim from Boston:
Old 06-01-19, 10:34 AM
hillyman
WALSTIB
hillyman's Avatar
Quoted: 280 Post(s)
Liked 384 Times in 183 Posts
Elite Termo Nanogelite. Expensive and not the best nozzle/cap but fill with ice and water stays colder longer to me than the polar ones.
www.bikeleague.org
hillyman is offline
Old 06-01-19, 11:44 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
I was on a similar quest - for a cheap plain clear bottle. In the end, my LBS had $5 bottles with their logo on them. Since I use the shop anyway, I have no problem displaying their logo, and the price was right
Litespud is offline
Old 06-01-19, 11:47 AM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
Camelback insulated
GlennR is offline
Likes For GlennR:
Dirt Farmer
Dirt Farmer's Avatar
Bikes: Jamis Quest Elite; Fuji Sagres; Trek Fuel EX 8
Quoted: 329 Post(s)
Liked 74 Times in 54 Posts
I use the Camelbak Podium Big Chill, as it's the only one I've found that does not leak a little bit. All other bottles kept in my downtube bottle mount would leak just a little bit on longer rides.
Dirt Farmer is offline
Old 06-01-19, 11:57 AM
Fahrenheit531
52psi
Fahrenheit531's Avatar
Quoted: 790 Post(s)
Liked 801 Times in 390 Posts
Bike shops sometimes have their own "branded," dime-a-dozen plastic water bottles. Cheap as dirt (I may never have actually had to pay for one, now that I think about it.) and they meet my needs:
Holds water? Check.
Dispenses water? Check.
Fits in cage? Check.
Fahrenheit531 is offline
Likes For Fahrenheit531:
Old 06-01-19, 12:38 PM
BCDrums
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 255 Post(s)
Liked 252 Times in 134 Posts
Get bottles that match your bar tape or cable housings or helmet. Stylin’!
BCDrums is offline
Old 06-01-19, 01:50 PM
August West
Quoted: 152 Post(s)
Liked 173 Times in 105 Posts
CamelBak Podium Chill, Big Chill & Podium Ice. Mix and match depending on ride length and temp. Load them up with ice & water before the ride and they tend to stay cold for a little longer than a regular bottle. I've found them to very durable and I like the valves.
August West is offline
Likes For August West:
Old 06-01-19, 02:04 PM
dim
dim's Avatar
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times in 22 Posts
Elite Deboyo Ombra Stainless Steel Thermal Bottle
dim is offline
Old 06-01-19, 02:06 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
Generally, Camelbak Podium. The valve caps tend to stay intact longer than those on the cheap bottles.
I have a Big Chill only because it is big. Years ago when doing two-a-day practices for high school sports in August heat (with no AC, fans, sunscreen, or supplements other than bananas) I discovered that warm water did not make me puke and cold water did. I still never use ice-cold water on rides, though may add a few ice cubes on hot rides to keep it room temperature.
Like @Jim from Boston, I sometimes use 1-liter bottles. I'm not a fan of carbonation while riding, but these bottles nicely hold a lot of water. I tend to use them early/late in the season when it's cooler and I'm combining commutes, transportation, and recreational rides to save daylight.
wipekitty is offline
Old 06-01-19, 04:18 PM
Wileyrat
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 336 Post(s)
Liked 223 Times in 135 Posts
Camelbak Podium Chill
Wileyrat is offline
Likes For Wileyrat:
Old 06-01-19, 04:59 PM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 941 Post(s)
Liked 319 Times in 189 Posts
We were off to visit the kids for a few days. The weather forecast was iffy at best. I took our bikes just in case. Actually, the weather was great. However, I had forgotten to pack water bottles. , so off to Target. Found 25 oz. Camelbaks, bought two, very pleased, seemed to keep the liquid a little cooler and liked the added capacity.
bobwysiwyg is offline
Old 06-01-19, 05:58 PM
robnol
Quoted: 277 Post(s)
Liked 18 Times in 15 Posts
a profile design aero bottle between ur aero bars is awesome....
robnol is offline
Old 06-01-19, 07:13 PM
3949dxer
Bikes: Specialized Roubaix Sport, Merida road bike, crappy old MTB
Quoted: 13 Post(s)
I and two cycling friends independently discovered that Evian 1 liter bottles are perfect for cycling. They are strong and thick and the material has a good amount of friction so it's secure in a bottle cage. I have a bunch of them and just refill them with filtered water from our kitchen.
3949dxer is offline
Old 06-01-19, 08:05 PM
devianb
devianb's Avatar
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 26 Post(s)
Liked 30 Times in 19 Posts
I don't have a recommendation, but I take a weight penalty to have my drinks ice cold. I use a 21oz. Hydro Flask.
I do have a 32 oz Powerade bottle I use in the summer in addition to my Hydro Flask. It was the largest bottle that would fit my bottle cages.
devianb is offline
Likes For devianb:
Old 06-01-19, 09:05 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
That saved me a lot of typing, because that mirrors my setup exactly. Out of direct sunlight, I've had Podium Ice bottles hold ice for 10 hours.
DrIsotope is offline
Old 06-01-19, 10:22 PM
Happy Feet
Happy Feet's Avatar
Quoted: 2236 Post(s)
Liked 1,314 Times in 707 Posts
Nalgene 1.5L
Happy Feet is offline
Old 06-01-19, 11:15 PM
Slightspeed
Slightspeed's Avatar
Quoted: 741 Post(s)
Liked 818 Times in 421 Posts
+1 on the Camelback podium bottles. Still mad at myself for leaving one at a Starbucks and riding off. Senior moment, I guess. For you guys with hard metal bottles, I'd hate to hit one if dropped on a group ride, riding in a tightly packed group. They don't seem very safe to me. Racing back in the 60s we used hard aluminum bottles, and I've seen a few dropped. This was BP, before plastic. 😏 I do find the Camelback bottle valves hard to dismantle and clean, but mine are pretty old. Maybe the new ones are better.
Slightspeed is offline
Old 06-02-19, 12:00 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Steely Dan
caloso is offline
Old 06-02-19, 12:14 AM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 582 Times in 379 Posts
I've used whatever was given to me.
However, when I want a good water bottle that I have to pay for, I would get a specialized. The opening is wide enough to put ice cubes, the spouts are easy to open and close, the bottle is durable and squeezes easily.
Curious, how do you get water out of a Stainless Steel water bottle that has a regular water bottle spout without taking the top off?
texaspandj is offline
Old 06-02-19, 02:32 AM
taz777
taz777's Avatar
Bikes: 5
Liked 25 Times in 19 Posts
Another vote for Camelbak Podium Chill.
I have a collection of water bottles and the Camelbak is the only one that doesn't alter the taste of the water during a longer ride. Plus, the insulation properties of it do work to a good extent (up to nearly two hours in my experience).
taz777 is offline
Old 06-02-19, 05:30 AM
bertinjim
bertinjim's Avatar
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 344 Post(s)
Liked 266 Times in 157 Posts
RVH -
California Springs water bottles in 20 or 24 oz. versions. The narrow neck allows easy snagging when lifting from the cage but is wide enough for ice cubes. They are freezable and the lid allows a free flow. No bad plasticy taste and squeezable to increase the flow rate. Style wise they match my classic steel bikes. Can't ask for more.
bertinjim is offline
