Rule of thumb? Add this many teeth and add this many chain links?
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I ride a gravel bike but it's pretty much just a road bike now since the "gravel" here is beyond my abilities.
Anyway, I have a 46/36 in the front and an 11-40 in the back. I decided to get a compact crank (50/34), but realized I probably need a longer chain now since I'm adding 4 teeth.
Is there a rule of thumb that I can use to determine how many links I need to add? When I setup the 11-40, I used the whole length of KMC chain I bought. Of course, now I'm worried that the chain is too long since I lost 2 teeth on the smaller ring.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
You want a thumbrule based on experience?
"Probably zero, might be one... maaaaaaybe two."
If your derailleur is REALLY tight in the big big, you'll probably need a new, longer chain. Else just wait and see.
Quoted: 4201 Post(s)
Liked 3,857 Times
Since I don't assume that the bikes I work on have had their chains set up lengthwise for the best shifting (as opposed to the least cost, after 112 bikes the company has a "free" chain if they shorten each chain by one link/pair) I CAREFULLY test before I do anything. But I agree with DiabloScott. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2026 Post(s)
Liked 1,096 Times
The "rule of thumb" for changing total teeth count is add or subtract 1/2 of the tooth difference. For example, going from a 46T to a 50T chainring you should add 4/2=2 half-links. If the difference is an odd number go to the next even number since you can't add 1/2 of a link. The reason for adding only 1/2 of the difference is that the chain only wraps around 1/2 of the chainring or cog.
Before anyone says anything, yes, there are 1/2-links available but they are unusual and not commonly used.
To do it right, don't rely on the original chain being correct.
Read the RD manual on chainsizing and verify if the chain is the correct length. Typically it is big-big + 2 or 4 links.... but that differs for SRAM and Shimano and for FS bikes there is even more to consider. RTFM.
Quoted: 2338 Post(s)
Liked 2,822 Times
I used big big +2 for years, but am now of the opinion that small/small works better ....this is what my LBS guy recommends and is what shimano recommends
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,378 Times
Anyway, I have a 46/36 in the front and an 11-42 in the back. I decided to get a compact crank (50/34), but realized I probably need a longer chain now since I'm adding 4 teeth.
Is there a rule of thumb that I can use to determine how many links I need to add? When I setup the 11-42, I used the whole length of KMC chain I bought. Of course, now I'm worried that the chain is too long since I lost 2 teeth on the smaller ring.
Quoted: 1572 Post(s)
Liked 643 Times
Smaller than 11t?
Liked 643 Times
To answer OP's original question, why guess? Since you're going to break the chain anyway just wrap it around the big/big combination and test it for sure.
Liked 2,822 Times
OP should also check what the wrap capacity of his rear derailler is, may not have the capacity for the change
currently he is at 41 wrap ((46-36) + (42-11) (10 + 31)
with a 50/34 the wrap is 45 (50-34) +(42-11) (14+31)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
+1. I almost never count links on my chain. I take a new chain out of the box, loop it around the big ring and big cog, add 1" for good luck, and cut it.
Likes For ThermionicScott:
bike chain is 1/2" pitch , a full link is 3 rollers, 2 on the inner and the 3rd one the 2nd pin into the next inner link
so an inch..
now you join 2 inner links with a quick link, functionally an outer link with pins fixed in it.. one on each side..
so an inch..
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
Quoted: 160 Post(s)
Liked 68 Times
Looks like I need to adjust my plans after a big Doh! moment. My current cassette is actually an 11-40, not 42. Not that that matters in the grand scheme because I was planning to use the original 11-32 on my spare rear wheel for Zwift. Of course, I'm not going to be swapping chains each time I want to Zwift, too.
Looks like I need to decide whether I want to stay with the 11-40 or go back to 11-32, and then buy another cassette to match. Doh.
https://www.youtube.com/watch?v=QuhHn7HaZcQ
Quoted: 6193 Post(s)
Liked 4,808 Times
Shimano publishes the exact procedures to use for determining chain length. There are differences for things like 3x or 2x front. Long, medium or short rear DR and other things. Other mfr's probably publish how they want chains sized to their groupsets too.
Shimano Tech docs are here... https://si.shimano.com/#/
You need to find the DM's appropriate to your bikes groupset.
Quoted: 160 Post(s)
Liked 68 Times
The new crank is installed and it doesn't seem like I need to add or subtract any links.
Liked 2,822 Times
just double check that big/big works.. it is not fun if it does not and you move into that at speed
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
My rule of thumb is to measure it on the bike, thus taking out any guesswork or assumptions.
Big-big plus 2 or 4 (half links), depending on the application.
Go to the park tools video series on chain sizing.
Clear, concise, no guess work from a reliable source.
