new stoker post
new stoker post
Not available yet, but looks interesting...
https://www.cyclingnews.com/features/...ype-first-look
-Stuart
-Stuart
Likes to Ride Far
Specialized also has something similar coming out soon, the Cobl Goblr - 18mm of vertical compliance in an all-carbon post. Apparently, these aren't any available aftermarket yet (only on complete S-Works Roubaix bikes), but once the supply is up then they will start making them more widely available. We have one on back-order with the local Spec' dealer - we'll report back once we get it, but don't hold your breath.
Clipless in Coeur d'Alene
I can't see the Ergon working that well for a road tandem, as that post is meant to help with rear wheel pitching hits. Hmmm, I'm sure we could think up something funny about that last part
Bikes: Volagi, daVinci Joint Venture
The Recumbent Quant
-Stuart
-Stuart
One question though. Why "stoker" post?
Cheers,
Charles
Well, the captain could certainly use one if desired, but it is generally the stoker that bears the brunt of rough roads and is most appreciative of a little extra comfort. That's the only reason I called it that.
The Recumbent Quant
Cheers,
Charles
A few reasons I can think of: 1) the stoker is mounted almost directly over the rear wheel, so bumps travel very directly up the stoker's seat stays from wheel to saddle, whereas the captain is mounted near the center of the frame and benefits from any flex in the long tandem frame. 2) the stoker can't see bumps coming and so isn't as prepared unless the bump is large enough for the captain to call out. 3) more often than not, the stoker is a lady who deserves a smooth ride! The looks of a LT Thudbuster may not be for everybody, but my stoker sure loves the ride it gives her. Bob
The Recumbent Quant
Cheers,
Charles
Bikes: 2004 Co-Motion Speedster
Interesting. I'd installed a Specialized post with the zertz insert (her old Specialized Ruby also had one) that she likes. On the other hand, anything that makes the stoker happy is ALWAYS a plus. That, and the current post is a pain to adjust w/ her Brooks saddle.
Jeff
Learn from other people's mistakes. You won't live long enough to make them all yourself.
2010 (Specialized) Carmel comfort (my neighborhood bike)
2008 Raleigh comfort (wife's neighborhood bike)
Jeff
Quoted: 509 Post(s)
Liked 9 Times
To amplify on what reburns said, when the rear wheel hits a bump and rises up an inch, the stoker's saddle will also rise about an inch, but the captain's saddle will only go up a fraction of that because it is nearer the fulcrum (front axle). So, a minor vibration for the captain is a bone-jarring experience for a stoker, especially if the stoker didn't know it was coming.
Likes to Ride Far
Point 1 is definitely important - The captain's post being a long way from either wheel means that it is EXTREMELY well damped. None of my single bikes (which are steel, alu', and carbon), give anything close to the smooth ride that I get in the captain's seat of the tandem. There is definitely no need for any kind of comfort seatpost when you have all of that frame to flex. OTOH, the stoker is basically in the same position as on a single bike, so has the regular amount of road shock that would be experienced on a single bike, but maybe a little more because of how stiff the seatstays must be to handle all the weight of a tandem team. Combine that with Point 2, the stoker's inability to see many shocks coming, then seatpost comfort becomes more important for a stoker than on any single bike.
I agree that Point 3 is pretty lame - women can choose to be just as tough as guys, it's just that many choose not to be (which may be wise or weak depending on your perspective).
Bikes: Spec. Roubaix, Cannondale RT2, BF NWT, BF tandem
I've had no problems with my Wound-Up post. I probably have upwards of 6500 miles (a conservative figure, but I don't remember when I swapped over) with no problems.
Jeff
Jeff
Likes to Ride Far
Every manufacturer of carbon posts recommends against clamping anything to their carbon posts, and most people on web forums echo these warnings. However, I have clamped a stoker stem to a carbon post of the tandem for a few thousand kms and have clamped seatpost mounted racks to a carbon post on my single bike with 5+ kg of weight on the rack for several hundred kms. Like Sprout97, I've never had an issue with any of these posts.
If I had an uber-lightweight carbon post (like one from one of those German weightweenie manufacturers, or something similar) then I would probably not clamp anything to it. With most other carbon posts, I would not be too worried. Having said that, we now have a Thomson seatpost for the captain's seat on the tandem (which I basically got for free because I grabbed it off of another bike that I flipped) and I have no desire to switch it back to a carbon model now. A lightweight aluminum model like a Thomson is about the same weight as most carbon models and you don't have any worries about going against manufacturer's warnings.
Liked 6 Times
We fossils have found that there are several "low tech" options which help.
Our C'dale (see sig.) has an older "damping" seat post which, combined with my bride's Selle Anatomica saddle, works just fine.
Our vintage Santana has a solid stoker post. We fitted a Brooks B67s (sprung saddle) and my bride is quite happy with the result. (The B67s is not as... firm as the B17!)
The Santana that we rode for a week in Europe had a Thudbuster stoker post. However, we packed the Selle Anatomica and she said it seemed no different in comfort than either of our own bikes.
YMMV
YMMV
Bikes: Co-Motion Mocha, Fuji touring, Trex hybrid, Bike Friday Tandem Traveler
I've been trying to source a cobl gobl seat post - anyone have luck finding one yet? Also curious as to if more people have feedback on the use of carbon fiber captains seat posts? I'm also concerned about clamping the stoker stem to it.
