Tubular Rims (polished silver)
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 299 Post(s)
Liked 684 Times
Hiya Folks,
I got back into cycling a couple of years back when I spotted a 1982 Holdsworth Avanti on Ebay a couple of miles away - I bought one new in 1983.
But this one turned out to have tubular wheels, something I had no experience of.
Long story short, after 2.5 years now I only ride tubular and I love them.
My Avanti came with Mavic Monthlery Route which is a workhorse training/road rim, well suited to roads in London.
I built a 1961 Holdsworth Cyclone last year so I stepped up my game slightly: Mavic Monthlery Pro
Campy Nuovo Tipo large flange (1253) + Mavic Monthlery Pro:
But the question I keep asking myself is what other rims should I be considering ?
Obviously I prefer polished silver - not anodized, and double eyelet 36 hole.
I've also seen comments that rims below 400g are too light for potholes.
I also want to try black/tan tyres at some point (Vittoria Corsa Control ?) - perfect excuse to build more wheels.
Or maybe I just need to buy another vintage frame.
Here's the list I've come up with so far:
So can anybody suggest a suitable rim I haven't listed ?
Any other advice welcome too
Likes For Aardwolf:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2207 Post(s)
Liked 4,660 Times
I haven't much experience with tubulars, so nothing to add, alas.
But I do have a fairly large collection of tubular wheels waiting to be tried, so thanks for that list! Very useful.
Likes For Aardwolf:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 170 Post(s)
Liked 278 Times
I've never ridden one, but in the past I built up a set of Constrictor Conloy tubulars on a pair of Racelite hubs for a customer.
On Sheldon Brown's site, you can find a link to Spocalc, which has a pretty comprehensive list of rims. With some cross checking and internet image searching, you could find which are white aluminum and 36 hole.
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
I went through Spocalc and checked against Velobase, added a few (most were anodized)
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 165 Post(s)
Liked 102 Times
What kind of riding would these be for? Also, I would think the tires would make a big difference.
Likes For kroozer:
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
So the main danger to rims is from potholes.
I'm currently using Vittoria Rubino Graphite 2.0 28mm tubulars (75 psi) and like them a lot.
Butyl tubes so they stay up for months, but the ride may be better on latex.
I'm considering trying Vittoria Corsa Control tubulars, 28mm again. But they're latex and available in tan wall.
Quoted: 2335 Post(s)
Liked 5,086 Times
I hand polished the Arc en Ciel's on my Opus before mounted the tubulars a few years ago. They still look great and have been trouble free laced to some Superbe hubs. This was a 1981 wheelset supposedly.
Steel is real...and comfy.
Likes For jamesdak:
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
I've got roughly the same saddle bag and a Wrights Swallow to try in the summer.
Having spotted the Araya 16B (road) version I'm coming to the conclusion that 350g might be a reasonable weight to try - same as yours.
Likes For chain_whipped:
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
https://velobase.com/ViewComponent.a...b91ab&Enum=107
Velobse comment: "Light weight with hidden eyelets and reliving of area in contact with tire."
I thought eyelets were a good idea for road rims, I could be wrong though.
Quoted: 1958 Post(s)
Liked 2,035 Times
Vintage rims under 400g are only for good roads at high pressures. Eyelets? Ambrosio or Mavic Reflex (silver).
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
Blue Andonized; Ceramic Coating;
Gray; Hard Anodized
Quoted: 1163 Post(s)
Liked 442 Times
If your frame has clearance you can add Velocity Major Tom tubular cyclocross rims to your list. These are for 24/25mm width tubular tires minimum. 27-33mm tubulars might be best. Also these should be very strong despite not having any spoke ferrules.
Also these are not clear anodized so the polished finish will develop water spots when ridden in the rain. The polish can be maintained using Mother’s Mag Wheel Polish, then maybe followed up with a car wax product like the Meguiar’s cleaner wax I use. This will “seal” the porous aluminum somewhat and help resist water and keep a shine a bit longer.
BTW: Velocity Major Tom rim extrusion is the tubular version of Velocity’s A23 clincher extrusion. These have a triangular semi-aero shape that may work for certain bikes. I have used double sided tape to attach my tires, the rear is a 30mm Schwalbe with a basketball tread. The front is a 25mm TUFO.
Cantilever believer
Quoted: 554 Post(s)
Liked 1,917 Times
I think I raced on Medaille D' Ors in the early 80s.
Liked 2,035 Times
Mavic Reflex: https://www.velobase.com/ViewCompone...=107&AbsPos=64
Gray; Hard Anodized
Gray; Hard Anodized
Plenty of silver rims. Alas, not polished.
https://www.ebay.com/itm/38578726085...mis&media=COPY
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
silly.
I'm going to say Velobase is wrong, or maybe just misleading (grey = silver ?)
They look pretty good, but they are anodized:
From https://fawkes-cycles.co.uk/mavic-re...ver-rim-p15569
- High performance tubular road rim that builds into a light and strong wheel
- SUP rim has a stronger arc-welded joint which is then milled to form an invisible join, eliminating juddering when braking
- Maxtal alloy is 30 % stronger than 6061 without any extra weight
- Anodised finish to reduce wear and corrosion
- UB Control gives the rims a higher coefficient braking surface and a smooth joint due to the digital milling process after anodisation
- Drilled for Presta valve tubes
- Weight: 375 g
Maybe I should do a table for silver anodized.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
Only single-eyeleted, but I recommend Nisi Corsa Stretto at 420g.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
Not sure I can see the difference with "single eyed"
https://www.pedalpedlar.co.uk/produc...0c-tubular-rim
Table updated with rims listed on www.pedalpedlar.co.uk:
(Also added Velobase ratings, may not mean much)
Liked 5,086 Times
They are Roubaix's. I'm a Veloflex Tubular snob and don't think I've ridden any Vittoria tubs.
Likes For jamesdak:
Quoted: 175 Post(s)
Liked 452 Times
Velobase says they don't have eyelets
“Senior” Member
Regarding the weight quoted in the chart for Monthlery Route (420 g): I’ve built up two wheelsets with this rim. Weighed each rim at 400g +/- maybe 2g.
Wheelman
Quoted: 299 Post(s)
Liked 684 Times
Velobase: 420g (Spec)
PedalPdeler: 397, measured presumably.
I'll put a comment in the table.
1980 Mavic catalogue
