Too Much Pressure On My Hands
Quoted: 2506 Post(s)
Liked 745 Times
Of course you engage your core.
In the saddle forward position, if you are trying to avoid supporting yourself with your hands, you would have to engage your core hard, really hold your trunk rigid, because you are fighting the imbalance that wants to topple you forward. Your center of gravity is too far forward, and an unbalanced object still tips over, no matter how rigid it is. In the saddle rearward position, you still engage your core, but you don't have to do it as hard, because you are not fighting an imbalanced position, you are simply doing a not-very-deep squat.
Here is another experiment you can try. You've done squats with a bar and weights, I assume. Get in the squat rack, put that loaded bar on your shoulders, keep your butt directly over your feet, and bend forward at the waist. You'll hurt yourself, fall forward, and get yelled at by all the lifters who know what they are about. One of them will get in the squat rack and show you the right way. He'll push his butt way back while bending forward at the hips. Because he is balanced, he will not fall over. Sure he is engaging his core, but so were you; you were imbalanced and he is balanced.
To be technical about it, you do NOT use your core muscles to hold your torso up when you are in riding position. You use your back muscles! Muscles can only contract. Your core muscles can do nothing about the forces that are pressing your torso down towards the bars. Only your back muscles can do that. And they get very strong as a result. Your core, not so much. Your core, however, is constantly needed to oppose the back muscles. To hold a desired position requires the continual interaction of both sets of muscles, one set of which is always working at a mechanical advantage. Over time, the muscles working through more mechanical advantage get weak and undeveloped. It is the imbalance in muscular development between your back muscles and your core muscles that lead to chronic, often acute, back pain and injury.
It was to address this often overlooked aspect of fitness why I mentioned abdominal exercise in my last post. You don't need to do 200 crunches to ride a bike, you need to do 200 crunches 3x/wk so that when you are 55 you won't be sitting in an orthopedic surgeons consultation room learning about the gory details of your upcoming back surgery. One of my riding buddies is 63 and he was facing surgery. One of my good friends is a chiropractor and he told me to try and convince my riding friend to opt out of a surgical intervention. Luckily his wife was also of that opinion and so between the two of us we got him on an abdominal exercise regimen. At present he is no worse than many people who have actually undergone back surgery and does not have any of the expense or possible complications of back surgery. Lets get back to bikes.
Riding very erect will take the weight off your arms and hands but, as noted will kill your aero big time. It also reduces the amount of power you can apply to the pedals. This is a double hit on performance. You are not going to show up to a club ride on a cruiser and wipe up the floor with roadies rocking quasi-time trial machinery. It's just not gonna happen. You can train your arms to hold up a lot of the weight of your torso and the ladies will love you for it. Your hands may complain. Drop bars have lots of alternate positions to give hand muscles opportunity to relax and get blood flow. Use them. Ride the drops occasionally even if you aren't going after a personal best.
The bottom line is, if you are set up correctly, there is going to be considerable weight on your arms and hands on even what we call flat-bar road bikes. You have to go to a very extreme cruiser or Dutch bike riding position where the bars are not only 4" to 6" above saddle height but are also pulled towards you so that the grips are practically in your lap. The Dutch ride like that around town for a couple or three miles but when they want to cover distance they ride bikes that look much like what we use and call drop handlebar road bicycles. I'm surprised no one has mentioned recumbents <running, ducking>
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
If you are rotating your whole body up while maintaining the same reach R (say by rotating a stem or both raising the bar and shortening the stem say), and the result is a bar higher by height H then you have shifted the horizontal projection of your reach back by distance R*(1 - sqrt(1-(H/R)**2). For H small compared to R, this is (R/2)*(H/R)**2. So if you move rotate your bars up to a height of say 3" this is something like a 0.2" shift of your back. Not much.
Liked 745 Times
No, it is right. If you are moving the handlebars straight up, you are stretching yourself out more and may even move the COG forward, putting more stress on your hands.
H
Quoted: 482 Post(s)
Liked 151 Times
As for my first paragraph being nonsensical, do an exercise. Face a wall and put your arms out straight out with your fingertips touching the wall. Now raise your hands 3 to 4 feet up, keeping in touch with the wall and not moving your butt. Exaggerated, but that is all I meant. Head tube angle probably keeps your reach constant as you raise the bar though.
Liked 745 Times
H
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
As an extreme example, suppose the rider is initially in a completely flat back position, such that the line segment from his hips to his shoulder is parallel to the ground. His CG is roughly at his belly button. Then raise his hands a few inches. That raises the shoulder end of the line segment by a few inches, raises his CG by a couple inches, and moves his CG rearward by only a very small amount.
Attached below is a stick diagram illustrating this. Assume shoulder-to-hip distance 24 inch, start with shoulder-to-hip line horizontal (0 degrees), now raise shoulder 4 inch, the shoulder-to-hip line is now at 9.6 degrees, assume CG is on the shoulder-to-hip line 8 inches from hip, the CG is moved rearward by 0.1 inch.
This is just an approximation. In such a position, the CG is actually probably below his belly button (outside of the rider's body).
Of course, as the rider's initial position gets closer to fully upright, then raising the handlebar has a larger rearward effect on his CG position.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
The bolded part is also incorrect, for several reasons, but it's not really worth arguing over.
Raising the handlebar will reduce weight on the hands, and reduce stress on the core. Increasing the reach, by either longer stem or moving the seat back will slightly increase static weight on the hands.
I'll stand by my earlier surmise that those considerations are mostly irrelevant, and that core strength and hand positioning is more apt to provide a solution.
Quoted: 482 Post(s)
Liked 151 Times
The calculation of the geometry I did was the same as in your figure, but I expressed it in terms of vertical height instead of angle.
Quoted: 482 Post(s)
Liked 151 Times
[QUOTE=wphamilton;16985890]You're off by an order of magnitude in your example. I'm not going over the math but you'd be better off using trig directly.
QUOTE]
Please if you are stating I am off by an order of magnitude, then do the math and show me. I am not off. I will draw a picture for you later if I get time if it will make you happy.
QUOTE]
Bikes: Nashbar Road
Liked 341 Times
Apologies, but I was serious that I'm not going over the math. Make some reasonable assumptions on torso angle eg 40°, torso height, head tube angle etc and use actual trigonometry and it will be more clear.
Quoted: 392 Post(s)
Liked 49 Times
My squatting form has been called 'impeccable' by observers. I know very well how many inches my hoo hoo needs to move rearward to keep me from falling on my face and it is much more than a couple or three inches! Maybe a crank forward design has that kind of rearward displacement of the saddle but nothing commercially available in a drop handlebar design does. Considerable weight on the hands and arms is thus an unavoidable trade-off to obtain the aerodynamic efficiency that makes commuting and sport cycling enjoyable and practical. <snipped the rest to avoid a very long quote>
Agreed, it is important to maintain core strength as we age. But I don't think riding a road bike is the biggest demand on our core strength, assuming the person is normally active. If all we do is lay in bed when we're not riding the bike, then maybe it is.
Quoted: 482 Post(s)
Liked 151 Times
This is turning into a pointless argument as you are not willing to show me how raising the bar really helps (assuming it is weight too far forward), so I have said my piece and stand by what I posted - that if there is too much pressure on your hands, it is probably because your COG is to forward, and the first thing you should try is to make sure you are balanced and set your seat back if you are not.
I think jyi and I are in agreement here.
Bikes: Nashbar Road
Liked 341 Times
Those factors have only a second order effect and don't change things.
COG forward is just another way of saying leaning forward. The weight is relative to the seat and bar (not the feet), dependent on total torso weight (and including arms weight), torso angle and how much if any is reduced by pedal pressure. That's it for weight. That's enough for anyone to reason through these issues.
There can also be a small amount of horizontal pressure, especially if there is a fit problem. I believe that moving the seat back, or perhaps tilting up, can sometimes alleviate that. That's really where "bike fit" comes into play - all this about crouching over the seat and sliding back in your easy chair is just misapplied analogy.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,181 Times
Yes. The saddle is pointed way down. You mentioned trying different positions including level and up but is your "level" have the nose even with the center of the saddle (part you mostly sit on) or the back of the saddle. "Level" for most saddles is the nose to about the middle. You have all the classic symptoms of a saddle tilted forward.
Bikes: 2014 Giant Defy 1 Endurance Road
Quoted: 7 Post(s)
Bikes: Defy 1
This is my reply, only my opinion.
I started getting a little pressure in my hands that wasn't there in my old Schwinn.
The actual fix was me reminding myself to position my weight through my tail bone. Stop letting your upper body weight against your hands into the handlebar. In other words balance yourself on the saddle and relax.
Your neck. Just don't look all the way out in front so often. Relax your neck and only look a little ahead, but look further out time to time.
Example: I look out 200 yards, relax and only look out about 40 yrds. I go that 40 yrds, then look out to 200 yrds again, relax go 40 yrds, then look out again. I'm not constantly bending my upper neck to look as far as I can all the time.
Good luck...
Good luck...
Bikes: Nashbar Road
Liked 341 Times
That must be an optical illusion created by the angle of the camera with respect to the bicycle. I leveled the saddle by placing a flat board on top of the saddle - a board big enough to completely cover the saddle. The board was resting on the highest spots at the front and at the rear of the saddle. I then placed a digital level on the saddle. I then set the tilt to 0.0°.
Quoted: 7 Post(s)
. I know it isn't a scientific measurement technique, but, humor me. When you have your elbow against the nose of the saddle, do your fingers reach the bars? They should. Just reaching is good. A little bit of overlap isn't terrible at your age. Again, I can say that because I am older than you. FWIW
H
H
Bikes: Defy 1
Did you purchase your bike from Middletown cycle and fitness?
If not, call them - they are good people that could possibly help. Giant Dealer
I have your same bike, but I have the stock seat.
What I listed above is what works for me, I'm 49 and have only been riding for a few months.
My 1982 Schwinn felt great. When I was actually fit to the Defy 1 - everything felt different for a few days, but all as settled in well for me.
I will be replacing the seat by mid September. I need a more comfortable seat, but the current seat isn't killing me. Hopefully by September - I will be a little lighter as well.
Liked 745 Times
In the center photo there are viertical lines that are reasonably close to vertical in the photo. There have been worse photos submitted for evaluation purposes. That said. I agree, and said as much earlier, that the saddle is not level. I don't really care about the care that was taken in measuring level. And neither does the riders butt. I have two saddles that are constructed in such a way that I have to tilt the nose of the saddle rather steeply upward to achieve a level surface at the rear section of the saddle where actual contact is made. On such a saddle there will be perineal pressure if the saddle is too far rearward leading to a constant low level tractive force being generated by the arms as they strive to pull the body forward to a more comfortable 'reach' to the bars. That's really what this thread comes down to: a saddle that is not quite level and a rider that has not built up enough mileage to normalize some of the discomfort that comes from riding modern bicycles.
I've heard it said a number of places that a Bumblebee cannot fly. They have too much mass to wing surface, and their power to weight ratio produces a negative coefficient. None of this theory affects the bees themselves and I see them occasionally as they visit flowers near my home in the summer. Maybe I shouldn't be using (vertical) stem extenders to raise my bars when I want less weight on my hands. The theory says that this does not work. It has worked well in practice, however. I employ the technique on a couple of bikes. FWIW.
KOPS is not an absolute, we've agreed on that but I think we can make suome rules about KOPS that are supported by the bicycle industry if not by theorists and fit experts who are peripheral to the design process. I think it is safe to say that if one intends to spin high rpm at the crank then a position at or even slightly forward of KOPS facilitates the rapid motions of the lower leg as they spin up to 120rpm and beyond. On a cruiser where 60rpm might be a maximal output a position considerably rearward of KOPS as much as 2" and more (think crank forward) behind KOPS works well for this purpose. Track and time trial bicycles will always have steep seat tubes to get the rider forward, zero setback seatposts also aid this. The usual 73* seat tube and 25mm set-back seatpost puts most riders a tad behind KOPS for the ~80rpm that most general purpose riding entails.
H
H
Liked 745 Times
I'll check this when I get home, but looking at the geometry table for the bike, the top tube and stem total 26", and my elbow to fingertip length is 20". The seat is four or five inches in front of the post, but that still makes the nose to handlebar length 21 or 22". My fingertips are probably going to come up an inch or two short of the bar, if not more.
H
Bikes: Nashbar Road
Liked 341 Times
@skycyclepilot That's free and easy to try and makes sense, why not bring the nose up two or three degrees and try it for a ride changing nothing else?
Quoted: 7 Post(s)
The top tube is 575mm, according to the Giant website. The stem is 110mm. 575 + 110 = 685mm. 685 / 25.4 = 26.97". Subtract a few inches for the nose to post distance, and perhaps a little because angles are involved, but I'll be surprised if all that gets me close to 20". Someone else suspected, in another post, that the bike may border on being too big for me. I'm beginning to suspect the same. I'll check the arm thing tomorrow.
Quoted: 83 Post(s)
This is where I disagree. You can't apply a force to the pedal without an equal and opposite force acting on the rider's torso. Treating this as a simple "beam supported at two points" statics problem is an over-simplification that is not valid for any riding scenario except coasting.
