Cold weather clothing selection guide
Rim crusher
I posted this a few years back, but thought I'd do it again. Some of you may find it of use. It is tried and true (for me, your cold tolerance may be different than mine, your clothing choices may be different too). I generally am a bit chilly starting out in the cooler temps, but have a light sweat going by the time I arrive to work, 13 miles later.
60F and up Shorts, jersey, socks, riding gloves, glasses
55-60F Add arm warmers (or long sleeve jersey)
50-55F Add lycra tights, Tshirt as base layer
45-50F Add wind vest and long fingered gloves
40-45 Replace riding socks with wool socks, add 2nd layer (or warmer) long fingered gloves
32-40 Add 2nd layer of socks, add 2nd layer of tights, add 2nd layer of long sleeves, add head band.
Above temps assume no heating from sun, no cooling from wind, and no rain.
Adjust accordingly for those conditions.
35-40.. I have not tried a 2nd layer of tights. Have to give that a try.. What can't be resolved in the cold air going into the nostrils. Don't like that. I've tried scarves, cycling baklava; but just don't like the runny frozen mess just below the nose.. The nose / mouth area is where I'd find the right protective clothing to make for a better ride...../ 35 is my mimimum temperature. Good in that , here 35 is just about as cold as it gets. Still....
Pray for the Dead and Fight like Hell for the Living
^ Since January 1, 2012
Maybe I'm off but I don't like your temperature ranges... I'd be a sweat bag in no time at some of your 50ish suggestions. My arm warmers don't come on until the 40s. It comes down to depending on what kind of metabolism you have and what kind of ride you're preparing for. Good list of clothing options though... and a resonable progression. I just disagree with the temperature ranges chosen.
The problem mentioned above is due to the fact that everyone is different. A T shirt as a base layer?
There are quite a few options listed in the winter forum. Especially considering that the temps listed here are late summer and early fall temps for denver. Perhaps I will post a list when I have time but I tend to wing it each year.
As mentioned above, a T-shirt in winter as a base is a poor idea.
For base layers I prefer powerdry material made by maiden mills.
I use either jerseys or a compression base layer from nike or adidas. There is not one single cotton based item on my person especially in winter. Riding at 5F with something that will collect sweat and then freeze is an amazingly bad idea.
Merino Wool as a base layer, if not as a second layer as well.
Regulates body temps the best.
I have a lightweight tank and one or two t-shirts.
Also have two lightweight merino wool jerseys as well as a heavier old school wool jersey.
No stink and you don't have to wash any of it for days at a time.
Once the temps drop into the 40's I'll add something to my legs like tights or swooshy running pants to block the wind. Heavier gloves and a light cycling rain jacket also help. I'm usually good into the mid to high 30's. Doesn't get much colder than that around here.
my nose itches
Bikes: 1986 Specialized Stumpjumper, 2013 Redline Conquest Disc
Is baklava a popular cycling dessert for the winter?
Bikes: Fugi Allegro (retired, cracked frame), Sears 3-Speed, Trek 720, Raliegh Technium E-bike
I would agree with JMRobertson. But it is a good list, i keep a similar list taped up in my garage. I always wear my reflective vest whenever I commute. The problem now is the difference in temp leaving at 6:30 AM at 50 and then returning at 4 pm at 80 degrees. I am already going with a thin pair of gloves under my fingerless gloves, two layers up top, and two pair of socks. On the way home all that stuff is packed away, or left to pile up at work.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
Most of the fall/winter/spring up here is rainy and cold, so I go for wool up top, and insulated fabrics on the bottom. I'll be getting my PI Gavia Plus tights this week (insulated, water/wind proof) and I'll bust out the long sleeve wool jersey when it really starts getting ugly out.
Bikes: 1 road, 1 Urban Assault Vehicle
I would be too, and at some of the lower ranges as well. I understand that we're supposed to cover the knees when it goes below 60, at least some people say so, but it just seems way too warm to me.
And it seems just way too *cold* to me . I'll usually swap to pants somewhere in the 60-70F range. But I'm always cold.
Beer is delicious!
I think it all depends on what you're acclimated to. I'm in Minnesota and I wear shorts when it's 45 degrees Farenheit or warmer. I also wear short sleeves once it hits the upper 50's. I've been doing this for years and as far as I know, I've suffered no ill consequences.
My knees can handle 40F without covering. However, I fear what could happen and keeping my legs warm makes them seem to work better. At the very least more comfortable.
65F still seems a bit warm to put leg warmers on. I am more around 60F.
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
I don't go to a second pair of tights, but do sometimes wear a pair of ski pants over the tights at single digit temps.
I wear a thinsulite cap which covers my ears in the winter, and my winter cycling helmet is a hockey helmet - better warmth, and easier to mount a light to than a bicycle helmet. When really cold, a thin balaclava.
Another problem in the winter is having your water bottle freeze - filling a polar insulated bottle with hot water helps, also putting it in the bottle cage upside down (close the spout) so that ice forms on the bottom first helps. Otherwise the spout freezes and even if the water inside is not frozen, you can't get it out. I have stopped at coffee houses on my commute in, and asked them to steam open the spout of the bottle with their steamer thingy - that works too
I probably underdress my core for the temp - it is often F****ing cold for the first couple miles in the morning, but once I start working, I warm right up. My commute to work starts with a 1 1/2 mile downhill, which is really unfortunate since it is hard to get warm until I hit the bottom of the valley and start up the other side. Personally I would rather be a bit cold than over-hot.
Trans-Urban Velocommando
Bikes: 06 Trek 1200 - 98 DB Outlook - 99 DB Sorrento
The best advice I can give is for each person to figure it out scientifically. I just tried stuff last year and logged the results. Take notes of the temperature (and other conditions such as snow, light rain, freezing fog, etc). Head too hot! Eyeballs frozen open! Core fine but legs are freezing! Fingers numb!
I numbered my successes and failures on a scale of 1 (just about perfect) to 5 (what was I thinking?!) and then sorted them by success and temperature so I can take a glance at the top of the chart, find something resembling the current conditions, then dress like I did in the past.
The first few chilly days are the hardest. I have a tendency to over-dress. This chart keeps me in check, but it likely only works for me. You have to do one for yourself to really get the hang of cold-weather clothing.
You gonna eat that?
I guess I'm doing it wrong. I just put on a sweatshirt, maybe some jeans, maybe a windbreaker.
I have yet to buy any bicycle-specific clothing.
Red light runner
Bikes: Seven Sola
Never listed this stuff, but it sounds right for my cool, dry winters.
50F and up Shorts, jersey, socks, riding gloves, glasses
45F - 50F => Silk gloves under my riding gloves, add leggings
40F - 45F => Arm Warmers
30F - 40F => Add a jacket & winter gloves (my hands get cold quickly)
20F - 30F => replace leggings with full bottoms
0F - 20F => REI water socks, balaclava, long sleeve jersey and a sock stuffed in my crotch (gotta keep the boys warm)
Still on two wheels!
The problem I have, especially this time of the year in Tennessee, is, the ride in is usually 45-55 and the ride home is 85! I also ride to work very early in the morning, 3:30am and it is usually very damp to go along with the cool. I have learned that 50 with the sun shinning on black tights and low humidity, is different than 50F in the black, damp mornings here.
My knees like to be warm, so it's knee warmers below 70.
Below about 60 the arm warmers come out, followed by a wind jacket down into the mid 40s.
If I am looking at below 45 the whole ride I go to the wind front tights and start adding layers accordingly. No cotton for me either, and I have found wool socks are the bomb for my feet in the cold weather. I also use a balaclava and ear warmers in the very cold temps.
Has anyone ever used ski goggles while on the bike?
There's time now
Quoted: 4096 Post(s)
Liked 164 Times
I use 3/4's down to the 20's, with a ski jacket and a fleece or sweater up top, preferably with pit zips. I purchased gore tex pants with zip-off capability that should rock come snow however.
Do those of you using arm and knee warmers find that they slide down? I purchased some leg warmers a few years back (PI) and could not stand them.
So Cal North County Rider
Bikes: 2008 Giant OCR2
I think it all depends on where you are from and what you are accustomed too.
In San Diego (north county) Pretty much no matter what day it is I am in either long or short sleeve wicking shirts and bike shorts. But during the Months between Oct-March it can drop from a nice 80f to a cool 40f. Most of you would agree that 40f isn't that bad but when there is a 40 deg drop its pretty significant. I basically will just keep a pair of gloves, tights and a Nylon jacket or Lycra/Fleece shirt with me to layer on top of things. Also keep a beenie under the helmet but I am looking for a better option then that for this year.
Length and intensity of commute can factor a lot into what gets worn at a certain temperature. I can get away with wearing a lot less for my relatively short commute than I could for a longer ride. For instance, down to about 50F, I wear only shorts and a short sleeve shirt. I'd wear tights and long sleeves at those temps for a longer ride though. My commute is hilly with quite a few stop signs which means I've never going fast for very long but I'm working hard most of the time. This keeps me warm as I can keep the intensity up the whole time.
My biggest challenge is not overdressing when it really cold (15F or less for my body). When I start out, I'm ready to just pull over and stop because I'm so cold but I'm usually soaked up top by the time I get to work. The last 0.75 mile hill before work always ruins it for me. I just get too warm while climbing it.
cyclist
Bikes: road bike, mountain bike, touring bike
Quoted: 19 Post(s)
Has anybody else noticed the regional variations here. The OP is from raleigh, nc and the people who aggree with the temp range is from the south. The people who dissagree are from northern states . When I lived in Durham, nc, I may have agreed. Now in boston, the list is way to warm.
I tend to go in this order. Arm warmers, knee warmers, jacket, glove liners and warm socks (I normaly go sockless), wind pants, shoe covers and a second wind jacket and a fleece cap under the helmet.
A trick I learned last year was to cover most the vents on your helmet with packing tape.
Scott
Scott
