Anyone tried the new Vittoria G2.0?
Old 03-27-19, 08:46 PM
smashndash
Quoted: 645 Post(s)
Liked 197 Times in 147 Posts
The claims in numbers are: “the new Graphene 2.0 compound provides 40% reduced rolling resistance, 30% improved grip and 40% improved durability [over the G1.0 tires?].” - road.cc. Also double the mileage.
That combined with with the fact that Vittoria is one of the only companies to use 2 or more compounds, plus tubeless compatibility should mean that the new Corsa are one of, if not the, best race clincher on the market.
Are these claims even remotely true? I can’t find any information about them, and the tires are only available through the official Vittoria site.
Heres the graphic:
smashndash is offline
Old 03-28-19, 05:10 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3390 Post(s)
Liked 648 Times in 445 Posts
Nope, haven't tried. Are these now on the shelves at the LBS? Found a pic of the new packaging, but haven't seen these (except an ebay seller) specified at the usual-suspect online shops -- i'm assuming they're trying to clear the 1.0 versions.
Sy Reene is offline
Old 03-28-19, 01:32 PM
floridamtb
floridamtb's Avatar
Bikes: Trek Emonda SL6, Trek Madone 4.5, Trek X-Caliber
Quoted: 95 Post(s)
Liked 8 Times in 2 Posts
I tried them, hard to fit at first, measured with digital calipers and they are true to size. I got more flats than I did with Contis so I dumped them and went back. What I saved over Contis I more than paid out on tubes and CO2
floridamtb is offline
Old 03-28-19, 08:01 PM
smashndash
Quoted: 645 Post(s)
I think we’re talking about different tires here. The new Vittoria G2.0s barely came out a month ago and I’m certain you can’t get them for under $160 a pair - not much to save over the GP5k. I know the vittorias aren’t known for their puncture protection. I’m mainly asking about how good the brand new 2.0s are.
Old 03-29-19, 06:35 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Curiously, this linked article indicates the same extra mileage as you have, though 2 paragraphs or so later, it says the opposite somehow holds true for the off-road versions of the same tires?
https://cyclingtips.com/2019/02/vitt...ls-tyres-news/
Sy Reene is offline
Old 04-01-19, 03:38 PM
63rickert
Quoted: 887 Post(s)
Liked 214 Times in 162 Posts
I have a set of team issue tubulars which had the new compound a while back. Cheap at the swap because there was a mixup and they were too fat for the team bikes. The grip is phenomenal. Faster? Maybe. Any good tubular is fast and these are silk. Durability? Can't tell you yet. The grip is noticeable at times when you would not expect anything to be happening but it is there. When pushed even a little just lots of security.
63rickert is offline
Old 04-01-19, 04:07 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2696 Post(s)
Liked 1,131 Times in 775 Posts
I haven't ridden the G 2.0s yet. This will be my third season on G+. I love 'em. I always found that tires were compromises that the components of, if well done, added up to certain number, never higher. In other words, you could make, say the grip 20% better but that improvement came out of both the rolling resistance and tendency to pick up glass and debris. Vittorias were, as a rule, better on grip than Continentals but worse on rolling, wear and cuts. Panaracer Paselas were the compromise where the components are nearly equal. Not tops at anything but not bad anywhere either. (Cost is one of those components.)
For me, the G+ tires are a big step up. A higher number. A game changer. You can still argue that this tire has better this or better that but the sum of those G+ tires is higher. (It won't be for long. All the major players will get on board and we all will win. The G+ aren't magic. I still get flats. Tiny radial wires get them, more so as the miles pile on. But compared to the Open Paves, wear is far better, they pick up a lot less debris and roll better in exchange for being slightly inferior in the wet (to an excellent wet road tire). Grip much better and roll the same as the Open Corsas.
I like that the G 2.0s I saw on the Vittoria websire use the same ribbed tread. Vittoria has brought back the tread I consider the best ever all 'rounder (and have for most of 50 years though I hadn't seen it the past 25). Fast, great cornering and is the best tread out there for climbing out of ruts and cracks or back onto the pavement. A full on racing tread with an agenda of keeping you upright. Wet or dry. In the real world. Combining that with the compound that both grips and wears well? My view - doesn't get much better.
Ben
79pmooney is offline
Old 04-01-19, 04:17 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Heres the graphic:
Ahh, that graph, I wish! Telling me I can go 3 times as fast using the G2.0s. Pretty soon we are going to see the Tour de France done at 40, 50 mph! G 2.0 is the real drug. EPO was just a plaything.
Old 04-02-19, 12:33 PM
bikebreak
Quoted: 129 Post(s)
Ben
same story with the tubular, the tubular G+ seem faster and more durable than old corsa but I notice less grip than the old Pave. even in dry.
I have killed a G+ tire by skid, making an emergency stop on a fast downhill and locking up the wheel. (don't assume a car will not suddenly decide to stop and turn left just because they are not signaling...)
other than that they last a long time, 25mm corsa G in back and 23mm Corsa Speed front (200 gram)
bikebreak is offline
Old 04-02-19, 01:34 PM
Peter2290
Bikes: Cannondale Supersix Evo Hi-MOD
Quoted: 19 Post(s)
I know you're being sarcastic, but of course the graph means nothing without a scale on the y-axis. It also doesn't mean anything since it's talking about the graphene 2.0 compound that's in the rubber and not the actual tire itself.
Just the usual misleading marketing for brand new tech.
Peter2290 is offline
Old 04-02-19, 06:07 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Am I mistaken, but I think the successor to the Pave is the Corsa Control G+, not the standard Corsa?
Sy Reene is offline
Old 04-02-19, 06:31 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
That's the way I saw it. I'll probably stick with the straight Corsas as the grip is quite decent and I will not be racing in the rain, The older Corsa scared me in the wet and I wouldn't ride them, just the Paves (and Paselas - a real step down in performance and a real step up in not picking up debris). The Paselas now rarely see my good bikes.
Ben
Old 04-02-19, 11:23 PM
HTupolev
Quoted: 1633 Post(s)
Liked 676 Times in 344 Posts
Ben
Which Pasela variety were you using? I've been using the non-PT ones on a vintage bike because it has 27" wheels, and I've actually been pleasantly surprised by their performance.
I avoided the blue-label PT Paselas because Panaracer doesn't seem to do half-measures with puncture protection layers, and so I was worried that they'd be very slow. I had a friend using T-Servs on his gravel bike for a while... we were equals in a road group at the time, but when we were both on our gravel bikes (mine using 53mm Rat Trap Pass ELs) he had a hard time even clinging to my draft when I was cruising along.
HTupolev is offline
Old 04-03-19, 01:27 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
I use wired on (except the big 37c which only comes in folding). The cheapest have served me well. I don't think I hvae ridden many PTs.
Ben
Old 04-04-19, 09:54 AM
bikebreak
Quoted: 129 Post(s)
Yes, but when I bought mine the Control was not out yet. caveat is the Corsa Control is much much heavier than the old Pave, especially in tubular.
The Corsa G is only a bit heaver than the old Corsa, and similar in clincher
Old 04-04-19, 05:57 PM
f4rrest
Farmer tan
f4rrest's Avatar
Bikes: Allez, SuperSix Evo
Quoted: 2870 Post(s)
Liked 24 Times in 20 Posts
Heres the graphic:
Oh sure, that's legit.
No graph axis.
Blue bars are all exactly the same.
Orange bars are all exactly the same.
f4rrest is offline
Old 04-08-19, 01:46 PM
drewguy
Bikes: Trek Domane 4.3
Quoted: 180 Post(s)
Liked 26 Times in 18 Posts
Been trying to find the Rubino G+ Pro tires . . . seem out of stock (except limited sizes) . . . I guess the turnover to a new product explains that?
drewguy is offline
Old 04-08-19, 02:05 PM
ddub
Quoted: 99 Post(s)
Alexander Kristoff (professional) has used the Graphene 2.0's tubeless for the last two races on the cobbles. No problems reported and he likes the feel over the tubulars, Or so the story says. Cycling News.
ddub is offline
Old 04-08-19, 02:42 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6833 Post(s)
Liked 690 Times in 438 Posts
If the 1.0 version is any indication then the 2.0 Rubino Speed will be 20% lighter, have less rolling resistance, more grip, get less flats and cost half as much as the 2.0 Corsa.
The Rubino Speed is also not on ENVE's list of banned tires.
-Tim-
TimothyH is offline
Old 05-21-19, 11:32 PM
smashndash
Quoted: 645 Post(s)
So I have a pair of G2.0 TLRs in hand, but have yet to burn through my stockpile of tires, and don't have a scale either, so I can't really post anything useful about them yet. I'll definitely post something once I have em on.
In other news: https://www.bicyclerollingresistance...orsa-graphene2
Looks like something is seriously wrong. Not sure if this has anything to do with the ENVE debacle, but the 2.0 clincher Jarno tested was slightly beefier than the G+ he tested. It also tested significantly slower than the G+ and even the older CX. The rolling resistance really diverges at lower pressures, which indicates that the tire isn't very supple at all. Eagerly awaiting the Speed 2.0 and the TLR tests.
EDIT: Compared to the Pirelli P Zeros I'm running now (an excellent tire, by the way), the 2.0 clincher is 50g heavier and 1W slower (per tire, I presume?) at 80psi, which is the end of the spectrum I'm interested in. In other words, unless these tires stick to asphalt like velcro, it could spell trouble. Especially considering Vittoria's earth-shaking marketing claims.
Old 05-21-19, 11:39 PM
smashndash
Quoted: 645 Post(s)
https://www.thegeekycyclist.com/prod...oria-corsa-g2/
Here's a review that's nearly devoid of usable information about the tire.
Old 05-22-19, 05:44 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2325 Post(s)
Liked 373 Times in 235 Posts
Well...a week after your post....he lost Paris-Roubaix because of tire problems, and regretted his choice:
Kristoff regrets 'big risk' after using tubeless tyres in Paris-Roubaix | Cyclingnews.com
No graph axis.
Classic marketing....just like you see for vitamin supplement commercials
Of course...in that case, the company selling that snakeoil got a lawsuit for their shenanigans. They still use that graphic though, and the woo is still up for sale.
Marcus_Ti is offline
Old 05-22-19, 06:52 AM
asgelle
Quoted: 735 Post(s)
Liked 228 Times in 141 Posts
And everyone who understands what went on knows the problem had nothing to do with the particular tire or tubeless vs. clincher, vs. tubular. His tires were simply too narrow for the conditions given his size. He would have had the same problems with any 25 mm tire.
asgelle is offline
Old 05-22-19, 07:21 AM
waters60
waters60's Avatar
Quoted: 120 Post(s)
Liked 60 Times in 32 Posts
I bought a pair of Corsa G+ tubulars, deciding to “ upgrade “ from Rallys. Bought from Probikekit, rear one had a valve stem leak in less than 200 miles. Took them both off and put the Rallys back on, as I was not about to waste more money on another Corsa. 20 + years on Rallys and never a valve stem leak. I will be trying Veloflex Vlanderen next. Crossing my fingers!
waters60 is offline
Old 05-22-19, 07:53 AM
smashndash
Quoted: 645 Post(s)
Perhaps more pertinently, he used what is known to be an extremely delicate TT tire (not even crit race, due to its lack of grip) on one of the most demanding courses imaginable. Vittoria makes the Corsa, which is an allrounder, and the Corsa Control, which is specifically marketed towards cobbles and such.
