Max Tire Pressure Label (700 x 32)
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
Hello All,
I have a quick question about tire pressure for my road bike (Trek Domane SL 5). The tire is the Bontrager R1 700 x 32 Hard-Case Lite.
If I remember correctly, the LBS inflated it to 90 and 95 psi (front and back). I weigh 190 lbs and live at 1200 ft MSL and the temperature is currently 60 deg F.
I went to air it up today and noticed that the tire is labeled with a "Max Air Pressure of 70 psi."
What should I air it up to?
Thanks!
Thanks!
Likes For Racing Dan:
Quoted: 18883 Post(s)
Liked 10,646 Times
Rule of thumb (which isn't always true) is that you can ignore the max pressure on the tire, but should pay attention to the max pressure of the rim.
But for a 32 mm and a not super heavy rider, experiment in the 50-60 psi range. More if you ride in a velodrome, on glass, or some other perfectly smooth surface, less on rough gravel. Lower pressures on wider tires (wider compared to the 23 to 25 mm many racing bikes use) are much more comfortable. Wider tires aren't meant for high pressure.
Likes For Seattle Forrest:
Quoted: 218 Post(s)
Liked 102 Times
WTF... Looked it up online... One site recommends at my weight to go to 80 psi. https://www.cyclingweekly.com/news/p...ressure-270668
I called the LBS where I bought it and they said to go to 90.
I called another LBS and they said to stick to the max of 70.
The tire specs on the Trek website for this tire say max of 50! https://www.trekbikes.com/us/en_US/e...-tire/p/25927/
This seems like a huge percentage of variation, but I'm not sure as I'm new to this.
For today's ride, I'll stick to 70 to be safe.
Quoted: 218 Post(s)
Liked 102 Times
Likes For Metallifan33:
Quoted: 20810 Post(s)
Liked 9,456 Times
I'm in your weight range and would run 30mm tires at 65-70psi, so 32s could run a little lower.
Likes For WhyFi:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Hello All,
Thanks!
Thanks!
Zipp and Silca both have up to date apps that let you plug in your weight, tire specs, and type of riding for recommendations. Those are great places to start. Zipp's app is Tyre Wiz, and Silca's app is off their main page.
Is that was my wheelset, I'd run them at 70, then drop the pressure in 2-4 lb increments til I started bottoming out then move up one notch. You can probably run your tires at 60 or so with no problems.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
tubed or tubeless might be a valid datapoint?
Likes For asgelle:
Quoted: 5224 Post(s)
Liked 3,581 Times
if it were me & I was riding good quality pavement, I'd go max rear, 10 psi less up front. if I was riding gravel, depending on the quality of the surface I might go 60 rear & 50 front
Using a popular bike tire pressure calculater I get 59 psi front and 72 psi rear for 225 lbs weight of rider and bike. I would use the max recommend 70 psi rear and 60 psi front. Of course there is a safety margin with the max recommend pressure. You just got lucky it didn't blow up at 95psi.
There is no need to over inflate your tires. It may be that your tires have stiffer sidewalls and do not even require the pressure indicated with the calculater. Over inflated tires are not only dangerous, but can actually slow you down on less then perfect roads as well as offering a brutal ride. Significantly under inflated tires can lead to pinch flats, can increase rolling resistance, and are unsafe too as control is compromised.
Likes For xroadcharlie:
Advocatus Diaboli
Liked 1,531 Times
On the high end of pressures, running a tube seemingly allows 15% higher PSI inflation while remaining in safe limit (subject to the actual tire and rim's ratings of course). See linked article near the end (sentence above their inflation charts) of the linked article below. Unclear though if they're referring to specifically running tubes in a TLR tire.
That said, the OP's tire I believe is for running with tubes only so probably a moot point.
https://engineerstalk.mavic.com/en/t...ght-rim-width/
Quoted: 4717 Post(s)
Liked 1,882 Times
Do you ever ride, or just read about it?
The article you linked is irrelevant to the OP's question.
Advocatus Diaboli
Liked 1,531 Times
I said it was moot since I hadn't originally realized the OP's tires were tubed only. To anyone else, I thought it an interesting factoid that from safety perspective you can 15% more pressure if running tubes than if running TL.
Liked 1,882 Times
Not really, but you frequently answer questions with a link to something you read, instead of talking about your actual experience on the subject.
I ride in the same area as the OP, and told him what actually works well for those conditions.
70psi is the max inflation for his tires, but it's 10-15% higher than what he needs,
Likes For noodle soup:
Advocatus Diaboli
Liked 1,531 Times
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Note that the OP is asking about a very specific model of tire. That specific model Bontrager tire as compared to a "standard or average" road bike tires is specifically designed for very low pressure. The maximum recommended is 70 PSI and he should not exceed that. For ultimate performance combined with maximum ride comfort on typical asphalt roads for all but heavy riders should be about 50-60.
Likes For BengalCat:
Quoted: 741 Post(s)
Liked 412 Times
It might be due to the surface, but I regularly run 23mm GP4000 on the velodrome at 140-160. I weight 235lbs. I don’t remember max pressure for the tire, but I think it is lower than the pressure I use. If you don’t get a pinch flat or the tire doesn’t blow up, you know you haven’t reached the limit 😂😂
Liked 1,882 Times
For the OP running 32mm with tubes, there's no reason to use anywhere near the max inflation of 70psi. 55-60psi should work well without risking a pinch flat.
@Metallifan33 In this area you should seriously consider going tubeless. Everything that grows here has a thorn, and unless you run highly puncture resistant tires(that ride like rocks) you'll be fixing punctures regularly.
