Sheldon Brown's fixed cup removal method
Quoted: 1136 Post(s)
Liked 650 Times
I thought this one would never come out. Lightrace fixed cup installed in the frame for 70 years. And it's French thread. Grabbing the flats in the vise didn't work. The flats would deform slightly and the frame would jump out of the vise.
So on to Sheldon's method. 1/2" bolt, nut, and washers. Socket wrench with a 16" handle on the non-driveside. Top tube under the armpit. Pulled up and it came loose with only moderate effort. The power of friction!
Likes For TenGrainBread:
Quoted: 4511 Post(s)
Liked 6,382 Times
This is why I ALWAYS R+R the DS cup with any and all BB service.
All new acquisitions get a service just for this reason.
Glad you got it out with all your appendages intact.
Likes For merziac:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
I've had to do a few things for this to work consistently, like backing-off the nut and re-lubing the bolt threads before trying again. It can be rather difficult to separate the assembly after the cup comes loose.
Quoted: 1303 Post(s)
Liked 1,911 Times
Sheldon's method again reminds me that long ago there was a Var tool that used the same principle to remove the fixed cup. A friend and bike shop owner here in town lamented to me that the tool could not be found anywhere and she wanted another one. Maybe it is time for me to get some parts and go do some welding to make a new tool for her. Thanks for the reminder. Looks like another project for the Stay In Place order I'm under. Thanks, MH
Quoted: 3810 Post(s)
Liked 6,699 Times
I have a Stein fixed-cup wrench clamp:
https://www.steintool.com/portfolio-...-wrench-clamp/
i picked it up cheap on eBay years ago from a seller who didn’t know what it was. It allows me to bang on the fixed-cup tool with a hammer or to use a long lever on the end of the wrench. Very effective.
Liked 6,382 Times
It's all about leverage and the control of it.
This has never failed or damaged any parts, tools, frames or flesh.
Liked 1,911 Times
Merziac,
I sure hope that is an Italian cup you are prying on! yikes! Smiles, MH
Liked 6,382 Times
I have done this on purpose several times on stubborn ones just to crack them loose. Some of them will actually crack loose easier when going the wrong way to start with.
Like I said, this method never fails or hurts anything, ever.
I just had to cobble something together for this operation on 2 Italian BBs today. I used a long, 1/2 inch bolt, with the head and some fender washers on the NDS, and a 4 X 4 piece of MDf I had laying around with a Tee nut in it. I put a 12" crescent wrench on the flats, tightened the bolt with a ratchet, and gently (or using a hammer as the case may be) teased the fixed cup loose. I was too busy to take pictures, so you are going to have to imagine it! Not pretty, but it sure did work, and one of those BBs was tight, perhaps Locktited! It is days like this that i wish i had a professional Park repair stand, the home version always wants to move away, or fold up when i torque on something.
To make one I think you'd need a lathe and a milling machine, not a welder.
The Sheldon method seems a little crude to me, but it obviously works. The above tools don't work the same way, since friction isn't used to grab the cup. VAR never made a friction tool that I'd ever heard of, but of course it's possible I missed it.
* Maybe there was a Hozan knockoff also. Can't remember.
Likes For Salamandrine:
Quoted: 1949 Post(s)
Liked 2,010 Times
I used the Sheldon Brown method on a very stubborn Italian cup. Used a long 1/2 inch drive socket and a cheater bar. Very scary. THEN I had to take the cup with attached Sheldon apparatus to the auto shop guys at school to rescue the cup. It was too tight for my shop to handle.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
That pic was just a setup pic, aside from that it doesn't matter one wit, if by chance you are going the wrong way it simply cracks loose then you reverse direction and spin it right off, easy, peasy.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Zeus did have a professional-grade friction-type fixed cup tool; you can see it in the lower right of the case:
Others were also available:
Liked 6,382 Times
With the leverage of this method, there is never a need for jerking or hammering, no collateral damage from shock and awe, just slow, steady brute force.
Liked 6,382 Times
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
That ought to be an interesting parts list there...
Liked 6,382 Times
Both setups were sourced from things already on hand, the hole and sockets for spacers came for the NDS setup when someone asked about how to do that side.
Also have a thinwall pipe with a flattened end that fits the BB wrench for way more leverage than is ever needed.
Liked 1,911 Times
I don't recall that VAR had a friction-type fixed cup tool. They did have the VAR-30, but that uses a jaw to hold the cup. You don't have to crank the pieces together super-tight, just enough to keep the jaw in place:
The tool I am remembering was a two piece tool similar to the Zeus one pictured. It was black steel and threaded into each other, and only had two flats on each end. You wrenched the two pieces together sandwiching the bottom bracket cup in between them,and then turned the tool with a wrench on the flats of either end. Depending on the thread pattern you either turned the drive side or the non drive side to remove the cup. Smiles, MH
Edumacator
Liked 3,128 Times
I am still having a devil of a time removing a fixed cup, even with the hozan tool I have. I might try to tighten-loose method, but I have sprayed all sorts of crap and it has yet to budge. And yes, I am loosening in the correct direction...
Liked 1,911 Times
Dawg,
Help this old stoopid brother out, and tell him what you are working on. There are a few work around as have been discussed here. Sometime I have seen outer races that have been worn to the point that the metal from the cup is stretched into the bottom bracket shell. These are the worst offenders, and even break apart during removal. Then you have to cut the old bits out with a Dremel tool. Then chase the threads before any reconstruction can begin. It would help if a pic was posted. Smiles, MH
