Is it possible to put SPD-SL cleats on SPD MTB shoes?
My wife bought the Sidi Dragon 5 SRS MTB shoes yesterday, they were $250 instead of $450.
they have nice stiff carbon sole and carbon toe protection for gravel and MTB riding however they are SPD compatible.
My wife has 2 bikes and I have 3 bikes which have all Shimano SPD-SL pedals. What are my options here?
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Throw SPD MTB pedals on your wife's bikes? Changing pedals is a snap.
Likes For ridelikeaturtle:
had SPD pedals 20 years ago and haven’t followed the performance improvement in them
https://www.bicyclesquilicot.com/fr/...-noir-epded500
https://www.bicyclesquilicot.com/fr/...-noir-epdm540l
Likes For dr_max:
Quoted: 605 Post(s)
Liked 480 Times
I can't make a recommendation, though I can't imagine the tech has changed a lot.
I'm sure there are others who will see this post and chime in with experiences using MTB SPDs on a road bike, which I've never done. Weight differences, feel differences (cleat size, platform width, etc).
Quoted: 3242 Post(s)
Liked 2,087 Times
Basic pair of Shimano 520’s, $45.
Likes For Steve B.:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
I have xt spd pedals on one bie and spd sl ultegra on another both are great and it is seamless going from one to another.
Quoted: 4806 Post(s)
Liked 3,932 Times
Isn't there an adapter that can be used to use 2-bolt cleats on 2-bolt shoes? I seem to recall that it is a plate with the drillings for both patterns. Bolt it to the shoe and the cleat to it. (But it does add stack height. How much I do not know. I've never seen them. I have heard their were well made and worked well, if you could live with the stack. The name? No clue. Sorry.)
For some of us there is a huge difference between SPD cleats and SPD-SL (and all the LOOK systems and a few others) and that is the inability to lock out float. Float would have had me on knee replacements decades ago.
Lake used to make their less expensive shoes with the bolt patterns for both. (In those days I was cash strapped and the expensive ones were out of the question so I never looked.) Now it seems it is either/or. I have two pairs of their best of two years ago, 3-bolt, really nice leather, dual BOA and as comfortable, at least on my feet, as shoes can get. (Nice big toe box!) These shoes cost between the OP's wife's sale and retail, so not cheap but if my experience with LAKE hold true, they should hold up and be joys to wear most of the rest of my life. (Oh, the burgundy red goes wonderfully with my freshly painted Mooney and Hermes Red Saphir shoe polish 1) make that leather come alive and 2) is color perfect!)
Likes For 79pmooney:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
I believe there are adapters to put 2 bolt cleats on 3 holed shoes, but not vice-versa which is what the OP wants.
Agree best option is try SPD pedals. Plan B could be return the shoes for a model that takes 3 bolt cleats.
Likes For datlas:
Quoted: 222 Post(s)
Liked 304 Times
Looks like there is and adapter for this. While there are many, many to adapt a SPD cleat to a 3-bolt shoe, this one looks to go the other way around, what the OP needs. Looks like it's going to add significantly to the stack height.
https://www.amazon.com/CyclingDeal-C...c1df98776&th=1
Liked 3,932 Times
Now, if my shoes looked like that one and the adapter was sitting on the sole lugs and not the flat in the area around the SPD cleats, I wouldn't think twice about cutting or grinding the lugs until the adapter sat flat. (I use 1/4" plate s under my right cleats to make up a right leg that came from the factory short. I do exactly that to get the adapter plate to fit in some of my shoes.)
In addition to Shimano, you may be able to find Look X-Track SPD pedals as well. Their entry level models are often cheaper than Shimano 520s, and their higher end models have a bit of extra platform around the cleat that might add some stability to the pedal.
It may be an opportunity to try Time ATAC or Eggbeaters, too.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
I like these
Liked 3,932 Times
Liked 2,087 Times
Curiious why you would recommend a single sided entry pedal that is twice as expensive and more difficult to use then the 520/540 pedals that are dual sided entry and easier to use and cost half as much?
Likes For Steve B.:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 300 Times
+1. Have those Sidi shoes and use them with my several bikes, all of which have SPD compatible pedals of various designs. So much easier than juggling shoes among bikes having different pedal standards.
Likes For Rick_D:
Expired Member
Liked 5,437 Times
Yes, 2 bolt SPD cleats, compatible with OP's shoes. It's a road-ish single sided pedal. I found them to be more comfortable on longer rides than the traditional double sided SPDs. Shimano used to also have a less expensive version (A20?) but the 600 seems to be the only current model.
Likes For shelbyfv:
Liked 3,932 Times
Edit: "rock-solid boring" In my book: very good
Liked 2,087 Times
1) I made no comment at all on how good they are or why anyone would of should use them. 2) Many singe-sided pedals have far more pedal clearance cornering. Some of us like to optimize our opportunities to pedal without unpleasant strikes. (Pedals like these can also allow lower bottom bracketed bikes to be ridden strike free and take better advantage of the cornering edge of the lower center of gravity.) 3) Some shoes offer less than full support across their widths and benefit from a wider platform.
Likes For Steve B.:
Quoted: 682 Post(s)
Liked 453 Times
They have more of a platform/distributed support to reduce hotspots (although the Sidi soles probably do a good job of that anyway)
Personally I wouldn’t use mtb shoes and cleats on a road bike but plenty of people do.
Likes For choddo:
Quoted: 4415 Post(s)
Liked 4,867 Times
Likes For PeteHski:
I run the aforementioned M520 pedals on both of my main bikes and they are fantastic - great quality at a low price. Can't beat them, IMO.
Likes For The Chemist:
Quoted: 682 Post(s)
Liked 453 Times
I sure do. No disadvantages that I can see to using SPD shoes / pedals even on a road bike. With good shoes hot spots are not an issue, double sided entry, and they don't make you walk like a duck when you're off the bike. Plus the cleats are far more durable than SPD-SL cleats.
cleat covers are essential to walk on them more than a couple of yards though.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
While not popular among roadies, I switched to SPD pedals on my road bike years ago and haven't looked back. I always hated walking like a duck when wearing Look-style SPD SL style cleats and shoes. Modern carbon sole shoes are so stiff, one doesn't notice or feel what pedal is attached (i.e., no "hot spots"). The only downside to using SPD pedals is likely the weight of the shoe and pedal combination, but if one isn't racing, it doesn't matter.
Likes For PoorInRichfield:
Thanks everyone for the advices
really appreciated
Ordered some classic double sided SPD for $35 on sale online with free shipping. She did 3 spinning sessions on Wahoo and no foot pain whatsoever from the cleats since the carbon insole are really stiff.
She had terrible foot pain on my sidi T3 triathlon show using SPD-SL cleats 4 years ago before switching to Fizik shoes. Doesn’t seem to be a problem with the SPDs with those shoes.
really appreciated
Likes For dr_max:
Quoted: 1461 Post(s)
Liked 1,486 Times
I have carbon soled Sidi MTB shoes and use them with Shimano XT and XTR pedals on all of my bikes (road, CX, MTB).
I stopped using road specific shoes/pedals many years ago, finding no benefits vs running MTB shoes. There's a slight weight penalty I think, but beyond that I notice no difference in stiffness/support and enjoy being able to walk into coffee shops.
