Solution to world hunger? Not really but Accushift owners may have some hope
Couple of days ago I picked up very nice 1988 Bianchi Premio with SunTour Alpha 4050 RD. I used Suntour group as one of the leverage points for the lower price as I read many threads where very few people made SR Accushift stuff work with non-accushift freewheels. Anyway - freewheel appeared to be dead (cogs are fine, just need to take it apart as it seems to be stuck) and being impatient person I went and picked up sunrace 6 speed freewheel (same 14-28 spread) - https://www.mec.ca/product/5020-159/s...ce%2Bfreewheel.
I figured if I decide to keep the bike I will use friction mode anyway and I decide to sell - I will fix original freewheel by that time or source another one.
Cleaned up the bike, took another wheelset from my parts bin (same spacing - 126 but had originally 5 speed freewheel), put new sunrace freewheel on, used this chain (shortened by 2 links) - https://www.mec.ca/product/5006-382/k...?q=kmc%2Bchain and voila - indexed shifting works. It was skipping at first on two smallest cogs but it was matter of not enough tension in the cable. Once adjusted - works like a charm.
Would be curious to see if someone can test it with same (or other) accushift rd with known low mileage or NOS one. May be mine is just worn (although jockeys appear to be in good shape) and alone with tension this allows to index shift
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
Accushift 6sp is spaced the same as Shimano 6sp.
I've been using Accushift shifters with Accushift derailleurs and Shimano FWs. It works magically.
The Sunrace should be spaced the same as Shimano, which is spaced the same as Accushift.
The @4050 "should" be compatible with other Accushift shifers/derailleurs. The @3000 is NOT.
The Yellow Jersey site has Suntour's Accushift technical manual for download.
So, theoretically, you could replace your derailleur with a fancy pants Superbe Pro or Sprint and be in business.
FWIW, I'm using Command Shifters, XC Pro and XC Comp derailleurs and the Shimano FW that you get for $15 everywhere.
Commence to jigglin’ huh?!?!
