Single butted 2.0/1.8 spokes? Straight?
Quoted: 18373 Post(s)
Liked 4,508 Times
I'm ready to build a couple of new wheels. But, I need some rather short spokes.
According to the spoke calculator, I think it is 206/208mm
DT apparently doesn't sell short spokes.
I think Sapim may make them, but at least some of the retailers aren't listing them. Special order?
So, I suppose the question is whether there is a significant benefit of double butted over say 2.0/1.8 single butted (cut) spokes.
Quoted: 714 Post(s)
Liked 800 Times
DT Swiss does not make butted spokes that short. They do make straight gauge spokes that would work. Sapim Laser spokes come in short lengths, but you will probably need to get them from a BMX shop. Dans Comp has them listed, but you have to call them to order.
Constant tinkerer
I've seen undertensioned spokes break at the elbow as well as where the thread starts. This, combined with the fact that double butted spokes exist, proves their worth and advantage over single-butted (cut) or straight gauge.
But that's more theory than reality. In reality, if you build the wheel properly you'll be fine with 2.0/1.8 single butted spokes. Or straight gauge. 1.8 is plenty at the threaded end.
Long story short: buy whatever you can get your hands on, but given the choice, go for double butted.
Whats Bike Friday across town got? they use a lot of short spokes..
For the spectators Clifford and Bike Friday are in the same town.
Quoted: 2026 Post(s)
Liked 1,096 Times
i have used straight gage spokes for wheels over 30+ years * do the OCD expression if you wish.
got a phil or hozan thread rolling tool?
* including 15 ga straight , 36 per wheel. never broke a spoke on that wheelset.
touring the wheels I built used 88 spokes, the lower cost of straight 14ga became significant.
Quoted: 1572 Post(s)
Liked 643 Times
Try Dan's Comp. They are my go-to source for short spokes. Cheap, reliable, fast and they also offer spokes in fancy boy colors.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
To answer your question, butted spokes are said to result in a stronger wheel than straight, but it's academic if they don't fit...
Today, I believe my jurisdiction ends here...
Liked 4,508 Times
They're listing the spokes at $0.60 each, which might not be bad, especially as I'd only need to buy the number of spokes that I need for the one wheel (plus a couple of spares).
A couple of sellers on E-Bay are also cutting the ends off of double butted spokes to cut them down to length, at pretty close to the cost of the full length spokes.
I should also be able to cut my own if I go that route, but if it only costs 10 cents a spoke to get them made, then it is probably worthwhile to just buy them. And, factory spokes would be all the better.
Looking at a few small wheels on the internet, it looks like there is a risk of bending at the nipples which can't be good. Perhaps one should double check the drilling, as well as ensure proper swivelling at the nipple washers.
Nope, I didn't get the Java rims yet. I found some, but unfortunately they're 406 rims, I think, and not 451's.
Anyway, thanks for the suggestions of potential suppliers.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
My guess would be that it's easier/cheaper for BF to source 36h hubs than 24h, and just don't need all those spokes to make the smaller wheels work. (Spoke holes on a 24h 451mm rim are closer together than 32 spokes on a 622mm rim.)
Liked 1,096 Times
I don't think butted spokes result in a "stronger:" wheel, but one that's a bit more fatigue resistant since the thinner center sections stretch more under impact and protect the thicker ends from stress.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
What are you building? I have several 451 wheels in my collection that I need to rehome. I've converted my Gold Rush recumbents to 406 diameter front wheels, so now I have 2 24-spoke and 2 28-spoke wheels to dispose of. Some rim wear, but still usable.
Jeff Wills
Jeff Wills
Liked 4,508 Times
I've been working on tuning and modifying a couple of Bike Friday bikes. I wanted to try lacing up a Capreo rear hub to a 20-451 Sun M14A rim that I picked up.
I'd like to do a bit of a comparison of Capreo vs Sachs Dual Drive.
But, truthfully, I like my regular bike, so I don't know how many miles I'll realistically put on the BF.
I think my front wheels are in reasonable shape, but it never hurts to have a spare... or something for projects. I was also considering building a single wheel trailer to mate with the Bike Friday with a matching 451 wheel... so everything would more or less match.
Quoted: 273 Post(s)
Liked 10 Times
So "fatigue resistant" isn't the same as stronger..?
Quoted: 802 Post(s)
Liked 703 Times
Yes. You can build a very lightweight wheel that will last many thousands of miles ridden by a lightweight rider on smooth roads. Put it on a Clydesdale's mountain bike and it'll be toast by the end of the first ride. Clyde S. Dale needs a stronger wheel.
Take that same wheel, loosen all the spokes a turn or so and it's still rideable. However, the tension variations will rapidly fatigue the spokes, causing them to break in short order. Ms. L. W. Rider needs a well-tensioned wheel to live with all her miles.
Jeff Wills
Jeff Wills
Liked 643 Times
Depends on who is doing the defining. If your definition of stronger is "doesn't break" that's a vernacular definition. We tend to use technical terms interspersed with vernacular terms so, whichever definition you use, there will always be somebody who is going to say that you're wrong.
Quoted: 273 Post(s)
Liked 10 Times
