Bilaminate frame construction - "Alex Singer" style?
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
I can understand the process to make it this way:
But am trying to figure out the order of fabrication in this method:
At first I figured one would just brass braze the "lug", then silver the tubes in, then I realized there would be no way to get any decent penetration into the lug. So then I figured silver in the lugs, mitered to match the TT and DT, then fillet braze with brass. But brass temps would melt the silver. So now I'm thinking you brass braze the lug onto the TT and DT, either pre-mitered, or mitered together with the tubes, then fillet braze the sub-assembly onto the head tube.
Anyone try this before?
Quoted: 4209 Post(s)
Liked 3,875 Times
I've done a few of the second version, not for full frame building but tools and play things. Flow brassed a sleeve with a lug like shore line cut on the tube end, miter sleeve and tube like a tube gets and fillet against the second joining tube. Use brass/bronze for both steps. Andy
AndrewRStewart
AndrewRStewart
Liked 5,801 Times
Liked 5,801 Times
Follow up question: 1" tubing fits inside 1-1/8" 0.58", and I've made a few scratch lugs that way, but they're pretty thick. I'm guessing the thing to do is turn down a 1-1/8" tube to thin it down first. Looking for someone with a lathe to do that.
Liked 3,875 Times
I have read of both centerless grinding and simple turning down as thinning methods. Of course there's always filing Andy (who has a set of self made lugs in process and they will be for a long time)
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,699 Times
I could turn some down for you
Herbie Helm had a beautiful frame at the Richmond NAHBS. He silver brazed the "lugs" onto the tubes and then brass brazed the tubes together. So you certainly could brass braze both.
Quoted: 103 Post(s)
Liked 144 Times
I turn my seat cluster sleeves and other bi-lam sleeves down to around .045" wall thickness from .058". The thicker look is just a bit too chunky for my eye.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Liked 5,801 Times
I've done a few scratch lugs with .058", and did a lot of filing and sanding to thin them out after brazing. It's a lot of careful work, would rather start with thinner material.
