Couplers' Location in Frame Design
In the construction of SS-coupled (or Z-coupled) tandems, are there disadvantages to locating all the couplers in the tubes between the captain's and stoker's seat tubes? An advantage, it seems to me, is that it is easier to pack two triangles, plus a couple of straight tubes. Is there a structural (stiffness) or durability price paid in using this design approach?
Quoted: 623 Post(s)
Liked 396 Times
As long as you keep the couplers tight they are more structurally sound than the tubes they are connected to. I believe as long as you can put the uncoupled tandem in to 2 airline legal suitcases the location were the couplers are installed on the frame is correct.
The advantage to having couplers in front of the captain’s seat tube is that it allows removal of the front triangle without having to remove the timing belt (or chain). This allows me to fit our tandem in the back of our small car by simply undoing the couplers and cable splitters.
Of of course if your rear brake is hydraulic, this point is moot.
FWIW Rodriquez 6 pack travel bikes have S&S couplers on both ends of the main triangle tubes.
plus in the wishbone seat and chainstays
[ BTC are stronger than the tubes they go onto..]
looks like they use 14 of them.. (6 in the solo bikes)
Bikes: Merlin Road, Rivendell Road, Arvon custom tandme, Hi-Light G-7
Quoted: 24 Post(s)
Liked 11 Times
If those are 2" couplers, that's a lot of $$$. Certainly will pack well.
Quoted: 169 Post(s)
Liked 84 Times
Lolly, our mountain tandem, only has 4 couplers. We're doing our first flight trip with her 8 weeks from today. Since all of our housings are full length, it will present some challenges I am sure.
I've built and packed up a handful of tandems with both coupler arrangements. In general, I find having couplers in front of the captain seat tube to be the superior approach. However, some tandems can't be made to fit into an S&S hardcase with that arrangement. Here are the pros of of the front-of-seat-tube couplers:
1. Small head tube / front triangle: very easy to fit in case without fork. Sometimes possible to leave fork installed.
2. (as others have noted) Bike can be partially disassembled for cars/trains without adjusting the sync chain/belt. We occasionally put the tandem inside our hatchback by disconnecting the cable splitters and front couplers. Wheels, seats, fenders, etc all remain installed.
3. Reassembly of the frame tends to be easier.
Cons of loose tubes:
1. Loose tubes can be installed at any orientation or flipped front-to-back. Bottle cages or cable guides could be located incorrectly. For those bikes, it's handy to put some match marks on the couplers.
2. Front triangle and rear triangle are both very large chunks. It can be difficult to nest them together.
Pros of loose tubes:
1. Allows tandems with especially long stoker compartments to fit into S&S suitcase.
In both coupler arrangements, a captain crankarm sometimes has to be removed or reversed.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I think it's around $12-$13,000 dollars. I've met the owners of that commissioned the original. Their bike has 50,000 miles currently and has been on 6 continents.
It fits in carry on luggage...in the overhead bin. Which makes sense. Anything at that price isn't worth being "lost" by baggage handlers or sloppy airlines!
