Dropper post on a CX or gravel bike?
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
So I just installed a dropper post on my gravel/commuter bike. I thought about it for a while since I recently converted to a 1X set up and rode a MTB on some pretty gnarly trails with a dropper for the first time. I wondered what would be involved to make my SRAM Doubletap shifter work as a dropper lever, as well as how to make an internal routed post work as well. I got it figured out and made a video of the process if anyone is interested. I'm not sure how it's all going to work out long term, but I'll make a follow up video once I form some kind of opinion on the set up.
Likes For Le Mechanic:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Shimano GRX does this.
The left lever can operate a dropper post when run 1x.
-Tim-
-Tim-
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Next on my list of things to try on my gravel rig (because I insist on riding it like it's a mountain bike).
Quoted: 96 Post(s)
Liked 72 Times
I rode my setup to work for the first time yesterday, works well so far!
Non omnino gravis
I wish I had an idea that I would be in the market for a dropper when I bought my SRAM Rival HRD levers-- I could have used the paddle on the left for the dropper, as you have. But I didn't, so I'm using the PNW Roadie Lever, which works well enough. It would just have been a lot cleaner (and easier to route the cable) with the SRAM paddle. About 1,800 miles with the PNW Pine on my Swiss Cross, and I don't think I can go back. I've found the dropper to be more handy for my everyday rides, most of which are on pavement-- on a typical ride out on the trails and fire roads, I might only need to drop the saddle 4-5 times. Out on the road, it's down at every stop light.
Quoted: 353 Post(s)
Liked 92 Times
I did the dropper hack on my Rival shifter and it took a whopping 5 minutes. Most of that time was just spent taking out screws. It's only 3 pieces and you can undo it the same exact way in less than 5 minutes.
Quoted: 96 Post(s)
Liked 72 Times
https://www.youtube.com/watch?v=ngvd0F8JxnE some pretty good instructions for it. looks reversible too which is nice
Sunshine
Quoted: 11009 Post(s)
Liked 7,537 Times
Cant say ive ever found the need to drop my post when commuting.
...actually haven't found the need to drop it when riding gravel either.
Our gravel roads are roads, just unpaved. If I were in an area with 15% twisting descents with washout and boulders, that might be a different story.
Thanks for the video, I like seeing how that left shifter is being repurposed on 1x.
Liked 10 Times
Def been on CX courses with some steep descents that i'd like to have it. But i run the same bike for cx and gravel so i'll keep my 2x for the gearing.
