Disk Upgrade from 1 1/8 Fork
Bikes: Calfee Tetra Custom, Calfee Tetra Tandem, Habanero
Hi. Apologies if this has been covered, did some searching and didn't find anything, though …
Thinking to upgrade 2007 Calfee tandem to eTap and hydraulic/disk brakes. Right now fork is 1 1/8 (Alpha Q X2). Is there a fork I can jam into my existing frame, or does this require sending it back to Calfee for rework? Team weight is about 310.
Quoted: 2495 Post(s)
Liked 738 Times
The Woundup Duo 2 is a tandem-rated disc-compatible fork with 1 1/8" steerers. It may be slightly longer (387mm axle-to-crown) than your current fork -- minimal affect on handling, but you'll want to lower your stem by the difference. It's available in 45 and 50mm rake. You'll want to match the rake of your old fork closely to preserve the bike's handling.
If your frame has a 44mm (or larger) head tube inner diameter, you can replace the headset to open up a few more fork options.
When it comes to tandem-brakes I’ve never regretted my choice for the Magura MT5. As a hydraulic double piston brake it’s working really well on our loaded 200 kg-truck and it has -to my mind- a fair price/performance ratio. Here (Europe) we have a street price of under 150 Euros per set (plus discs). The brake body itself is exactly the same as with the MT7 (which comes for more than double the price), it has just a simpler lever and different OEM braking pads. And since this lever has even a wider transmission ratio than the MT7 (means, the moving range of the braking pads is slightly bigger), it is nearly the perfect brake to me. In comparison with the MT7 you need a little more hand force (sometimes two fingers instead of one) but it’s easier to get the whole system “grind-free” after re-mounting of the wheels...
James_Smith
Mountain Biking
22
02-11-17 06:16 AM
canflyboy
18
05-27-12 06:47 AM
