MKS QR pedals
Bikes: who's counting?
Quoted: 16 Post(s)
MKS QR pedals
I just acquired these for my Dahon, but for the moment I can't trust them.
The basic problem is that the yellow plastic clip they provide to prevent the adapter cap from slipping off while riding is about twice as thick as the space available between the adapter cap and the crank. Of course, I could theoretically back off the adapter from the crank, but they show a tightening torque for this, so it doesn't seem advisable.
The other thing that bothers me is the difficulty of removing the yellow plastic clip, and I wonder why they couldn't have molded on some grab points at the ends.
==>> How have others dealt with this?
Which MKS pedals exactly? I own MKS QR pedals, but they don't have a 'yellow plastic clip'. A model and image would help.
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 847 Times
I have these pedals, and the plastic thingy is long tossed in the trash.
Quoted: 7 Post(s)
There are two types of MKS quick release pedals... there is a cheaper model that has the plastic thingy to keep the quick release mechanism from accidently releasing. I've heard of people leaving the plastic thingy out with these and having them accidently release the pedal. There is a more expensive model that doesn't have a plastic thingy. Instead you have to twist the quick release mechanism before it can release.
See if you have to twist to release it.
Quoted: 573 Post(s)
Liked 118 Times
… by buying Wellgo and Expédo quick-release pedals, after reading about the same issue you had.
https://www.xpedo.com/products/pedals...traverse-5-qrd
QRD - Wellgo
QRD - Wellgo
Quoted: 16 Post(s)
They're Promenade. I don't think an image would make a difference, as if you're not familiar with the situation, I don't see how you can help. I was hoping to hear from folks who had experienced this and resolved it.
I knew they had more expensive versions, butdidn't realize that the release process was part of that price difference. I mostly wanted something I could mount semi toe clips on.
tds - somewhat typical for you, you'll make a statement like that but not say what you're using instead. If you have no intent to be helpful, why reply at all? Do you just like to generate noise?
Quoted: 113 Post(s)
Liked 8 Times
I think what tds meant was he tossed his and hasn't had his pedals come off.. one of my bikes has clips, the other doesn't .. I had a pedal come off in 2006 without the clips, but I wasn't 100% sure if I had engaged the quick-release fully.. there were a lot of posts pro and con on the Dahon board concerning clips for the MKS EZY system.. then along came the Superior EZY series, which did not have the clips .. I also run MKS EZY clip-less pedals on my same bikes when I feel like clipping in..
Quoted: 16 Post(s)
Thanks, Bruce - it's good to have a voice of reason. I'll try to locate some appropriate washers. I'd say right now I have about (and perhaps less) than a mm of clearance, and the yellow band needs about 3 mm.
Based on my tests on the ease of removing the pedals without them being secured, I don't think I'm willing to ride like that.
I don't get your last sentence at all.
I tried to copy it, but the forum software won't let me.
Speaking of that - I find that after I post, many of the spaces between words are removed. Any idea what causes that? Or is it a bug that folks have just learned to accept?
55+ Club,...
Bikes: 9+,...
Liked 847 Times
And thanks @BruceMetras. My mks pedals had come with a plastic yellow clip, that the INSTRUCTIONS specified was a spacer. I didn't need it, so I discarded it. It was stated that it wasn't needed on certain crank arms.
Quoted: 113 Post(s)
Liked 8 Times
The MKS EZY system is the one that uses the plastic clips.
The MKS Superior EZY system is the one that uses the 'twist to release' coupler
The MKS EZY system that uses the clips have a variety of pedals that can be used with the couplers.. one of pedals is the MKS Cube SPD type clip-less pedal as shown.. this is the pedal I have when I want to use my SPD type shoes, which is rare as I really like Power Grips and I ride a lot in Five Ten Freeriders ..
Quoted: 113 Post(s)
Liked 8 Times
55+ Club,...
Bikes: 9+,...
Liked 847 Times
More than a spacer, the yellow clip is to keep the coupler from accidentally disengaging while riding.. some have reported years ago that their foot contacted the sliding sleeve while pedaling, pushing it inward, then the pedal was not secure and it would release.. the yellow clip once installed makes it impossible for the sleeve to be pushed in with the resultant release of the pedal.. as I said, I ride with and without the safety clips, but then my foot is probably more stable over the pedal because of the Power Grips..
Quoted: 113 Post(s)
Liked 8 Times
When you release the pedal, do you push the coupler sleeve straight towards the crank arm, or do you give it a half twist?
Bikes: to many
Quoted: 213 Post(s)
i thank that the op has not pushed back the sleeve all the way ...there is a lot of room to get the safety clips in there
I never use mine
but thats my personal choice
they need be fully inserted and not just 80% which i believe the op has trouble with
thor
I never use mine
thor
I have a set of MKS AR-2s on a speed P8 and they look like this mount, except I have black plastic clips.
MKS UB-LITE EZY Pedals | Tern Folding Bikes | Worldwide
I also think this, or something is jamming the sleeve from its full travel.
I use my plastic clips, vaguely recall reading some folks that have gotten hurt when their pedal fell off unexpectedly.
Bikes: Wheeler Mtn bike, Strida 5.0, Tern Link Uno, FSIR Spin 2.0, Dahon Mu P8
Quoted: 34 Post(s)
I"m another one with the mks pedals and I also never used those yellow clips after i lost them.
Never had it disconnect and been riding them since 2010. Repacked the bearings twice so far and it's running amazing.
55+ Club,...
Bikes: 9+,...
Liked 847 Times
I've also noticed that the pedal cage comes up above the release, so my foot wouldn't hit it, and possibly open it, during a ride. I'm guessing the situation might be different for different individuals.
Raleigh20 PugFixie, Merc
I have these and as far as I can tell the yellow plastic clip is a 'designed by lawyer' thing to protect them from any liability should the pedals release accidentally. It's clearly an afterthought, as if it were an integral part of the pedal design it would be metal and easy to remove.
My experience with these pedals is that I've never once had a problem with accidental quick-release, and nor should anyone as it's a very clever, strong design - It's hard to imagine an every-day scenario where the collar would be pushed back enough for the axle of the pedal to release - and even if it did the pedal would probably not move laterally out of the collar.
So like others - I tossed the little clips as they only hinder your user experience. Make sure the pedals are clipped in properly before riding and you'll be just fine.
My Raleigh Twenty site | foldr : A flickr pool | #6460, #5632 & #3407 on the fixedgeargallery
I have had to use a washer to space the adapter out from the crank arm as the crank has an indentation - with no washer, I could not get the pedal in or out.
Bikes: to many
Quoted: 213 Post(s)
They come witj washers which one is supposed to use. The washers also protect the alloy crankarm from being chewed up ..
Quoted: 3459 Post(s)
Liked 1,465 Times
I never used the plastic thingys. But, I am always careful to make sure that the release mechanism is in the locked position. But I worked in a factory were we had air hoses with similar quick release type fittings so I was used to making sure that quick releases are in the locked position.
I would not be surprised if the plastic thingys were really designed to just make sure that the release mechanism is in the locked position to make some attorney happy.
Quoted: 573 Post(s)
Liked 118 Times
I'll add to this thread since those pedals look very similar.
I got a pair of cheap Promend PD-F57 removable pedals.
What are those yellow thingies, and what happens if I lose them?
Thank you.
Edit: "clips", "retaining rings"
"The yellow C ring supplied with should be fitted to stop the pedal from being released by kicking during the pedal stroke - we thought it wouldn't happen, so tried without them - eventually we managed to make the pedal come loose. It sits behind the pedal and stops the pedal release mechanism from being deployed. (In winter with cold fingers this could be a bit of a fiddly manouver)"
https://brilliantbikes.co.uk/brompto...y-stopper.html
"The stopper must be fitted. If the stopper is not installed the pedal attachment is incomplete.
Without the stopper the adapter can break, or the pedal may fall off resulting in serious injury."
https://www.mkspedal.com/?q=en/product/node/33
Thank you.
