1984 Peugeot 12 Vitesse - New Zealand
I'm still not completely convinced. A Facebook contact assures me "The better model set up as a racing model was made of Vitus steel tubing." Someone else told me that mine is Carbolise tubing which I understand is somewhat entry level. At the same time, still a good reliable frame for everyday use. Though I'm not encouraged by this Facebook comment "Some of the brazing on the locally made frames was not great, and i did see several that came apart at the lugs."!
Quoted: 5888 Post(s)
Liked 3,471 Times
Peugeot carbolite is just hi tensile steel. If it's hi tensile steel, you can tell by running your finger on the inside of the tubes and feeling for a seam. Also a seam is likely visible on the fork legs as well. Some good tubing sets are seamed but if your bike is seamed, it is likely hi tensile steel.
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Quoted: 600 Post(s)
Liked 11 Times
I'm amazed at how similar this bike looks, in paint and graphics, to my old 1983 PH10s. Of course, that was a lesser bike, with lesser components and no chrome fork, but the color/graphics appear to be dead on.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
Here's my '84 PH10LE for comparison (I bought it brand new in '85).
Winemann side pulls. Rigida 27x1 1/4 alloy clincher rims. Original pedals. FD and RD were replaced 30 years ago when I put a 3rd chain ring on the crank (32-48-52). Crank and arms were also replaced. I don't remember what the original crank set or derailleurs were. Helicomatic rear cog set (12-28). 25" frame. Carbon seat post (not the original). Saddle is a Trico gel (also not original). Don't remember what the hubs are and unfortunately the bike isn't at the house at the moment.
Jon
Jon
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
saw several that came apart at the bottom bracket .
That certainly looks like the right colour. I had to squint to read the name 'Metallic Blue'. Is that from a US catalogue?
Jon
Jon
I'd be interested to know if your bike has the Maillard rear hub system.
Quoted: 600 Post(s)
Liked 11 Times
Here's a better image (the top one) of what my bike looked like, since I don't have a good photo of mine. Complete with stem shifters and turkey wing levers, which at the time I rather liked.
I'm betting your frame is structurally sound. Shame that so much of the paint is damaged, since it's a very good looking bike. That said, I wouldn't be surprised if it cleans up better than imagined.
One thing your photo and others have shown me is that the bikes look pretty nice without the chrome forks. I am considering having the frame and forks powder coated then a new set of decals added. Maybe even with the forks a different colour as you can get metallic silver and various shades of white. Perhaps even a blue frame with white forks would do for an unusual look though I'm sure that would really upset the purists!
Quoted: 600 Post(s)
Liked 11 Times
The problem is the rust beneath the main decals on the upper tubing. To get at the rust I will have to destroy the decals which are such a feature of the bike.
I've been looking at the plastic derailleur cable guides under the BB. There's a single tiny rivet holding it in place and a hole where I assume there should be another. That will have to come off if the bike is re-finished.
I've received a quote of NZ$120 by a local firm to powder coat the frame. It goes up to NZ$180 if the colour I want isn't one they have in stock. Fortunately I can have the sandblasting done via a family contact which will keep the cost down. I like the idea of having the forks powder coated as I think there is something suspect about the chrome in the case of my bike.
Here are the colour options available to me. They don't have much in the way of bright colours and there's only one blue 'Electro Bluit' that looks like it might work. It is darker but has the metallic look which is in keeping. Other than that, I like the idea of an off-white...
Powder Coating Colours - Dulux
I think I've found the correct decals. Agreed, something that compliments the graphics and vice versa would be best.
Another piece of information has come to light while I was looking up how to remove the crank set. I wasn't sure of the model but now know that the bike has a Shimano Golden Arrow FC-S105 fluted crank set. According to information just found on VeloBase.com it is of excellent quality and rare. Also on a page about the similar FC-S125 they refer to an example of the fluted version FC-S105 with the 'HF' stamp (same as mine) indicating the year 1983. Here are the page links:
VeloBase.com - Component: Shimano FC-S105, 105 Golden Arrow (Fluted)
VeloBase.com - Component: Shimano FC-S125, 105 Golden Arrow
Now if only I could find the right size socket to get on with the job...
Quoted: 283 Post(s)
Liked 636 Times
The socket to undo the crank bolts is nothing special ? 14mm from memory ?
For what it is worth these bikes did not have had shimano 105 when new ( In NZ)
They all had a very basic stronglight crank set .
Ah yes, I was waiting for someone to mention the crank puller tool. At this stage no but my brother probably has one that is very well travelled.
Incidentally, I have been anticipating needing to buy the special tool for loosening the rear Maillard gear cassette. However, I discovered the whole thing is completely loose! I will of course need the tool to tighten it up properly.
That is what I was expecting either 14,15 or 16mm but none of the sockets from a borrowed metric set will fit. I think it is the design of the sockets, i.e. the outer diameter is too wide for the available space. Will try to find another set.
That's good to know. I have been assuming it was retrofitted but wasn't 100% certain.
Quoted: 283 Post(s)
Liked 636 Times
hmmmm if you have a helicomatic hub like the one pictured you sort of need the correct tool to tighten .
In saying that if you are careful and dont use too much pressure you can get away with multigrips. :=)
Quoted: 1639 Post(s)
Liked 829 Times
A lot of collectors frown at powder coating bike frames as it causes a couple on "negatives".
1) Powder coating usually ends up going on much thicker than regular paint, so some of the lug and pantograph details on frames lose their edge definition.
2) If the powdercoater and owner of the bike do not collaborate carefully before the powder coating is done, to mask of certain areas on the frame with holes and threads that components mount to, powder coating will get into them and will make assembly of the threaded parts and holes where items go through or get pressed on to (bottom bracket, downtube shifters, waterbottle mounts, seatpost clamp bolt, headset, brake calipers and rear and front (if it has a French style mount with a threaded boss on the seat tube) derailleurs) very hard to do, as powder coating does not come off easily.
In this case, I think powder coating is a good alternative to paint as this Peugeot have very simple lug profiles (Most likely, medium point, Bocama, windowless) and most likely does not have any pantographing, so there is not that much detail on the frame to worry about getting covered by to much powdercoating. Just make sure that the frame is masked of carefully for components I mentioned above.
Only thing that might get affected on the bike will be it's market value to C&V collectors who just do not like powder coating on any C&V bikes.
A motor mechanic friend of mine said these bikes were everywhere when he was growing up in Holland. He recommended the powder coating because that was how they were done at the factory. I assume that is correct.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 829 Times
Peugeot Carbolite forks from that era actually had a very narrow groove running along the backs of the fork legs. That's where the fork leg tubes were seam welded. The grooves and welds are very clean, most likely because it was not done by hand, but my machine.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Thanks and yes I do have the helicomatic hub. The tool with the bottle opener has great appeal and might just be worth getting for that reason alone, although reasonably expensive via eBay from memory.
