Pimping my Dahon Espresso
Old 01-23-19, 09:40 AM
kidshibuya
Bikes: Tyrell CSI, Dahon Mu LT11, Doppelganger Aurora 219
Quoted: 150 Post(s)
Originally Posted by Barchettaman
I was a bit cramped so fitted a cheap extender from China. Does the job!
Also, I wasn’t getting on with the bullhorns so swapped in a cut down flat bar and some Ergon grips. It’s much better now.
Nice work.
If you want some ideas for light weight parts take a look at my build:
https://www.bikeforums.net/folding-b...csi-build.html
There are still a lot of areas where you can shave weight but it gets costly quickly.
kidshibuya is offline
Old 11-06-19, 02:35 AM
Barchettaman
Barchettaman's Avatar
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 103 Times in 69 Posts
Barchettaman is offline
Old 11-06-19, 02:41 AM
Barchettaman
Quoted: 128 Post(s)
So, 2 years since I got it and the Dahon has seen some serious use.
It’s been on tour around Europe, gravel riding in Bavaria, on holiday to Cornwall, had a couple of months in Wales and recently 6 weeks commuting across London.
It’s been on buses, planes and just about every sort of German train.
The rear rack collapsed but I had a Blackburn rack ready to go on.
I have just swapped the new handlebar in. The FSA external bottom bracket is pretty short lived but I have removed the seals, cleaned and repacked it a couple of times. Easily done. Drivetrain now has a few thousand KM on it but still looks ok. New shift cables and housing, new brake pads, that’s it.
I’m very glad I went with the Magura hydraulic rim brakes as I have ridden with some serious weight on board.
All in all a great acquisition and a keeper, for sure!
Old 11-11-19, 05:08 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times in 174 Posts
What Front chainring do you run? I'm interested in the small one as the top seem a 50 something teeth.
thanks
Fentuz is offline
Old 11-18-19, 04:54 AM
Barchettaman
Quoted: 128 Post(s)
thanks
Standard racing compact (as that’s what I had in the parts bin). 50/34, 11-30 ten speed cassette.
It’s a bit overgeared. A 13-30 cassette would be perfect.
Old 11-19-19, 09:29 AM
Barchettaman
Quoted: 128 Post(s)
Likes For Barchettaman:
Old 11-19-19, 09:30 AM
Barchettaman
Quoted: 128 Post(s)
Just got this one too for €10 - looks like a project!
Different branding but the geometry is the same.
3x7 Microshift, flat tyres, no seatpost, but should be an easy fixer upper.
Old 11-21-19, 07:18 AM
Barchettaman
Quoted: 128 Post(s)
All finished, rides perfectly.
Old 12-17-19, 12:12 PM
Barchettaman
Quoted: 128 Post(s)
So the white DLT above sold pretty much straight away for €130, which netted a nice profit, offsetting the costs of pimping the silver Dahon a bit.
I’m currently in Strasbourg and the bike is running perfectly. Newly cabled and with fresh brakes, I repacked the folding pedals as they were squeaking horribly, everything works as it should and it’s a joy to ride.
If you don’t need a particularly small fold, then I highly recommend these Dahon 26” folders. They ride exactly like a standard hybrid.
Old 05-24-20, 02:01 PM
Barchettaman
Quoted: 128 Post(s)
Back to pimping the Espresso: it’s about to receive a Swytch front wheel e-bike conversion.
Old 01-03-21, 01:18 PM
kentpaul
has anyone put shock forks on the front of a D21?
kentpaul is offline
Old 01-03-21, 04:29 PM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
What are you hoping to gain? Roger
rhenning is offline
Old 01-04-21, 05:07 AM
kentpaul
a smoother ride I have it set up as a mountain bike. also considering a rear ewheel or middrive motor?
kentpaul is offline
Old 01-05-21, 02:42 AM
Barchettaman
Quoted: 128 Post(s)
Hi Roger,
When I am working away, I will be able to more comfortably park and live temporarily further away from my destination and commute in.
I will hopefully save some cash. The Swytch kit works well.
Old 01-05-21, 03:14 AM
Barchettaman
Quoted: 128 Post(s)
is that a question for me?
I am considering neither as the front wheel Swytch conversion fulfills my requirements. It’s a decent piece of kit, although installation took a while.
I also serviced the external bottom bracket cups whilst I had the crank arm off so that took a bit of time. It’s well worth doing this if you run an external BB. They won’t be perfect afterwards but you can extend their life massively.
Old 01-09-21, 01:53 PM
kentpaul
have any of you figured out the best way to attach an ebike battery to the frame?
kentpaul is offline
Old 01-25-21, 03:35 AM
Barchettaman
Quoted: 128 Post(s)
You have various options.
a smaller bottle style battery on the bottle bosses under the downtube.
a rack battery on... a rear rack.
the Swytch handlebar battery is a decent solution. It’s easy to remove. There is a mild effect on the steering as it is slowed by the extra weight up there but you get used to it quickly enough.
hope this helps.
Old 02-15-21, 12:01 PM
kentpaul
hope this helps.
https://www.bikeforums.net/folding-b...l#post21925054
kentpaul is offline
Old 03-12-21, 12:53 PM
tds101
55+ Club,...
tds101's Avatar
Bikes: 9+,...
Quoted: 1111 Post(s)
Liked 842 Times in 587 Posts
How about some pics of the bike with the kit installed. I'm contemplating getting the Swytch Bike kit myself,...
tds101 is offline
Old 03-12-21, 01:15 PM
Barchettaman
Quoted: 128 Post(s)
  • Oops apologies. I will upload photos tomorrow!
Old 03-12-21, 01:27 PM
Barchettaman
Quoted: 128 Post(s)
a pretty terrible photo but it’ll give you an idea.
Old 03-12-21, 05:28 PM
kayakindude
Bikes: 1987 Cannondale SR600/BioPace, 1991 Cannondale Road Tandem,1994 Giant Iguana MB, 2009 Airnimal Chameleon, 2016 Dahon Vybe C7A
Quoted: 121 Post(s)
Liked 100 Times in 63 Posts
I love my Swytch kit. Bought 2, 1st one is on a tandem. Other will go on my wife's road bike to keep up with my Chameleon
On a smaller folder their Brompton block mount would be ideal.
kayakindude is offline
Old 08-31-21, 07:20 AM
Barchettaman
Quoted: 128 Post(s)
Crisis time!
The seat tube cracked all the way round; fortunately the guys at the theatre here in Belgium could fashion a rough and ready repair.
It looks pretty awful, but I don’t care at all, it just has to hold!
A month of Begian pavé proved too much for it!
