Using a flashlight as a bike headlight?
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I have been using a Fexix LD10 and LD20 flashlight for perhaps a decade. Mounted on bike with a twofish linked above.
It works for seeing the road in total darkness even on winding hilly roads when racing friends.
I put in a fresh charged NiMH A or 2xAA before ever ride and if the ride is over 3hrs I carry a 2nd set of batteries.
I can aim it level to slightly down for use on road or tilted down more for rare use on MUP.
Flash mode during the day.
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Actually it is the L1D (1xAA) and L2D (2xAA) I still use - I have two bodies for each length, but use the same head. I also have a LD20 which is the improved model, but the threads are different so it doesn't fit with the LxD bodies.
When on extended night rides I use both the L2D and LD20 set up below bars on each side of stem. Usually I use one at a time and switch over when one runs out of battery, but use both when I want more light.
Here is the L1D on commuter:
I'd like to put some ideas into this thread:
https://www.bikeforums.net/electroni...l#post19987793
If $50 is the definition of cheap in this thread, whats the definition of good, effective and bright?
There are several evolutions of bike lamps:
The difference between headlamp and headlight can be told as follows:
"headlamp is the term for the device itself, while headlight properly refers to the beam of light produced and distributed by the device"
wikipedia.org/wiki/Headlamp
So for class 5/6 there are now even chinese designed lamps without brand:
banggood.com/XANES-SFL04-750LM-T6-LED-German-Standard-Smart-Induction-Bicycle-Light-IPX4-USB-Rechargeable-Large-F-p-1217023.html
banggood.com/XANES-1500-Lumens-Led-Bicycle-Lights-MTB-Cycling-Front-Head-Lamps-Safety-Usb-Charge-Cycling-Light-p-1216450.html
- flashlight body with mount for use on handlebar
- offroad mtb lamp with round shaped reflector and low luminous flux (<200lm)
- offroad mtb lamp with round shaped reflector and medium luminous flux (200 - <900lm)
- offroad mtb lamp with round shaped reflector and high luminous flux (900 - 4500lm) examples: YinDing, Lupine
- bicycle lamp with reflector optics/cut-off beam and low illuminance (<40lx) examples: B&M Ixon, Cateye HL-EL500
- bicycle lamp with reflector optics/cut-off beam and medium illuminance (50-100lx) examples: B&M Ixon IQ Premium, Cateye Volt 80
- bicycle lamp with reflector optics/dual beam and high illuminance (150-380lx) examples: B&M Ixon Space, Supernova M99 series
Quoted: 4559 Post(s)
Liked 2,802 Times
Some purpose made bike headlights also have features not usually found on flashlights. Some headlights have side ports or lenses to increase visibility from the sides. That includes most Light & Motion Urban and similar L&M lights; many Serfas lights; and several generic headlights sold under many brands for $20 or less.
Some bike headlights -- not all, unfortunately -- include built-in hoods or lens/reflector designs that shape the beam with a cutoff similar to motor vehicle headlights to avoid blinding oncoming cyclists and pedestrians on narrow multi-use paths. Some Serfas and Nite Rider headlights have built in hoods that physically cut off part of the beam to minimize spill. I've homebrewed hoods for my Light & Motion Urban light to do the same thing more effectively. And Busch & Muller and a few other headlights have lenses and reflectors designed to mimic the beam patterns of motor vehicles -- defined cutoffs, plenty of light on the road with minimal spill.
Occasionally I prefer the broad circular beam of the unmodified Light & Motion Urban so I'll remove the homebrewed hood. On rural roads at night I want to see everything in case a deer or other critter darts out. I also want to see into the trees to watch for owls and hawks -- when startled some bird, even smaller mockingbirds and jays, will swoop down to defend their nests or go after anything they consider prey. This is so common with a hawk found in Texas and Oklahoma I've called 'em Great Speckled Hood Swoopers. There's a theory that the hawks are actually after any flying prey driven ahead of a speeding vehicle or bike, which our headlights help illuminate for the hawks.
Quoted: 3459 Post(s)
Liked 1,465 Times
I have been using a vintage D Lumotec dyno powered headlamp on my rando bike. Two days ago I ordered a new B&M IQ-XS to replace it.
https://www.bumm.de/de/produkte/dyna...di-silber.html
Quoted: 7348 Post(s)
Liked 2,464 Times
My regular light for commuting is a Lumotec IQ Fly-T. I don't remember how many Lux it is rated at, maybe 50 or 60. It's not super bright, but I'm not super demanding about brightness.
In your list I was not sure where the transition from incandescent to LED was? Between 1 and 2?
bumm.de/de/produkte/dynamo-scheinwerfer/parent/167/produkt/167rtsndi-01-schwarz-167rtsndi-silber.html
lupine-shop.com/en/accessoires-and-parts/upgrade/
The IQ-XS is good, but why didn't you take the IQ-X ?
bumm.de/en/products/dynamo-scheinwerfer/parent/164/produkt/164rtsndi-01-schwarz-164rtsndi-silber.html
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I've used flashlights, it works fine except for narrow beam, more hassle recharging, and seems like in the way a little more. I've never had a mount fail or even slip, but my DIY on that is a little more robust than the commercial ones.
The flip side is that the cheap bike lights are less expensive, more convenient and cast a broader beam so my only use now for the flashlight is as a backup.
Liked 1,465 Times
I ordered it from Germany. Since I was already ordering something else which was covering the shipping cost for that order, the light was essentially free of shipping cost. At the time I ordered it, $1.13 USD was about 1.00 Euros. Price was a bit under 39 Euros. Price of IQ-X would have been over 50 percent more. I did not think it was worth the additional cost.
But the old light I am replacing is quite old (in photo) and overdue for an upgrade now that the newer lights are so much better.
It is my understanding that the XS has a beam pattern very similar to the Luxos B. On a different bike I have the Luxos U, which I assume (but could be wrong) that the low power setting on the Luxos U is the same beam pattern as the Luxos B. And I am quite content with that beam pattern, did not think I have any need the extra power for the extra cost.
Liked 2,802 Times
The Light & Motion Urban 350 is down to around $30-35 now. Hard to beat that value with any farm rigged flashlight and mount.
Even better, for folks who need more runtime per charge. the upgraded L&M Urban 500 is now available in a Rando version with double the runtime over the original: 3 hours on high, 6 on medium, 12 on low and a full day or longer on pulse. About $65 on Amazon.
No need to fuss with extra batteries -- which I've done with my Serfas SL-255, which uses a pair of AA batteries. That light isn't a bad value for $20 or less, which includes an excellent mount. Maximum output is 255 lumens, adequate for some purposes. Main problem is the narrow beam, which I actually prefer for the MUP at night to avoid blinding oncoming cyclists and pedestrians. But it's a bit narrow for rural rides. I might buy another if the price drops to the lowest I've seen, around $14.
Quoted: 2281 Post(s)
Liked 1,710 Times
On my beater mountain bike, it had a front white reflector mounted on a bracket attached to the brake calipers. I simply removed the reflector, bent part of the bracket horizontally, and mounted a bright LED flashlight to it using a hose clamp. It does look a bit ghetto but it works, and this bike I rarely ride after dark anyway, just wanted something just in case I did get caught out after dark on it.
Quoted: 7 Post(s)
Some recent info about lower-cost bike lights can also be found here. In this post you'll also find a good video about beam patterns and comparing them. I'm a fan of the newer lights made for bikes since most of them have a decent beam pattern, are waterproof (or very water resistant) and as others noted, are not far off from the cost of flashlights.
Arizona Dessert
Liked 2,169 Times
I've yet to find a bike headlight with beam pattern that allows for under bar mounting.
Quoted: 1814 Post(s)
Liked 923 Times
I have Light & Motion, Lumina, Blackburn, Cateye, & Chinese cheapo lights
that have round beam & don't care how they are oriented. The L&M ones in particular mount well under the bar.
Arizona Dessert
Liked 2,169 Times
What I meant was a 'designed/shaped' beam vs. the circular provided by flashlights. (context is the post immediately proceeding)
Perspective
By stacking 2 threadless stems , you can add a piece of tubing in the lower one, and put a handle bar battery headlight on it
right side up but still under the handlebars..
there are specialty dynamo headlights made to be bolted on front racks under the big bags Brevet riders love, Designed to be fitted upside down....
Arizona Dessert
Liked 2,169 Times
Yeah, no. I am looking for the minimal, not extra stuff hanging off of bike or other compromises.
Liked 2,464 Times
@noisebeam, what, specifically are you after, and what is the context? I bet it's possible, some-kinda-how.
Arizona Dessert
Liked 2,169 Times
I've been using flashlights as headlight for well over a decade.
But I have been told that proper lights have a beam pattern that is much better so I looked into them and found they all mount on top of bars.
So I wondered if they all were like this or if some allowed for under bar mount.
if not I will continue to use flashlight.
bumm.de/en/products/akku-scheinwerfer/parent/164/produkt/164bla-silber-164bmla-schwarz.html
bumm.de/en/products/mehr/produkt/470lh.html?
lupine-shop.com/en/led-lightsets/helmet-and-bikelights/1487/sl-a4-international
lupine-shop.com/en/led-lightsets/helmet-and-bikelights/1653/sl-af-7
monkey-link.com
sks-germany.com/en/products/ml-bracket-1-humpert-ergotec-swell/
sks-germany.com/en/products/ergotec-vorbau-swell-x-ml/
sks-germany.com/en/products/lumotec-iq-x-e-ml-150-lux-connect/
sks-germany.com/en/products/ml-m99-mini-pro-connect/
shop.supernova-design.com/shop/product/m99-mini-pro-25-for-monkeylink-141
Arizona Dessert
Liked 2,169 Times
Thank you
Dirt Bomb
Quoted: 5465 Post(s)
Liked 288 Times
Really powerful flashlights are dirt cheap. But I do like the beam pattern better on bike lights.
Quoted: 980 Post(s)
Liked 776 Times
Pros: none; other than satisfying some weird urge to be cheap about your personal safety?
Cons: a wax candle attached to your helmet(assuming you splurged for a helmet)is much cheaper and almost as effective.
Bikes: Tern D7e
Quoted: 23 Post(s)
Liked 5 Times
Some bike lights have a remote battery while most are integrated. Try to get one with the battery compartment that is sealed against humidity and moisture.
To reiterate, a bike light has a beam spread or pattern for the road, not a powerful spotlight beam that is like a laser beam to drivers and pedestrians.
Flashlights could blind dogs and kids and cause them to walk in front of you causing injury.
Flashlights may vibrate more, because of their length and weight while bike lights are light and compact, normally. There are dedicated flashlight brackets like Fenix that minimize vibration. There are headbands that hold flashlights on your head or helmet. There are headband lights of varying lumens.
Vibration in time may cause damage to the flashlight while none to a bike light. Vibration may cause the light to jump around on the road and disorient you. Of course, if your handlebar bounces a lot, any light will bounce making it difficult to clearly see the road, but a flashlight may bounce more. There are helmets with integrated bike lights front and back. There are attachable helmet lights for front and back and top. Most lights are blinkable.
Get a white and or red color light only, not blue, green, etc.
The bike light market is big and competitive so, why use a flashlight unless mobility or dual purpose is your bag.
If you get a light with button batteries, dont fret. You can get them cheap online, but watch any big shipping costs added after you Commit. This is dishonest in my opinion. You may be able to cancel after you panic.
Quoted: 507 Post(s)
Liked 237 Times
I've been using various flashlights for years because I didn't commute at night all that often and never bothered to spend money on a proper bike light. I use a rubber/velcro mount, have never lost one. A lot of the problems of flashlights - like floppiness, aim, unshaped beam - have been addressed and yeah, they are annoying. One thing I like about a flashlight is that I can remove it from the handlebar and then use it in my hands. However, I plan on getting a proper light with a shaped beam - like a B&M Ixon Core - once I start riding again. It's just more convenient and a proper tool for the job.
