Go Back  Bike Forums > Bike Forums > Recreational & Family
Bike for Family Man
Recreational & Family Ride just to ride? Have a family and want to get them into cycling? Drop in here to discuss recreational and family cycling issues.
Bike for Family Man
Old 06-30-20, 10:36 AM
phogi
Bikes: Specialized Singlecross, Trek 720
Quoted: 9 Post(s)
Bike for Family Man
Hi All,
Need some bike recommendations. I'm a 40 year old dad with two young kids (3 and newborn). I have a Specialize Tricross single speed but its not ideal for hauling a kid on the back--too tippy and twitchy.
Looking for something more stable under load, and capable of front and rear racks, possibly paniers if we end up doing longer rides or even doing an overnight bikepacking when the kids get old enough. If possible I'd like something with a Nexus 7, as being able to shift at a stop while loaded seems like a key advantage. However I'm not interested in the "hauler" bikes as they seem very specialty and could not be used as a regular bike in the future.
I've looked at touring bikes like the Trek 520 and similar, city bikes like the Loft 7i, and the "fitness" bikes being marketed by the major companies.
What would you recommend I should be looking at?
phogi is offline
Old 06-30-20, 10:40 AM
phogi
Quoted: 9 Post(s)
I should add that I'd like the bike to be able to haul one of those kids trailers that makes it like a tandem, and also be able to haul a trailer for a kid (though probably not at the same time).
phogi is offline
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times in 240 Posts
Is there a reason you are looking at a 7 spped rather than 8 speed igh?
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Old 06-30-20, 12:01 PM
phogi
Quoted: 9 Post(s)
Nexus has a 7 speed hub, and I don't think I'd want an old 3 speed.
phogi is offline
Old 06-30-20, 12:24 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,024 Times in 723 Posts
If budget isn't too much of an issue I'd go with a Soma or Surley frame and build to suit, not certain there's a lot of 7sp only, bikepacking capable bikes on the market. I'd guess you can get in at under 1000.00 since there isn't an amazing drive train to add, just build the nicest wheels possible, an origin8 crank with chainguard on one side to protect pant legs and basic components all around. Should be an easy build. Thinking on simplicity, this https://www.bianchiusa.com/store/git...eed-cream.html
would let you get started really affordably and make the wheels the priciest thing going. You've got me thinking this might be something I do.
One issue I do see is the the trailers often attack to the axle, you may have an issue with that but some you can change the attachment to clamp the frame, if you do that first wrap the stay with a thin layer of handlebar tape, that'll keep the frame safe from the clamp.
Russ Roth is offline
Old 07-01-20, 07:21 PM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
Nexus IGHs also come in 8 speeds. I have one on my Norco.
One advantage to the 7 speed over the 8 speed is the gear ratios of the 7 speed are more evenly spaced. More can be seen on that here. https://sheldonbrown.com/nexus8.shtml
FiftySix is offline
Old 07-01-20, 09:57 PM
hermanchauw
hermanchauw's Avatar
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times in 9 Posts
Mini velo.
hermanchauw is offline
Old 07-01-20, 10:29 PM
Mista Sparkle
Bikes: 2007 Fuji Roubaix, 2018 Trek Marlin 5, Huffy Baron (Retired), Schwinn Twinn (On Deck)
Quoted: 29 Post(s)
Liked 23 Times in 20 Posts
I haven't done any touring, but I have done several longish rides ~40 miles towing my son in a trailer(burley bee) on both a race-ish road bike and a mountain bike. 40 miles with an extra 50 lbs on the road bike is really no problem at all, I'm just 3-4 mph slower for a similar level of effort...
The mountain bike is nice because I can turn around and see behind me, and I have gears to go up hills. I bought it mostly as something different from my road bike to tow kiddos around.
I had been really hesitant to put the bike trailer on the road bike, I was worried about twitchyness and visibility and hills and stopping, but once I had it attached, I found it really quite nice. It is substantially faster and still handles fine. It is a little difficult to see, so if you ride in cities a lot I wouldn't recommend it.
Being Illinois, hills are few and far between, but I have been seeking them out for some intervals towing the little one, and it really isn't too bad. I've never really found myself needing to change gears while stopped, its kinda the same as coming up to an intersection alone, just a little slower to get going. you get used to it quickly.
If I were to do it again (buy another bike for hauling kids), I'd probably get some sort of flat bar road bike/hybrid, but at this point I just use the road bike. Probably the biggest reason to have a hybrid would be to have something similar to my wife more so than some practical reason. Something like a touring bike would also likely be excellent and be upright enough for good visibility, and with something other than a close ratio cassette.
I have no experience with a trail-a-bike yet, but I just picked one up, as well as a tandem, so I can tow my wife, and 2(-3?) kids and not accidentally drop them...
In general I would look for a bike that fills a hole in your N+1 equation, perhaps something that meets your touring oriented needs, instead of focusing on something to haul kids, because it will likely be excellent at hauling kids anyway.
Mista Sparkle is offline
Likes For Mista Sparkle:
Old 07-02-20, 11:41 AM
FiftySix
I'm the anecdote.
By the way, another benefit of the IGH bikes besides the shifting at a stop is the single speed type chainline. That 1x1 sprocket configuration essentially eliminates the likelihood of dropping a chain while riding.
I haven't kept up with Nexus 7 or 8 speed hub bikes in a while, but I can't think of any that are of the drop bar/touring variety. Most that I remember are urban/commuter/hybrid type bikes, not unlike that Loft 7i. Here's one that looks like a more classic styled version of that Loft, no first hand experience with Linus, though. https://linusbike.com/products/roadster-7i
Not sure if you can buy a new Norco locally, but the Indie 8IGH is the much changed successor to my Norco.
One that was really interesting in a MTB/BMX mixed with an urban bike style was the Electra Super Moto 8i. But it seems like it had a short production run as it's not on Electra's website for 2020 anymore.
FiftySix is offline
Old 07-22-20, 07:12 PM
Sladester2
That looks awesome
Sladester2 is offline
Old 03-08-21, 09:46 PM
NRissy
Bike-train
Bikes: Santana Encore Tandem, Trek 3900, Marin MTB, Marin Road bike.
Quoted: 14 Post(s)
Liked 28 Times in 19 Posts
I have an older Trek 5700 Mountain bike that I tool around town with the kids. I picked it up used for a great price. I have my nice 29 and a road bike for those occasions. My five year old rides his weeride copilot attached behind me and his 2 year old brother rides in the trailer behind him. I pull about 100lbs but it's a great work out up and down the hills around here.
NRissy is offline
Old 03-09-21, 09:12 AM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times in 339 Posts
Originally Posted by hermanchauw
Mini velo.
Is it possible to have any additional atrocities configured on this abomination? So much wrongness in one place.
AdkMtnMonster is offline
Old 03-09-21, 01:05 PM
nathand
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times in 62 Posts
If an internally-geared hub isn't critical, consider an older (mid-90's) steel mountain bike. I'm about your age and have 2 kids (3 and 6) and have used a mid-90's Trek 820 for hauling my kids around. That bike has low enough gears for towing two kids up a hill, an indestructible frame, eyelets if I did want to mount a rear rack (although I had one and had to remove it because it interfered with the hitch for the Weehoo trailer), and is stable with an upright riding position for good visibility. Sadly my 820, which I'd had since high school, got stolen, and I replaced it with a slightly nicer but inexpensive 930 found on Craigslist. A used bike like this is cheap enough that you won't have invested much if your needs change as the kids get older. Here's photos of one 2-kid configuration. I also have a Burley Bee two-kid trailer borrowed from a neighbor.
nathand is offline
Likes For nathand:
Old 03-09-21, 04:32 PM
NRissy
Bike-train
Quoted: 14 Post(s)
I have a similar set up except I have gone with the weeride copilot and a trailer as I don't like the child riding with me on my bike. Here is my set up:
The only problem I am running into is the fact that either I am going to fast for my son to peddle or the hill is too steep for his little legs to do any good!
NRissy is offline
Likes For NRissy:
Old 03-19-21, 02:22 AM
Prodigy4299
Prodigy4299's Avatar
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Quoted: 26 Post(s)
Liked 35 Times in 21 Posts
I will echo what the others have written. I use my 30 year old MTB bike converter to a 'hybrid' set up to haul the kids either in a child seat, a Thule Chariot, or both. I don't know if it's just me, but using my beater bike for this makes it a lot less stressful than if I was using one of my 'nice' bikes. Will the child seat frame attachment leave scratches on the frame? I don't care. And my bike has fallen over and scratched more than a few times when I am putzing around with the kids in the Chariot.
One last advantage: when we go somewhere and have to lock up the bike and wagon, I only worry about the wagon. The bike itself is functional, but largely worthless to a thief (scratched up frame no decals, etc.).
Prodigy4299 is offline
Likes For Prodigy4299:
