Odometer for Catrike Villager
Quoted: 34 Post(s)
Liked 12 Times
My wife has a new Catrike Villager that she has been riding for a couple months. Naturally, she would like to keep track of the mileage she
rides (near daily).
Anyone know of a decent odometer (computer) for a Catrike Villager, nothing fancy just to serve that basic function? Appreciate
any and all suggestions.
Have a great day,
Scubaquarius
rides (near daily).
Have a great day,
Scubaquarius
Quoted: 1572 Post(s)
Liked 643 Times
I think that the trend is to using a phone app.
Mrs, Grouch and I use the most entry level Garmins that I could find. I like them because there is no wheel size factor to measure and we can switch them from bike-to-bike if we like.
Likes For Retro Grouch:
Bikes: Catrike Road
I use this on my iphone
Map My Ride. It’s accurate, can be used while walking, pauses, and shows the route. I have NOT found a way for it to do cumulative miles. However, it does allow you to take a pic of the info.
Gobent
Gobent
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
I use the Wahoo sensors (Cadence and Speed) and their phone app. The Wahoo app will record each and every ride locally on your phone. If she wants, she can add a heart rate sensor to get a better idea of workout intensity.
Be sure and get a phone mount that is the correct size for the phone / case. One of my phone mounts has dropped my phone, which is double plus ungood. Also, I have had the Wahoo cadence sensors come out of the Wahoo supplied mounts several times. They are now wrapped on the crank arm with a big gob of electrical tape.
Quoted: 626 Post(s)
Liked 701 Times
If you go to the MapMyRide website, you can see weekly, monthly, and yearly totals, so it can and does track your cumulative miles. There's probably a way to access that info on the app, but I don't bother trying.
It is hard to beat a basic Cateye, et al, bike computer if all you need is speed/distance. You can get them for under $20 and sometimes under $10. The only problem with them is that you sometimes have to be inventive to get them on bents in general. Wires can be too short and brackets that might be built to go on an upright fork might not work a trike kingpin. My solution usually involved soldering extra wire and mounting the sensor to the rear wheel. One thing to be aware of is that Cateye wires are hair-thin and can be very hard to solder and seal.
My current solution is more expensive. I have a Garmin. The advantages are that it can easily mount on whatever bike I choose to ride, so only one is required, and I get a LOT more info. The disadvantage is that batteries now have to be recharged between rides instead of being changed every other year.
Bikes: There is always room for one more.
Quoted: 184 Post(s)
Liked 389 Times
I've been using Planet Bike cyclometers for almost 20 years now. They have an easy to read screen and they are easy to program. Also, they sell extra wiring harnesses for $14 that come in long and tandem lengths which are handy for recumbents. I did try one of their wireless versions but didn't care for it much as it didn't seem to be as accurate as the wired versions. Also, the sensor must be within 21 inches of the computer pretty much limiting them to DFs.
Don
Don
Quoted: 523 Post(s)
Liked 229 Times
According to the information at Utah Trikes, the Villager comes with a "left mirror/computer mount". You are expected to mount the computer on the left mirror stalk. That puts it in easy distance for using a standard length wired computer. Even the most basic models will keep track of your cumulative mileage, a daily mileage, maximum speed and average speed for the daily mileage. All it takes is pushing one button at the beginning of each day to reset the daily mileage and elapsed time. I've given away a few of these inexpensive Sunding computers in the past and never got a comment they didn't work or weren't good. https://www.ebay.com/itm/154141550217 $8.45 from a California seller on eBay. The same computer imported from China with about a 3 week delivery time is $4.64 https://www.ebay.com/itm/132311786303 I usually buy from the overseas source when I buy them as gifts.
One strange thing I encountered was trying to use a wireless computer on my CT700. It wouldn't work with the computer mounted high on the trike next to the front derailleur and the sensor on the sensor mount supplied by Catrike with the trike. Apparently the frame was right in the way for blocking the signal as the computer works perfectly well on a mountain bike.
A little fancy but I'm a fan of Garmin Edge GPS computers. It's more future proof than a standard speed / cadence wired computer. You can connect heart rate, power meters, and other devices via ANT+ and bluetooth. If it happens to drop and break, you won't be without your phone.
