Removing spacer rings from Taxc Neo 2T
Bikes: Cannondale Supersix Evo Disc Ultegra 2020
So, my sons HUP CC road bike chain rubbed up against the body of the Tacx Neo 2T when in the chain was in the largest cog. So I took the cassette off and added two spacer rings. That fixed the rubbing but now he can't engage his smallest gear. I don't really want to re index his gears as I'll have to re index again when he wants to ride on the road. So, I want to remove one of the spacers. But how? I got the cassette off. I took the bushing out behind which the spacers were inserted. But they're very snugly in there. I tried turning the body of the trainer to the side and gently give it a tap, but I suspect the grease is holding the rings firmly in. Any advice? I just want to remove one of the rings.
Randomhead
Liked 3,697 Times
I'm confused about where you put spacers, but I don't have one of these trainers. Can't you gently pry it out with a knife?
