Show us your Vintage Touring bikes
Old 02-08-21, 02:40 PM
  #2451
Cycle Tourist
Quoted: 195 Post(s)
Liked 207 Times in 126 Posts
Originally Posted by casanewt
Not as nice? That thing is gorgeous!
Aw. Thanks. I think I suffer from a inferiority complex because of the centerpull brakes and the straight gauge tubes. I've always found the centerpull brakes to work just fine and the straight gauge tubing works better for me on tall frames when fully loaded, still though.😀
Cycle Tourist is offline
Old 02-08-21, 08:30 PM
  #2452
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,699 Times in 935 Posts
Originally Posted by Cycle Tourist
I had spenco brake lever covers on my first Univega touring bike. Here's a earlier 610, '62 I think. Not as nice as the '65 pictured earlier.
Do you mean 82 and 85?
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 02-16-21, 02:11 PM
  #2453
Prowler
Quoted: 472 Post(s)
Liked 1,028 Times in 404 Posts
Road worthy again
This is the bike I've used for the GAP, the Pine Creek and several other lovely rides. Twice packed like a mule and several times running free. Last summer on the Pine Creek trail it rained over night and this old thing looked pretty sad the next morning. Paint a bit milky looking and bits of rust here and there. Time to do something better than when I first rehab'd it. So last October I took it all apart, all the way down. I cleaned the f/f real well, cleaned off any rust then set to coating it. I decided, since I had the stuff and had all winter, I'd apply numerous very thin coats of boiled linseed oil (aka BLO). I cannot recommend this to most people as most would just want to get the job done. I didn't care. Had all winter so did 2 or 3 film coats a week, every week on into December. No idea how many. None of the coats took much time. I did thin the BLO with about 20% mineral spirits which speeded the drying of each coat. I then hung it in the garage for another month.
The paint looks much nicer now, deeper color while preserving all the nicks and scratches of 25 years serving mankind. BLO has a long history as the base for paint and I've seen good durability on other outdoor usage. Now its fully re-assembled. I had the rear fender but recently fabricated the F fender (saved from the dump). Used contact cement to re-fix edges of the saddle cover that had come loose. Various other wee things that need attention. In the dead of winter I can afford to be pretty picky.
It's been here before but I thought the Voyageur fans might like to see the latest config. Now to await the end of the recent "snow train" and the arrival of spring.
Prowler is offline
Old 02-16-21, 04:50 PM
  #2454
squarenoise
squarenoise's Avatar
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times in 105 Posts
I just posted this in the Miyata 1000 thread with more details, but figured I'd share here as well.
squarenoise is offline
Old 02-16-21, 06:18 PM
  #2455
eom
Eccentric Old Man
eom's Avatar
Quoted: 248 Post(s)
Liked 173 Times in 87 Posts
That is sweet.
email:
bikeforums@protonmail.com
eom is offline
Likes For eom:
Old 02-16-21, 07:45 PM
  #2456
The Golden Boy
Really great job! Super classy lookin' bike!
Likes For The Golden Boy:
Old 02-17-21, 09:56 AM
  #2457
Kobe
Kobe's Avatar
Quoted: 276 Post(s)
Liked 339 Times in 179 Posts
First think that jumps out at me when I look at this is, look at that great fender line!
80 Mercian Olympic, 92 DB Overdrive, '07 Rivendell AHH, '16 Clockwork All-Rounder
Kobe is offline
Old 02-17-21, 11:13 AM
  #2458
Het Volk
Quoted: 192 Post(s)
Liked 145 Times in 78 Posts
Originally Posted by ctak
Recently sold my 1983 Centurion Pro Tour 15, but have an album to remember it by: https://flic.kr/s/aHsmTX9UXw
Pro Tour 15
Why would you sell that?
Also - the lacing on those wheels seems less loaded touring oriented and more racing oriented.
Het Volk is offline
Likes For Het Volk:
Old 02-17-21, 05:52 PM
  #2459
ctak
ctak's Avatar
Quoted: 170 Post(s)
Liked 264 Times in 146 Posts
I used this sporty thing mostly for "spirited" 40-70 mile efforts over mixed surfaces with areas of dilapidated asphalt, for which the longer chainstays and relatively flexy .9/.6/.9mm tubeset helped to smooth things out. For multi-day loaded touring, I'd probably look for something heavier duty with 45-50mm tire clearances and, as you pointed out, a proper wheelset.
The frame was a little small for me, unfortunately. I've since moved up to 24"/61cm.
ctak is offline
Old 02-17-21, 07:34 PM
  #2460
polymorphself
Quoted: 838 Post(s)
Liked 1,080 Times in 521 Posts
IFor multi-day loaded touring, I'd probably look for something heavier duty with 45-50mm tire clearances l
Assuming lots of gravel or you just prefer that size tire for loaded touring?
polymorphself is offline
Old 02-18-21, 02:57 AM
  #2461
ctak
ctak's Avatar
Quoted: 170 Post(s)
I just prefer a wider tire for carrying 40-lbs of gear for days on end along highway and back-road shoulders. Not to say that 38mm Schwalbe Marathons on a Pro Tour with the right rims (or Voyageur ) wouldn't make the grade..
ctak is offline
Old 02-18-21, 01:22 PM
  #2462
Germany_chris
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
Some Changes
Germany_chris is offline
Old 02-19-21, 02:11 AM
  #2463
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 885 Post(s)
Liked 990 Times in 522 Posts
Originally Posted by Germany_chris
How do you keep that tape on the top tube?
bwilli88 is offline
Old 02-19-21, 04:47 AM
  #2464
Germany_chris
I’m a little Surly
Quoted: 699 Post(s)
Shellac and twine
Old 02-19-21, 07:10 AM
  #2465
The Golden Boy
That looks really nice- what is your gearing front/rear?
Old 02-19-21, 07:17 AM
  #2466
Germany_chris
I’m a little Surly
Quoted: 699 Post(s)
24/36 and 11-34
I just recently did the chainring swap 22/34/44 wasn't working 34 was too small for daily use and 22 was just too small. I'll find out this weekend if I like the 24 if not I'll head back to Amazon for a 26
Likes For Germany_chris:
Old 03-14-21, 09:44 PM
  #2467
Cycle Tourist
Quoted: 195 Post(s)
Boy, If that's not the best looking, unbreakable touring bike I've ever seen, I don't know what is! If your goal was perfection with a touch of personality, I'd say you made it.
Likes For Cycle Tourist:
Old 03-14-21, 10:03 PM
  #2468
Cycle Tourist
Quoted: 195 Post(s)
Originally Posted by sloar
Borderline vintage...
That's full on vintage. Love those old 'dales. I was so envious of anyone that owned one. Thanks
Old 03-14-21, 10:26 PM
  #2469
Cycle Tourist
Quoted: 195 Post(s)
Originally Posted by Hobbiano
A touring bike is a fairly specific type of bike. However, you could tour on any bike, if you wanted to. But is any bike a touring bike? I don't think so. Is a racing bike a touring bike? You could tour on it. Is a touring bike a racing bike? You could race it.
Age old argument. Yeah, a racing bike could be turned into a tolerable touring bike. I'd be a stupid thing to do of course. Anyone could pick up a nearly free japanese frame suitable for rebuilding into into a good touring bike.
My point was only, as you suggested, that you can use any bike for touring. I've seen some very unlikely bikes used for touring successfully. They have one thing in common. They're rugged. The posters hybrid makes a good start in putting together a nice touring bike. Those bars would never work for me. My butt would never support my body without a little more help from my hands. 😅😅
Old 03-15-21, 02:04 AM
  #2470
Germany_chris
I’m a little Surly
Quoted: 699 Post(s)
Thank you
Old 03-15-21, 07:32 AM
  #2471
Hobbiano
Quoted: 394 Post(s)
Liked 346 Times in 230 Posts
Yeah, I kinda agree with you. But the title of the thread "Show us your vintage touring bikes" suggest vintage touring bikes not just any old bike that you could tour on, doesn't it?
Hobbiano is online now
Likes For Hobbiano:
Old 03-15-21, 09:53 AM
  #2472
DQRider
Old Boy
DQRider's Avatar
Quoted: 984 Post(s)
Liked 1,715 Times in 611 Posts
What if your bike is a high-end, hand-built Italian, geometry more like a race bike, but the model name on the NDS chainstay says "Special Touring"? It seems to me that the only distinguishing factor that makes this a "touring" bike are the eyelets for either fenders or racks. But you can't have both.
USMC 1981-1991 Semper Fi!
DQRider is offline
Likes For DQRider:
Old 03-15-21, 10:43 AM
  #2473
Germany_chris
I’m a little Surly
Quoted: 699 Post(s)
Touring bikes use heavier tubing, generally have shorter top tubes, longer chain stays, slacker angles and room for bigger tires. Lots of bikes particularly from Europe have rack and fender mounts because they’re used for transportation.
Old 03-15-21, 11:08 AM
  #2474
The Golden Boy
You can wrap a rag across your fingertip and call it a "toothbrush."
Old 03-15-21, 07:22 PM
  #2475
Hobbiano
Quoted: 394 Post(s)
Sport touring? I don't know but that's a sweet bike. Looks great in blue.
