Any tall folks (6'7"+) have a Surly Long Haul Trucker?
'roid monkey wannabe
Bikes: I have a custom 2006 Zinn magnesium frame road bike set up for triathlon and a big semi-custom touring bike, the frame of which is a 1983 Apollo Prestige XL.
I was upset that I couldn't buy the venerated LHT frameset for myself because I am too tall...or so I thought. Then, just yesterday, I met a guy who is 6'7" and has a LHT! He had the 62cm sized frame of course and what looked like an aftermarket fork with about 4" or more of steer tube sticking up above the top tube (with spacers around it bien sur). The guy said he had about 5'000 kms on it with that setup and no problems yet but I was a little skeptical about the safety of such a long section of steer tube above the head tube. Has anyone here seen a similar setup that worked well and had more miles on it?
Also, does anyone here know of a LHT owner with crank arms longer than 175mm? I prefer longer cranks and want to know if it's possible to put longer ones on without affecting the clearance in turns too much.
Thanks in advance for the info
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
Not that it's a spot on comparison, but I'm 6'6" and I ride a 62cm Cross Check. I put a slightly shorter, taller rise stem on it to keep from going with the "5 inches of spacers" solution; but you do what you gotta do sometimes...
The LHT already has a pretty low bottom bracket, so I don't think I'd go with anything over a 175mm crank. I've got 175's on my X-Check and twice I've had some pedal strike issues when I'm not paying attention.
atop a blazing saddle
I'm only 6'2", but my 58cm LHT fits me well. A 62cm frame might be fine for a 6'7" person, but there's only one way to find out. All complete LHTs come with extra length on the steerer tube. This is to allow the rider to have it cut to fit. If you don't need any cut, don't cut it.
Hmm, okay well thanks for the info guys. It sounds like I'd better stick with a custom bike then because 175mm cranks just won't do. Nor do I want to drop mad cheddar on some hokey looking bike.
Oh and trust me, 6'2" is so much different from 6'8". If you can buy slothes off the shelf, I don't expect you to understand.
Quoted: 5 Post(s)
Liked 7 Times
6'6" isn't too much different from 6'8" except for a bike fit, in that I can usually squeak by with the largest off-the-shelf items. Maybe ask Mazama about the custom fit process for his bikes. I think he's over 7' tall, and would have a better knowledge of the process.
Year-round cyclist
I am 8.5 inches shorter than you, but regarding the fit, a lot depends whether you have long legs or not. Their top tubes are long compared to, say, the Cannondale or Trek touring bikes, so if your legs are long, you might very well find it OK once you get a long seatpost and stem. On the other hand, if your trunk is really long, then you'll run out of top tube.
As for bottom bracket height vs 180 mm cranks vs clearance in curves, I have a Trek 520 which has similar BB height. In a nutshell, you will be OK unless you like to turn aggressively at high speed and/or ride with feet pointing down.
i've tried many different frames, and to get what i wanted, i had to get a custom, i use 185 cranks, and got tired of hitting toe ground, etc. Being 6'8" has it's problems, and trying to "get by" just makes it worse. Good luck!
Yeah Amen! I think I'll just get a Naked frame and forget all the nonsense. Besides, the LHT only comes with 700c wheels in the larger frame sizes and those are too hard to find out in the boonies.
Forgive the resurrection of an old thread , looking to hear from somebody running 180 cranls on an LHT / DT ? bit too low or ok?k
