For the love of English 3 speeds...
Quoted: 457 Post(s)
Liked 462 Times
Yep, I don't have the proper tool, but I've debated making one from scrap metal with my welder, but all in all a punch has always done the job with so little hassle that I haven't taken the time to make a proper tool, if I end up with a hub that won't open up with a punch I'll make the tool... I have always dealt with hub that were in wheels though.
What do you guys use to dismount the ball ring on the later Sturmey AW hubs that don't have a vise flat on the shell? Older hubs let you use a vise on the shell and punch on the ball ring to open up the hub. But what are you using for the later hubs that lack vise flats on the shell and have the smaller notches on the ball ring? Is there a circle spanner or c-spanner that works for these? The punch method is more troublesome on these later hubs from the 1960s and 70s.
I also have several wrenches that fit the various ball cup styles. One is an older OEM Sturmey Archer spanner wrench, one is branded 'Brampton' and fits the entire circumference of the typical two notch ball cup, and several others appear to be made from 3" pipe couplers which have been machined to fit like a socket over he ball cup, with a hole through the middle to put a bar through.
I found a socket at another shop that appears to have been a 4x4 hub socket that's been modified by grinding off two pins with a bit of metal taken out of the ID of the outer edge of the socket as well.
Not sure what the original application was but the socket has been modified slightly in both ID and the removal of two pins. This works well also when the hub is in the wheel, some flat spanners won't allow the pins to engage the ball cup without spoke interference.
Later OEM style for rounded indent ball cup.
Likes For barnfind:
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Toronto Update
Scanning some recent Kijiji listings
1954 Project bike listed at $115.00
70's 3 speed at $150.00
A good looking Superbe @ $250.00
Another 1954 listed at $395.00 (bit of a stretch)
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
Those blocks are a good idea. I probably could make a set up using a compass, jig saw, and sander. I have a ball ring tool on-order with Gentleman Cyclist.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
The wood blocks work great, there's actually four sets of them, one for the AW and similar size hubs, one for the SW, pne for the Sears/JC Higgins hubs, and one for Shimano. The blocks are thin enough to not interfere with the oil port, but I tend to remove them just in case anyhow.
I rarely use the SA spanner, its faster and easier to just tap the ball ring loose with a brass bird's mouth punch. I only use the 145 wrench on the newer hubs with round indent. I've never had a hub that these didn't work on, even a few rusty disasters still came apart just fine.
To make life easier, I tend to break loose the ball rings while still in a wheel but lately I've run into quite a few loose hubs that need to be torn down for parts or rebuilt.
The wood block shown above has been in my tool box here now for over 20 years. I found them all at a very old bike shop that I cleaned out in the late 90's.
All four appear to have been made from one length of old true dimensional 2x4 lumber. When tightened around a hub, there's about a 1/4" gap in the seam. The hub shell should be clean so as not to scratch the chrome. The original rubber looked like a piece of heavy inner tube, I've since replaced the rubber a few times with a piece of EPDM roofing rubber. I usually just wrap the rubber strip around the hub and place the blocks over the hub and tighten it down in a huge vise. The rubber is on both sides of the hub.
I've got a similar tool that's made from hardwood that's basically the same thing but the halves are secured with two bolts and two wingnuts and the one end of the wood is about 3ft long, eliminating the need for a big vise.
Its loaned out right now, but here's a rough idea of what it looks like.
Liked 443 Times
No computers needed.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
That '54 looks interesting, because I think it's earlier than the license plate. The Dyno has a bakelite face , the rims look unblemished (stainless?) and it looks like it might have the rare 3 pin crank although the pics are poor. Those cranks appeared on the early 50's Super Sports.
Not saying it's worth $395 but it's still worth a look-see if there wasn't a bloody pandemic.
Picked up this Raleigh Sport today for just under $100. Bike seems to be in good shape. No rust except a little on the chrome. A few small dents in the fenders and paint scuffs on the frame but nothing major. Cleaned up pretty good. Will need new tires/tubes and brake pads obviously but otherwise I took it out for about a 20 minute ride after cleaning it up and rides really nice. Shifts like butter. Only negative is the Brooks, which seems to be original is ripped pretty bad. It's still actually pretty comfortable but from what I've read a rip at the rivet means this seat is pretty much done for. Which is a shame because besides that big rip the leather seems to be in nice shape.
Also, can anyone tell me what these things are, I'm brand new to the English 3 Speed game.
1. Black strap around the rear hub.
2. This small bracket or whatever attached to the front axle.
Likes For partyanimal:
Liked 443 Times
Looks like it might be a Made in Canada version.
There could be a small sticker on the downtube near the BB.
The colour is a bit different than English versions.
I have the same bike and it's my go to work bike.
Liked 443 Times
That little bracket on the front axle is the remains of a Lucas odometer.
Likes For gster:
Quoted: 809 Post(s)
Liked 1,022 Times
The leather strap on the rear hub is a hub shiner. It mops up oil, and makes the hub shiny. They used to be the thing to have back in the day.
I've been sorting through several buckets of old used SA hubs here from a clean out, and nearly every one that had a hub shiner has its chrome worn away or dulled where the thing sat and rubbed the hub mile after mile for years on end.
I'm seeing a few that were leather, a few just cheap plastic with a reflector and nut holding the ends together, and even a few with just a piece of rope tied around the hub with a knot for weight.
The best hub shells I'm finding are those that were left all covered in grease over the years, once you soak off the dried up grease and dirt, the chrome is like new underneath almost every time. Just the same, those that were kept polished and clean are pitted with rust.
Likes For 2fat2fly:
Bikes: 1951-2 BSA 900E Roadster, 1961 Triumph Sports, 1953 Raleigh Sports, 1981 Raleigh Superbe, 1976 Raleigh Twenty, 1951 Taxandria, ±1950 The Gold Lion Tandem
Quoted: 40 Post(s)
Liked 14 Times
JIMBO53 Really nice bike and will clean up very nicely. As an ex-owner of a BSA motorcycle would have loved a bike like that.
Peter
Liked 443 Times
I did find a good supply of rod and lever brake pads.
10 pesos each!
They had a full case of them.
Likes For gster:
Quoted: 887 Post(s)
Liked 335 Times
gster was a cyclist, boys
His bike was made of polished steel
He searched for parts around the world
To fix the bikes he had to heal
gster met his match, you know
On the deserts down in Mexico
Nobody heard his cryin' words
Oh, but that's the way it goes
All the LBS's say
They could have conned him any day
They only let him slip away
Out of kindness, I suppose
Lefty, he can't braze the tubes
All night long like he used to
The parts that gster bought down there
Ended up in Lefty's lair
The day they lay poor gster low
Lefty split for Ohio
Where he got the parts to go
There ain't nobody knows
All the LBS's say
Mechanics tell how gster fell
And Lefty's livin' in cheap hotels
The desert's quiet, bike shop's sold
And so the story ends, we're told
gster needs your prayers, it's true
Save a few for Lefty, too
He sold the shop - he had to do
And now he's growin' old
All the LBS's say
Likes For dweenk:
Liked 443 Times
gster & Lefty
All the LBS's say
All the LBS's say
All the LBS's say
All the LBS's say
All the LBS's say
All the LBS's say
Clever and thoughtful.
One of my favourites.
Townes Van Zandt version.
customised with dinosaur and magic pony stickers
Quoted: 887 Post(s)
Liked 335 Times
Thank you for that.
https://www.youtube.com/watch?v=zprRZ2wFQD4
Here's my $25.00 Mexican guitar
Likes For dweenk:
Phyllo-buster
Liked 2,054 Times
Thanks for that clip. I miss videos(sorry, films) shot in Super 16. I used to do scratch removal on 16 mm before HD reared it's bulldozer head.
Likes For clubman:
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 589 Times
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 463 Times
Liked 443 Times
Liked 443 Times
This is cool. Late '40s Super Sports? I think they only made them a couple of years before the Reynolds 531 models came along. Looks like either an AG or FG hub in the back and the lamps are all there as well. Too small for me, but that blue is tops. Since I have a '50 and my wife a '56, my years of hunting these down are over, but I perk up whenever they come out of the woodwork. This one needs some time and elbow grease by the looks of things.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1296 Post(s)
Liked 939 Times
The same thing happened to my B72, soon after I bought the bike. The saddle was the 1961 original. A chunk fell off when I tried to attach a saddle bag.
Standard Member
Liked 939 Times
1962 Rudge Sports with brand-new, unused Brooks Flyer S saddle and Carradice Pendle saddlebag
