1985 Raleigh (USA) Alyeska
I can't take credit for that one. I've seen it on many other bikes and it's a good use for partial rolls of tape. It's yellow Tressotar with two coats of amber shellac. As you can see, it's about as close to Brooks honey as you can get with cloth tape.
Albatross bars are cool!!
Bikes: 1984 Cannondale ST; 1975 Raleigh Grand Prix; mystery Nashbar tandem MTB; 1991 Paramount Series 20 PDG (in bits); 1984 Raleigh Record (in smaller bits, needs dropout repair); 1985 Raleigh Alyeska (wrecked, needs downtube repair)
Quoted: 11 Post(s)
Liked 11 Times
Well, I seem to have figured out why my chain has been constantly jamming when I tried to shift, and sometimes even when I tried to backpedal. I tried a new Nashbar/Microshift rear derailer I'd bought for another bike that shifted splendidly with an APII cassette and chain, and it shifted very well with this combination as well. That ruled out the bushed chain and pre-HG freewheel as major headache producers - logically enough. Since there's nothing really all that special about the Microshift derailer that makes it hugely better than an '80s model, I had another look at the original one. Turned out I'd reassembled it wrong when I'd had it apart to try to figure out why there was no tension on the lower jockey pulley, and the chain had actually worn a groove into the shaft of the tee-nut thing that holds the cage on, because I had installed it backwards. D'oh! I fixed that and reinstalled it, and it seems to be working much better now.
Don't feel bad, I think we've all done similar things from time to time. My usual is getting the brakes all setup perfectly centered, good cable length, etc... After I'm all done, I find the caliper quick release was open the whole time D'oh!,,,,BD
So many bikes, so little dime.
If I had a nickel.......
missing in action
Quoted: 42 Post(s)
Liked 49 Times
It was the entry-level touring model, but it's a nice ride and lighter than I expected it to be. I suppose it would be described as a sport tourer if it were marketed today, but Raleigh didn't advertise it as such in the catalog.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Hard to tell according to the 1985 Raleigh Catalog there were 4 touring models with the Wyoming being the entry level, Alyeska and the Kodiak being the middle of the line with the Portage being the fully loaded ready to roll one. Unfortunately no geometry specifications are given.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Quoted: 7348 Post(s)
Liked 2,470 Times
That's a good description. I've toured on bikes with sidepull (single pivot) brakes, and they are less than ideal for that purpose. But if you wanted to tour on that model, you'd do fine.
Quoted: 11 Post(s)
Liked 11 Times
Neat pic of the Wyoming! I noticed from the catalog that that bike came geared pretty tall, that means that even hills would probably be a bear unless the rider was really strong.
Don't know if this helps for comparison, but this frame is a 1984 "Record", a straight-gauge chromo sport-tourer that came with base features like stem Powershifters, safety levers, separate seat clamp, nondetachable chainrings, and steel rims. Oh, and those awful steel rattrap pedals that like to self-destruct. The wheels in the pic are a set of old 700c racing rims with 25mm tires. You'll notice on the next page of the catalog that they listed no less than six sport-touring models!
You gonna eat that?
Quoted: 11 Post(s)
Liked 11 Times
Today I noticed something funny about the brakes on this Alyeska. The holes for the cantilever return springs are on the outboard side of the cantilever stud! I cross-checked with my '91 Paramount MOS, and its spring holes are on the inboard side of the stud. Yet I've seen pictures of an Alyeska equipped with Suntour XC-Pro brakes, which appear nearly identical to the XC-LTD cantilevers that came on my Paramount. Do folks performing such a brake swap have a special trick for making the springs work out?
missing in action
Quoted: 42 Post(s)
Liked 49 Times
I don't have a direct answer to dealing with the springs, but I know that there are some cantilever brakes that don't rely on the hole in the stud base. They have a rotating collar at the base that you can adjust with a cone wrench to set the tension, seems to work pretty well. I believe the Dia Compe and Tektro made such brakes.
Alternately, you could always drill a new hole in the base of the stud.
** Edit - now that I think about it, there isn't any room for a hole on the opposite side of the stud...
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
This is how I went about mounting a set of Pro-Star cantilevers made to mimic the old Mafacs. I believe I wound up putting the right springs on the left side, the left on the right, and inverting all of them; or something to that extent:
At any rate, this works only on the Pro-Stars. Mafac cantilevers will not work without designing a completely new spring.
-Kurt
Quoted: 11 Post(s)
Liked 11 Times
Interesting stuff. On inspection, my XC-LTD cantilevers look like they could be made to work (spring-wise, anyway) by just drilling another hole in each brake part for the spring to anchor in. I also discovered that a set of Shimano Nexave V brakes could have their spring backing plate assemblies swapped side to side, so that the stud that actually engages the spring hole is in Alyeska orientation. Nice to know that there can be flexibility in brake configuration despite the weirdness.
Curiously, testing the V brake led to another discovery - I got the wrong brake levers! Work good with V brakes, work awful with cantilevers. Funny that the eBay seller didn't tell me that. Still, this isn't entirely bad, as I have another set of newer levers that will solve the problem, and then I can stick these levers with the V brakes on another bike.
Quoted: 11 Post(s)
Liked 11 Times
FedEx driver dropped off a package this morning .....
Quoted: 1109 Post(s)
Liked 1,200 Times
Does anyone know if the frame and fork on the various models (Wyoming through Portage) are the same? The catalog linked seems to indicate so.
What is the rear spacing on your Alyeska?
missing in action
Quoted: 42 Post(s)
Liked 49 Times
No, I don't think they're the same. For starters, the Wyoming (bottom of the touring line) has caliper brakes and no mid-fork lowrider mounts. The Alyeska has high-ten stays vs the full chromoly frames of the Kodiak and Portage.
I believe the latter two frames only differ in the wheel sizes they were designed for, but I'm just going on what I've read about those two, I've never had either in my hands.
Quoted: 586 Post(s)
Liked 612 Times
They appear to be Gary bars. I have a set. They are very wide in comparison with most vintage Rando bars, but I like them. They won't fit the existing stem on the Alyeska, as the center of the bar is 31.8. Of course, they might be some other version, but that's what they look like to me.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
Thanks TugaDude, I thought they might be something new. The photo looks like they've got a bit of a randonneur-esque lift on the top, and I thought the Gary's had more splay. I love rando bars, but they're usually narrower than I'd like (though that doesn't stop me from using them.)
I understand that Velo-Orange is making them in various widths now, I'll definitely be investing in some of those...
Large Member
Anybody want another Alyeska? I just found this one on "the Bay". Sweet looking bikes.
https://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MEBIDX:IT
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Liked 2,470 Times
That one on ebay looks really nice. Good thing it's even too small for me!
Quoted: 11 Post(s)
Liked 11 Times
The MKS Lambda pedals strike me as a little funky. They're smaller than I'd expected, and the narrowness will take some getting used to, but I'm hopeful, and I'm looking forward to not always striking pedals in turns and not feeling like my other pedals are trying to cut my shoes in half.
