$16 Cotter Press
#51
Shipping for the Chain Breaker + a tubing bender was $8.99.
#52
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Likes For cudak888:
#53
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
#54
Quoted: 7348 Post(s)
Liked 2,474 Times
Kurt, well put, and of course you're right, but sometimes the wallet won't allow it. I absolutely advocating using the right tool for the job whenever possible. But in the meantime, until I can afford the tool, it's useful to know what some reasonable (or even unreasonable) workarounds are.
Now let me go look for this sale at Harbor Freight...
#55
Bikes: 1973 Peugeot UE-8, 1985 Schwinn Voyageur, 2010 Trek 1.2, 2012 Bianchi Siempre
FYI - if you buy more than one from Harbor, the shipping is not multiplied accordingly. Something to consider for you guys who live close together. I just bought 2 - and the difference in shipping was only $1 -something.
Oh - and they are still on sale.
#56
Liked 2,474 Times
I'm putting an order together now. Anything else from HF I should take advantage of?
#57
Liked 2,474 Times
By the way, I bought this scale, and it gives various readings for the same object, so it turns out to be junk.
#58
Bikes: Fuji Monterey, Schwinn Traveler, Fuji Special Road Racer, Gitane Interclub, Sun EZ-1, Schwinn Frontier, Puch Cavalier, Vista Cavalier, Armstrong, Raleigh Sports, Schwinn Stingray
Amesja, Is it necessary to drill the cup out on this or could you just remove it entirely and have a larger hole for the pin to exit?
#59
Bikes: 1977 Raleigh Super Grand Prix, 1976 Gitane Tour de France
I found another use for this press last night, A guy I work with came over to pick up a bunch of old junk frames and rims for scrap and as he pulled up in front of my house his left front brake line broke off due to rust.
With no parts stores close or open we had to improvise, we tried bending the line over and crushing it down with a vise-grip but even with four fully crimped bends it still didn't want to stop leaking.
Then I had a brainstorm, I ran inside and grabbed the HF press and with a bolt stuck in the one side to provide a flat clamping surface I put it on one of the crimps we put in the brake line and cranked it down tight.
No more leak, he could stand on the pedal with both feet and it was solid, it got him home and he'll replace the brake line this weekend.
#60
Liked 4,395 Times
-Kurt
#61
Liked 2,474 Times
Well, as you may know, I ordered the part a few days ago, because $16 is hard to resist, and $10 is even harder.
However silly using a hammer is, it's still a fun topic to talk about. Maybe it's fun BECAUSE it's silly. It's so satisfying to triumph over the damn cotter after all that manly banging, dontcha know.
Likes For noglider:
#62
Liked 2,474 Times
I received my chain breaker today. I drilled out the small threaded section to allow a cotter to pass through. I don't have a drill press, but an ordinary drill sufficed.
Just for fun, I removed a cotter from my Rudge and put it back in. Yes, this press made child's play out of the job. You're right. I should have gotten this much sooner.
Likes For noglider:
#63
SE Wis
Quoted: 2747 Post(s)
Liked 3,399 Times
Currently on sale for $9.99
#64
Bikes: Surly Trucker
A good fix, in a bind, is a giant c-clamp with a socket. I've taken a liking to an air-hammer with a brass bit lately.
#65
Bikes: Miyata 110, Schwinn super le tour 12.2, Schwinn super sport, Lemond Zurich
when I lived in Denver my LBS had one of those, it was HUGE
#66
This is such nifty idea that I just made up two of these presses - one for myself and one for a friend.
To keep the pusher from falling out, I stuffed a plastic drywall screw anchor sized for a #8 screw over it while it was inserted into the larger bolt. I first snipped off about a third of the anchor. Seems to work. You could probably find a press-on stamped steel nut to do the same thing.
Likes For Three Spires:
#67
Quoted: 786 Post(s)
Liked 520 Times
#68
The Baltimore bike co-op has one of those. A very cool tool. Another reason to support your local co-op.
#69
Bikes: Tons
You can have one for $150: https://www.ebay.com/itm/VINTAGE-VAR-...item23175733b2
Or... you could buy the perfectly adequate tool from HF for $16.
#70
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
The C-clamp method works with an older quality C-clamp. I wouldn't try it with some of the newer cheapo chinese cast C-clamps. Those will snap if you just drop one unloaded onto a wood workbench from more than 12" inches. Drop one on a concrete floor and they shatter into multiple pieces.
the other problem with a C-clamp is the thread pitch. A C-clamp has a very coarse thread pitch of like 6-8 threads per inch where a good press like the wheelsmith or even this Harbor Freight conversion will have something on the order of 25-30 tpi or more. That is just leverage. With more TPI you have a ton more leverage for each thousandth of an inch you need to move the cotter until it gives way.
#71
Quoted: 100 Post(s)
Liked 57 Times
+1. Moved from that to a Sears ball-joint separator, which worked great but left marks on the crank. Finally paid up for the Bikesmith tool and now wonder why I didn't just buy it in the first place. It's the right tool for the job.
#72
multimodal commuter
Liked 574 Times
I have both the Bikesmith tool and the Harbor Freight tool. I really like the former and am not about to make any complaint about it. But there are times when the Harbor Freight tool is better. On my Raleigh Lenton Sports, for example, the Bikesmith tool couldn't get close enough to the chain ring, so couldn't press the drive side cotter out straight, and I'd bent it before I realized what was happening. It should have worked on the other side, but it bent that one over as well. After drilling a guide hole into the remains of those, the Harbor Freight tool popped them both out without further trouble; but I had to grind off the ends of the jaws of the latter so it could get close enough to the chain ring.
I did not modify the pusher of mine; I only drilled out the hole at the receiving end and ground the edges off the jaws. It is not the better tool in most cases, but in really tough cases it is the right tool for the job.
#73
incazzare.
I recently bought the bikesmith tool, and it works really, really well. I was sick of trying to do it with a hammer and failing 50% of the time. I may make one of these eventually too, because as Rudi says, there will probably be times when the bikesmith tool doesn't quite fit.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Likes For lostarchitect:
#74
Bikes: Centurion Pro Tour 15; Trek 1200; Trek 2000; Easy Racers Tour Easy; Nishiki Alien; Kestrel CSX: Motobecane Le Champion; ICE Adventure Trike
I came across this thread about two weeks too late. I recently removed a cotter by using the "hammer, pipe, nail set" method described by Sheldon Brown, and know I don't want to do that again. Thanks for the tip Amesja.
Likes For jeb814:
#75
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
Quoted: 110 Post(s)
I bought a Zinn Vise whip as soon as I could afford one, and will never use a chain whip again! I bought a Precision Instruments dial torque wrench and was astounded how just completely inaccurate "click" torque wrenches are. The funny thing is I've never been in a bike shop that had a decent quality (Precision Instruments or Snap-On Torque-O-Meter which is made by Precision Inst.) dial-type torque wrench. They only have the crappy toy-quality Pedros or Park.
Speaking of getting Hard to find, did you know that Park no longer makes the Third Hand brake tool. I still use cantilevers on multiple bikes and hate disc brakes (I call 'em boat anchors). On eBay the Park third hand tool is fetching a pretty price. If you've got one, hold onto it.
