1970s? Stella road bike
Bikes: 2004 Cannondale Jekyll FS 5"Travel, 1971 Stella, Campy components
Hello,
I recently acquired a Stella road bike from what I'm guessing is the 1970's. It is a 10 speed with mostly campy components, and sun tour rear derailleur. It seems to be mostly original, but there were a few things I wanted to tune up without compromising the bike. I haven't been able to find much about the bike other than it was a French company which made everything from low end to performance race bikes. I'm guessing based on campy components this bike is somewhere in the middle in terms of quality.
The rear brake sticks, is there any harm in replacing brake cable? Also, the tires leak a fair amount of air. They are quite old 700x32c tires white wall tire. I have been hesitant to pump up to recommended psi and blow out the side walls. Is there any harm in getting new tires and tubes? I would keep the ones on it, but i have no idea if they are original or near original as I don't know the history of this bike.
Lastly, the grips are cracked and falling off. Was considering getting bar tape to re wrap? I've ridden mountain bikes for about 4 years, but have never ridden rode bikes much. I plan to use this bike to commute to school and run errands around town. The gears shift well, and I love the extra speed on pavement compared to mtn bikes
Thank you for your thoughts and suggestions
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times
Do what you need to get it on the road.
Post a pic sometime.
Fred "The Real Fred"
All of the stuff you propose is quite normal. Also consider replacing the brake pads, the shifter cables and housings and repacking the bearings.
All of this stuff is consumable, so most people don't consider these modifications harmful. We'd just like to see you back on the road.
Friendship is Magic
Bikes: old ones
Quoted: 26381 Post(s)
Liked 10,357 Times
The top end Stella bikes were very good ones, but whether your components represent that
or a swap by someone trying to upgrade is problematic to discover.
Post close up photos of the frame lug work and the rear dropouts, as well as any tubing stickers
if there are remnants of them for a better analysis here. There were a boatload of the lower and
middle end ones sold in the 70's.
And clean off all the aged rubber, cable housings, etc. and start fresh.
https://i.imgur.com/lTHSgHY.jpg
Sort of a test post to see if the pictures work. So after looking at the frame I was unable to find any mention of the type of tubing whether it's steel or alloy or 531. There bike has campy shifters, and front derailleur, campy hubs(or freewheels? Not sure of terminology but thing that holds spokes to rim, qr axles runs through their? center) and campy quick release mechanisms. Sun tour rear derailleur, and super champion (made in france) rims.
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
...from what I can see of the dropouts and the cottered crank, not a top of the line Stella,
but possibly not the bottom of the line either. By the time they were routing the rear brake cable
like that, the best French bikes had Stronglight cotterless.
Still might be butted tubing and a decent ride, though. Can't tell from here.
The Campy is probably upgrade swaps by someone who loved it.
Quoted: 556 Post(s)
Liked 132 Times
Pic is fuzzy, of course, but on first impression, looks like a mid level Stella. Campy Nuovo Tipo hubs. Maybe Valentino front derailleur.
What does that chromed crank set say on it? Neat bike. Looks to be in very good condition.
The chromed crank set says aduprat universel. I apologize about photo quality, my phone takes terrible photos. I will link a few more photos closer up hopefully reveal more detail.
Also 3 alarmer, you mention by the time French bikes ran rear brake cable like that, approx.. What year would you put this bike at?
Front of bike
https://i.imgur.com/8jbZk43.jpg
Front derailleur
https://i.imgur.com/PBY8fop.jpg
Rear brake
https://i.imgur.com/3wZjlXi.jpg
Stella insignia on frame https://i.imgur.com/91mWPAd.jpg
Campy shifters
https://i.imgur.com/7klAQJz.jpg
Rims etc.
https://i.imgur.com/VZyfG3b.jpg
Front of bike
Front derailleur
Rear brake
Campy shifters
Rims etc.
car guy, recovering
Bikes: Olympia Competizione & Special Piuma, Frejus track circa 1958, Dahon Helios, many others
Liked 7 Times
Probably Durifort tubing. The steerer tube might be stamped if it is. Mid-range bike for sure. Nothing wrong with that if you like to ride it. Tires, tubes, cables, bar tape & brake pads are all consumables and should be replaced as needed. New ones will do only good for your bike and you.
Michael Shiffer
EuroMeccanicany.com
Michael Shiffer
EuroMeccanicany.com
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
...in the early 70's, you saw mostly an extended housing and cable clamps:
By the mid to later 70's you were seeing a lot more exposed cable runs with stops,
or the other popular method of brazed on cable guides:
Stella was one of the companies that did the exposed cables early on, like on the one
above that I fished out of a bike junkyard in the early/mid 80's with no components.
It's not exactly a foolproof way of dating. There's not a good documentation of the company on the internet, to my knowledge.
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,460 Times
Nice bike! That Suntour rear derailleur is a very nice upgrade (VGT Luxe I think from the photo.) Do the maintenance suggested above; and do yourself a big favor by replacing that quilted vinyl, squishy-foam saddle with something nicer. You will find yourself enjoying longer rides a lot more.
Brent
Brent
Forum Moderator
Quoted: 3084 Post(s)
Liked 6,560 Times
Quoted: 3464 Post(s)
Liked 2,827 Times
I think the wheels are original, if so then the inside of the lock nuts on the hubs will give you a date, so it will be that or later, parts were not "just in time" back then.
My personal guess from visiting bike shops back then, 1972-73.
Nice shape for its age. It could probably use a thorough repack of the bearings. I would exchange the rear brake cable to front, get a new rear cable, maybe even lined housing which might require deft trimming to fit the cable ports.
I too think it might ride above its pay grade.
Very few shops sold Stella locally in Southern California, the brand did not have the visibility of Peugeot, Raleigh or Gitane.
And I would feel free to change saddles as that was not original and probably not that comfortable... and be sure to check the insertion amount of the stem into the fork... at least 2.25" inside the steerer, while its out, grease it.
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
NICE looking bike!
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
Thanks for the info, comments, and ideas!! I intend to get some new rubber on this bike, swap brake cables and housings, and clean/repack the bearings. I will probably upgrade the seat as I use this bike for longer rides when weather improves. Planning on replacing tires with same size (700x32), and will also check rim to see of its needs new tape inside. what type of grease is recommended for Repacking bearings? The back wheel definitely seems to have a little trouble with hub doesn't feel right when pedal long.
Woke up this morning to clean/repack bearings, and realized I need a cone wrench.. Also I had to use a vise grip to remove QR axle from front rim. Any advice on a rust buster? I have silikroil which I used and can now use QR axle by hand. The back wasn't as bad, but still rusty.
Also, I took some better photos of joints/ rear dropouts.
Rust remover?
https://i.imgur.com/iQVVhf7.jpg
Headset/toptube
https://imgur.com/30gqBH9
Seattube/toptube
https://i.imgur.com/QVBeRuA.jpg
Rear dropouts
https://i.imgur.com/jq5OfBz.jpg
And brent, yes good eye on fuzzy pic is is a vgt-luxe derailleur and I am pleased to hear it's is good quality!! I t seems to work well.
Rust remover?
Headset/toptube
Seattube/toptube
Rear dropouts
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
You had to remove the front axle from the rim (I assume you mean the hub) with vise grips? Do get the correct cone wrenches. Once you loosen the locking nut on the outside the rest should be easy.
+1 on what they said about doing maintenance. Cables, housing, tires, brake pads, even chain and FW are consumables. I wouldn't be too concerned about keeping that bike "all original" anyway. In fact, that stuff is basic replace-when-necessary on any bike you intend to ride.
Repack the hubs at least, and maybe the headset. Consider the BB too, but you'll want advice on how to deal with that cottered crank.
That looks like a nice rider. I'm a bit surprised at what 3a says about the rear brake cable routing. I would have guessed the exposed cable meant early to mid-70's, but maybe Stella did things differently from some other manufacturers
Real cyclists use toe clips.
jimmuller
jimmuller
[Qand E=jimmuller;16502573]You had to remove the front axle from the rim (I assume you mean the hub) with vise grips? Do get the correct cone wrenches. Once you loosen the locking nut
[/QUOTE]
I had to use vise grips to clamp onto round/cone side of QR skewer (opposite the lever side) , it was rusted in place on the skewer. However, I can now use fingers to loosen/tighten.. Thanks for rust products 3a. I found out my hometown doesn't sell cone wrenches, and I'm going to need a fr-2 from park tool anyways to remove regina freewheel.. So I called the bike shop where I live (and will return tomorrow) and ordered tool, and he said they have Falcon 14-28 freewheels for 17.99, would this be a good time to replace fw, and chain after cleaning /repacking bearings in back hub? I'm a little discouraged with my "cone wrench" I purchased a 12mm end wrench and ground it thin enough to fit before I realized I need a 13 or 14mm cone wrench. Will probably just buy proper tool tomorrow when I return to Missoula, and pack the bearings tomorrow.
[/QUOTE]
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
thoroughly clean and flush your old one (soak it in kerosene or some other solvent),
and relubricate it with oil dribbled through the sems at the bearings.
Looking at the condition of the bike, your freewheel is probably not worn enough to
need replacement, and ought to be of a higher quality than anything made by Falcon.
Someone will eventually tell you to replace the cottered crank with cotterless, too.
IMO, also a mistake with this particular bicycle, and crank. You will never manage to
service it by yourself. Those cotters have been in there a long time. A lot of the junior
mechanics at LBS cannot do this procedure correctly either. Find someone who is old enough
to have done it a few times, and is aware of the various methods for pressing them in and out.
A lot of the threading (probably most) on your bike is French, so Google French threading before
you **** anything up while taking it apart. It has not been serviced in a long time.
....every Falcon freewheel I've ever seen is a low end POS, so my advice would be to
https://i.imgur.com/Xm4GeOM.jpg
Cleaning/repacking the bearings today. Lock nuts on campy hub are stamped 71. Are these the correct era to be the Nuovo Tipo as someone else mentioned?
I don't have much intention of replacing cottered crank immediately, as the frame is a bit small for me. Been loving the bike with new rubber, and freshly packed bearings. Will look into repacking headset soon!!
Also, any tips for removing leftover glue residue on bars, from old grip tape I tried to remove? I tried WD 40 and iso propyl alcohol as solvents and neither were too effective
car guy, recovering
Liked 7 Times
Nuovo Tipos were being made in 1971. They are from the same era as your bike and may well be original.
As for bar tape glue, there is no downside to leaving it on. As long as there is no powdery residue the new tape will stick just fine and cover up the old stuff.
When you do the headset, see if anything is stamped into the steerer tube on the fork. Tubing makers sometimes mark it with a symbol (dove for Columbus, e.g.) or their brand.
Michael Shiffer
EuroMeccanicany.com
Michael Shiffer
EuroMeccanicany.com
Lovely bike. I wouldn't change that crankset for worlds, it suits the bike perfectly, as do the pedals and straps. I think if it were mine I'd be tempted to change up the saddle for a nice ideale or brooks and give it some red or black cloth bar tape, but other than that it looks fantastic.
