Replacing 105 pulleys with Dura Ace
That guy
Bikes: 2012 Felt FC build
Quoted: 25 Post(s)
Hi, a few quick questions:
Can I replace my 105 pulleys with Dura Ace pulleys? (I'm thinking yes, but want to be sure)
If yes, can I use the 105 pulley bolt with the Dura Ace pulley? I saw online somewhere that there is a Dura Ace-specific bolt that looks a little different than the 105 one (there's a threadless indentation between the head and where the threads start).
If I have to use the Dura Ace bolt, will that bolt fit okay in the 105 cage?
Thanks!
Thanks!
Quoted: 1438 Post(s)
Liked 1,092 Times
Never Fix A Running Piece. What benefit do you expect to enjoy with this change?
Likes For dsbrantjr:
Quoted: 4212 Post(s)
Liked 3,883 Times
As long as the replacement pulley is of the same width (as in chain width, 8,9,10... cogs) and of the same tooth count (pulley diameter) there should be no issues. We do this at work when we can't find an OEM grade replacement. All but the earliest DA pulleys have used a superior bearing (initially a ceramic bushing and more recently a true set of cartridge bearings that still allow some float) then the lower grade groupos used.
Why do you want to do this? Because the original pulley is worn out? Because you think it will benefit your speed? Better shifting? Cool factor? In my world only one of these reasons will hold water. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Advocatus Diaboli
Quoted: 4740 Post(s)
Liked 1,533 Times
That guy
Quoted: 25 Post(s)
Thanks guys, my pulleys are indeed worn out and I read that Dura Ace would make a low cost upgrade to bearings from simple bushings. Any thoughts about my bolt questions ml
Likes For Brad Bike:
Quoted: 2026 Post(s)
Liked 1,096 Times
Depending on the head configuration of the Dura Ace bolts you may have to reuse the 105 bolts. What's the problem with the 105 bolts? In my experience all Shimano rd cage bolts are the same.
That guy
Quoted: 25 Post(s)
To clarify, nothing is wrong with the current bolts. The Dura Ace bolts just seem different when I look them up online. If you guys are saying vthe standard bolts will work with the DA pulleys, then that's exactly the info I'm looking for.
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,010 Times
You should be fine assuming all is the same. I would probably try to re-use the 105 bolts and if they don't work try the DA bolts again making sure everything matches up not that I believe pulley wheel bolts have changed that much over the years but I don't really know because I so rarely replace them. My favorite replacement pulley wheels especially on the vintage side were Tacx. They are the same material but can be had with ceramic bearings without a ton of cost but it appears they have stopped making them for some dumb reason.
Really Old Senior Member
Dura Ace & 105 have been through a lot of different generations.
If your 105 pulleys are worn out, they're probably several generations old.
I'd at least look at the exploded views of the parts to look for obvious dissimilarities.
That guy
Quoted: 25 Post(s)
You're kidding, right? Dura Ace & cheap just doesn't fit.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
Nope, no joke. I went ahead and pulled the trigger on a pair of DA pulleys which, at about $40 US, falls into the category of "low cost" will enough for my liking. We'll see how they perform. If I have any concerns, it certainly won't be an issue to just go back to the style I have currently.
The key difference is that the Ultegra set uses ball bearings in both pulleys, whereas the 105 set uses ball bearings on one and a plastic washer on the other.
When you make as little power as I do, every 1/2 W counts.
Quoted: 8 Post(s)
I spent < $20 for an Ultegra RD-6800 pulley set (Shimano part no. Y5YC98140) for a 105 RD-5800 rear derailleur.
Quoted: 839 Post(s)
Liked 1,064 Times
Liked 1,475 Times
True! I had assumed that the OP would at least order from the same or later generations having the same number of cogs/speeds as his RD. (As far as I know that ensures compatibility even across generations, at least with respect to 105 and Ultegra.)
