Vertical jump and cycling training
Quoted: 8 Post(s)
Does anyone know or have any experience about vertical jump height changing after cycling training??
I have a good body to jump high but my vertical jump is very average (20 inches!!!) is this caused by practicing cycling or is just genetics?? Thanks
Sunshine
Quoted: 10897 Post(s)
Liked 7,384 Times
What was your vertical before picking up cycling?
And do you practice very specific exercises or just assume you are good to get up since you have a good bod for it(not really sure what that means)?
Quoted: 3190 Post(s)
Liked 2,460 Times
Genetics.
just another gosling
Quoted: 3872 Post(s)
Liked 1,920 Times
I would guess that your vertical jump would suffer from the usual cycling training. Cycling is an endurance sport, emphasis on slow twitch muscles, vs. jumping, emphasis on fast twitch. The two types can convert back and forth to quite an extent with training. The same cyclist can train either to be a sprinter or a climber, and be fairly good at either one, but not as good at both at once. Of course if you never had a good jump, maybe it's genetics for you. Cycling won't help though.
Results matter
Results matter
Quoted: 8 Post(s)
Just assume i'm good to jump since i have a good body to do it....ahahah
Quoted: 1186 Post(s)
Liked 289 Times
Likes For gregf83:
Sunshine
Liked 7,384 Times
You did t answer my questions and I really dont l ow how you quantify having g a good body to jump. If you have a good body to jump high then you fan jump high, yet you are at 20"...
Good luck with your quest to improve your vert or to troll.
Likes For mstateglfr:
Quoted: 8 Post(s)
just assume I'm out on this thread until it becomes clearer it's actually serious.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Sorry, i didn't mean to sound not very serious, i just mean that i assume my vertical jump should be higher than 20 inches, because I have a good body to jump high (long legs and lightweight), so my question was : is my bad vertical affected by cycling training or is just genetics?
Having long legs and low body weight means little by itself. Vertical jump is about strength to weight ratio and fast to slow twitch muscle fiber ratio, plus specific technique and conditioning. Finally, your vertical jump seems to be at the top end of average or slightly above average. Not bad at all for someone who, I'm guessing, has spent little to no time actually training for jumping.
Quoted: 8 Post(s)
Quoted: 1067 Post(s)
Liked 259 Times
How does it matter what your vertical jump is?
Sure it counts if required in the sport you do (Athletics, basketball) in which case you would specifically train for it.
Outside of that it doesn't matter.
