Weight loss and impact on Riding
Quoted: 33 Post(s)
I lost 10 pounds from last season.
Now when I ride the same trail as last season should this weight loss be comparable to riding a bike that is 10 pounds lighter (theoreticlly).
In otherwords is weight loss (less weight on the bike) the same as having a Bike weighing less.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
So they say (me too sometimes). But every time you stand on the pedals or shift your position it's 10 pounds less that you're moving than if the 10 pounds were on the bike. It's also 10 pounds less of flesh that needs base metabolism calories - that much more energy for cycling. I don't know how much that is though.
Quoted: 811 Post(s)
Liked 1,946 Times
10 pounds less interacting with gravity. Was improved conditioning in the off-season part of this equation?
Non omnino gravis
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
I think it matters what 10 pounds. Keep in mind you're the motor as well as the cargo. If you lost a bunch of leg muscle, not so good. Upper body muscle and fat, probably gonna be faster a tiny bit.
Likes For livedarklions:
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 761 Post(s)
Liked 555 Times
the 10 pounds matters, but riding fast and hard (yikes) requires fitness and time in the saddle. Just dropping weight might not equate to faster time trials or whatever. Need better legs and lung capacity too
Likes For Oso Polar:
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 343 Post(s)
Liked 292 Times
I'm about 15 lbs heavier than before I had kids, and I'm definitely slower.
I'm also 5 years older, and I'm riding a lot less than I was, so it's difficult to isolate any one factor; but when I'm riding hills, I do definitely wish there was less of me to haul up. (Set some downhill PRs lately, though).
Going up hills, the hills don't care if the weight is you or your bike - 10% less mass means you will be faster up hill, but it is not as dramatic as you might think.
You can go here and play with the numbers yourself, but going from 235 lbs to 225 lbs will reduce your time going up a 1 mile long 5% hill from 9.1 minutes to 8.75 minutes, assuming you are putting out 200 watts and your bike weighs 20 lbs. So, you were about 15 seconds faster going up that 1 mile hill.
Same parameters but on flat ground, you will save less than 1 second by being lighter!.
As others mentioned, where that 10% is a higher percentage of your total body plus bike weight, more benefit by reducing gravity's effect when going uphill, still not much on flat roads.
Now, the gravity doesn't care where the weight loss came from but related forces (like momentum) do care. On rides where you are starting and stopping, less force is required to get less mass moving again, in particular getting rotating things like wheels. up to speed again. If you made your wheels a few lbs lighter, it might be just as noticeable as that weight loss from your body.
I made my self a deal 3 years ago: if I lost 20 lbs, I could go out and buy a bike that weighed 10 lbs less than my steel 1995 Trek 520. I lost the weight (245 to 225) and bought a carbon road bike - between 30 lbs overall reduction (around 12%) and much, much lighter wheels, I felt like I was on an e-bike!
Likes For jpescatore:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Over the last three years I have been working on weight loss and fitness. I am down 70lbs, I am defiantly faster. My average speed went up a lot or I think its a lot. My average power too has climbed BUT my short efforts to max power is less than it was. I am ok with that because losing fat makes it easier to climb no doubt.
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
If you lost 10 pounds of fat then it is not the same as just decreasing bike weight by 10 pounds - it is much better and way more noticeable than 10 pounds reduced from bike. The trick is to lose fat and not muscle mass, something like "lost 80 pounds last year fasting" alone is very a good way to lose mostly muscle mass and become weak - physical activity is a must during weight loss. And it is actually very tricky to decrease weight and increase fitness simultaneously...
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 282 Post(s)
Liked 267 Times
I struggle with my weight and go up and down by 20-30 pounds. It's simple. If I'm riding the same amount, if I weigh more, I go slower and climb with more difficulty. If I weigh less, I go faster and climb with more ease.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Having been there I can say that is it pretty much impossible to lose that kind of weight that fast and keep/gain strength. Keep the weight off and give it another year or two to build strength back and you'll def see improvements.
Quoted: 2281 Post(s)
Liked 1,710 Times
I now have a bike that's about 10 lbs. lighter than my old bike, and yes, I can go a lot faster on it. Now if I could only get my body to become at least 10 lbs. lighter...
Quoted: 550 Post(s)
Liked 325 Times
On flat ground it almost doesn't matter, although a bike with tires can save 20W at 20 MPH which is 10% of the total power.
For most riders (included racers, it seems) most climbing time is not done standing - on the way up weight is not your friend climbing for the vast majority of people the vast majority of the time.
Similarly, very few people are doing hour long climbs as a high percentage of their riding and will never be able to lose 10% of their total weight very often! A lot of bike weight savings are in the 1-2% of total bike+rider weight, or lower.
Using bikecalculator.com, for my weight (220) on a 60 mile ride with a 1% overall average grade (about 3000 ft of climbing) at an overall average of about 16mph works out to be a 3:44 ride. If I drop 20 lbs, that time goes down to 3:38 - I saved 6 minutes in an almost 4 hour ride. Very meaningful in a race, not very meaningful outside of a race.
From that point, taking 2 lbs off my bike saves about 30 seconds.
Tragically Ignorant
Liked 9,094 Times
Also, because the effects of weight are not evenly distributed over the route, you have to consider how that 1% grade is distributed as well. If I have a big climb at the beginning of the ride, I'm going to be a lot more tired at the top of it with the extra weight than when I'm lighter. That might affect my speed on the remainder of the ride. Unlike other motors we use, our legs get tired.
For me, the hills get a lot smaller in August and September than they are in March, and that's with about a 5% winter vs. summer weight fluctuation.
BTW, I stand on the pedals a lot, when you do long-distance riding, there's a lot of good reasons to do so.
It makes a bigger difference than you realize. The amount of effort needed to carry around extra weight is considerable, and when that weight is removed, the energy savings goes a long way to improving your speed and endurance. I used to live in a place where I could ride all year, and my weight stayed consistent. Then I moved to a country which has 4 seasons, and winter riding is impractical. During the winter months I invariably put on weight, and as I get older, the weight packs more quickly. When I start riding I can feel the extra effort needed to move that weight around. As the weight comes off, everything becomes easier, and when I get back to my optimum weight, I find things like stairs, hikes, and long dog walks much more pleasant.
Likes For 50PlusCycling:
Tragically Ignorant
Liked 9,094 Times
I have, though, gone too far the other way, working out a lot while not eating enough to maintain muscle mass. I did that before I went back to cycling so I don't know what effects it would have on my speed, but I generally found myself looking muscular because of the lack of fat, but actually lacking strength to push open heavy doors easily, etc.
Quoted: 733 Post(s)
Liked 815 Times
I was referring to losing large amounts of weight in a short period of time. 8 years ago I dropped 100lbs in about 10months, losing that kind of weight and building strength at the time is extremely difficult and doesn't happen for most people. But once you're successful at keeping the weight off, then you can work on strength.
Over the last year, I've actually gotten leaner and stronger while my weight has stayed roughly the same. Up until this recent training block, I've stayed pretty steady at 185lbs, hanging out around 180 now. I completely agree with the high energy flux model, eat more, move more, fuel the effort and build strength at the same time.
Likes For Rides4Beer:
Non omnino gravis
When I first started cycling, I dropped 50lbs in less than 6 months. I thought this was due to the bike, but it was not-- it was due to me being woefully out of shape and overweight. And most importantly, adding activity-- and it could literally have been any activity-- helped offset my diet. A bit over five years later, I'm 5 years older and my body has completely acclimated to cycling. I eat less (and better) than I did 5 years ago, I've averaged nearly 200 miles a week for over 5 years, and I've gained back about 20 of those 50 pounds in the past 2 years.
Weight is lost at the dinner table, and strength is gained by doing strength exercises. Riding a bike is an excellent form of aerobic exercise. But it's not magic.
*ignoring those who cycle competitively, to the point where they are physically destroying their bodies, repeatedly, i.e. Grand Tour riders; and even they experience more muscle loss than anything else, as they had little fat to begin with
Likes For DrIsotope:
