Advice on Power Meter
Quoted: 3905 Post(s)
Liked 7,181 Times
Quoted: 800 Post(s)
Liked 512 Times
My recommendation is for a left sided PM from 4iiii. I've had mine on my bike for over a year now. No complaints. I get over 120 hours from the battery, so while I considered the rechargeable 4iiii unit, I settled on the left side arm requiring the CR2032 battery.
Perceptual Dullard
Quoted: 900 Post(s)
Liked 1,122 Times
I used to worry about L/R imbalance, but now choose to ignore it. Why? Two of my four power meters provide L/R imbalance; one consistently says my left side is stronger (53/47) while the other says my right side is stronger (46/54). (The overall power for all four meters is within 1-2%.)
Some crank spider PMs (like, P2M and Quarq) produce L/R splits but they can be flaky because of the way they try to calculate the split. That said, some crank arm PMs produce kinda flaky data, too. I've wondered about pedal PMs but haven't had a chance to do a full test on their splits.
Liked 7,181 Times
That's interesting. Are these two the same model/brands, or different? What models/brands are they?
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
Edit - NVM. Garmin and P2M.
Perceptual Dullard
Quoted: 900 Post(s)
Liked 1,122 Times
The meters in disagreement are a P2M and Garmin Vector 3. Technologically, I have more faith in the Vectors for L/R splits, however, the P2M L/R splits align better with known physiological differences, i.e. leg size and injuries. I could throw a couple other meters into the mix to shed some light (murk?) on the subject, but the discrepancy doesn't affect what I'm doing so it's easy to ignore.
Likes For RChung:
Liked 7,181 Times
Yeah, the P2M definitely gets fooled by any "pulling up" on the pedals. For instance, it's almost impossible to get a 100/0 L/R split with the P2M when doing a one legged drill, whereas it's almost impossible not to get a 100/0 split with the Vectors.
Likes For RChung:
Quoted: 20791 Post(s)
Liked 9,436 Times
Liked 7,181 Times
We've had a bear, a bobcat, two moose, a bunch of coyotes, and a beagle-corgi mix in our yard in the past few months – I want to be prepared in case I have to pedal with one leg.
Same for me, most rides finish at 50/50 or 51/49. At low intensity I have a slight imbalance, usually a few percent, but it evens out as I approach threshold. I’ve had dual sided Garmin Vectors for about 4 years so when it was time to pick up a PM for my gravel bike I opted for a single side crank arm since I knew dual sided wasn’t going to add anything except cost.
Quoted: 528 Post(s)
Liked 230 Times
I have been using Assioma Duo for over a month now. Works amazing.
I would echo what others said though - dual probably does not add much value, the sides are almost always with the 50-50 to 51-49 range.
I got my 105 4i left only power meter in the mail yesterday. Hope it will fit and get it installed for an outside ride by the week-end.
I decided at my level this will work fine at $300. I am using Trainerroad and plan to get a Garmin or Wahoo that I can push some of the workouts outside, so I effectively will have spent about the same, but have the workable package. If I feel like improve pass this level and need dual sided, I will put it on ebay.
Liked 6 Times
A lot of people hate on the single sided power meters, but I absolutely love my 4iiii power meter. It's been Rock solid since I bought it, only changed the battery one time.
Likes For Duganator9:
Quoted: 46 Post(s)
Liked 9 Times
I'll give a non-recommendation to Avio Power Meter. Great idea (self install crank PM), but terrible execution. Units have been out for over 18 months, and they still can't address a phantom battery drain issue. Well, they say they have with the latest firmware, but that firmware doesn't calibrate properly - you end up putting out 2000 watts. I had a unit installed for 6 months - the battery issue got so bad I was replacing the battery every other day. Last week the unit stopped working even with a new battery - icing on that cake was the battery door broke from repeated removal/install. So, I took a mallet and plastic prybar and removed the POS.
I think I'll be going with pedal based system.
John
John
Likes For RChung:
Liked 7,181 Times
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 287 Times
I would get a used stages or 4iiii.
When it comes to training and measurement, consistency is key. If you favor your right or your left leg, how are you going to train differently based on that? If you go to the gym, you should be doing the same number of reps/sets with both legs and that's about all you can do. Sure you can do 1 leg drills on the bike, but are you really going to do them for one leg only?
Consistency is key.
If your left leg is stronger or weaker... it doesn't matter. The PM is measuring the same thing every time. You'll see improvement there as it comes. Unless there's a reason for you to suspect that your legs might be getting stronger at different rates then I wouldn't worry about it.
I used to have an SRM. Very happy with my current 1 sided PM. I no longer race and I've been getting back into things and it's a fantastic way, esp to start off. If you buy used you can resell without much of a loss. I'd do it the same way again if I had to! Easy to swap between my two bikes as well. Takes like 5 mins.
Consistency is key.
Likes For ridethecliche:
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 385 Post(s)
Liked 321 Times
My view on power meters changed radically after trying to buy a stupid bathroom scale. I weigh myself daily and wanted "the most accurate scale". After much research, I found that the search for an accurate scale was largely meaningless. I could buy 30 scales and I'd be willing to bet that all 30 scales would give me slightly different readings on any given day. Even if 15 of them gave consistent weight readings, how do I know that those 15 are "accurate" and not just equally wrong? Will the scale readings change over time as parts wear? Does it even matter what number my scale reads in comparison to anyone else's? If my scale says I weigh 165 lbs but a finely calibrated, high precise, gazillion dollar scale used for measuring gold (?) says I actually weigh 164.354 lbs, does that really matter?
As RideTheCliche states, I think what is actually important is if the meter you bought is consistent with itself over time. It's only through this consistency that you can determine if your fitness level is improving. Of course, build quality should matter as well but is quality is usually assumed no matter which power meter is purchased. (I.e., if the power meter doesn't work half the time, it's of no value no matter how "accurate" it is.)
If I was the chief mechanic for a large cycling team, that might be another story. In which case, I would think it is important that all the rider's power meters are calibrated consistently so comparisons between riders could be made.
And here I thought being chased by an occasional dog was scary
Likes For PoorInRichfield:
Perceptual Dullard
Quoted: 900 Post(s)
Liked 1,122 Times
1. It's possible to check the accuracy of a bathroom scale.
2. Whether consistency is all you need depends on what you're doing with the information.
3. My step dad was a butcher so I used to work in the shop. I can guarantee that if the scales in the shop were consistent but inaccurate, we would have been in a lot of trouble.
4. Whether consistency is all you need depends on what you're doing with the information.
Likes For RChung:
Fat n slow
Quoted: 3229 Post(s)
Liked 2,034 Times
I personally wouldn’t buy any crankarm based dual sided PM for current gen Shimano cranks. I had a Stages on backorder until I read the info gplama posted about the right side being inaccurate, after that, I went for pedal based PM instead. Really happy with my Vector 3.
https://gplama.com/2019/06/29/shiman...-power-meters/
Quoted: 18883 Post(s)
Liked 10,645 Times
Sigh.
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 287 Times
Sigh.
The vast majority of folks buying these devices will likely never use them in ways where what one is doing with that information truly benefits from the additional info. Hell, if all you're doing is posting your numbers on strava then it doesn't even matter does it? Wait, in that case you'll want something that reads high and can have the offset modified to read even higher!
These discussions are often fun to have though. It's pretty cool to see how far things have come since 10+ years ago when I used to have a wired SRM.
Oh! I can say that 1 sided crank based PM's will make your one leg drills look rather hilarious during a log though!
This concern for 'inaccuracy' is largely unfounded if you're buying a vetted unit though. Looking at DCR or GPL before buying an item can help one see how they stack up to other accepted units and allow a buyer to see how they do when it comes to both internal consistency and 'accuracy'. With that info in mind, and a +/- 1-2% difference in internal consistency... what else do you really need for the riders mentioned above?
Quoted: 741 Post(s)
Liked 412 Times
I have never heard or talked to a sprinter who used a powermeter to even out leg strength. My guess would be that they spend so much time in the gym that an issue like that would dealt with there. What is cool is how sprinters and their coaches use power to determine what their optimum gear will be for a particular track or situation. A good gear not only gives quick acceleration, but also slower deceleration.
Likes For colnago62:
Perceptual Dullard
Quoted: 900 Post(s)
Liked 1,122 Times
Likes For RChung:
