Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Those are the Speed Concept tri-bars that connect to the top of Madone's stem cap. They bolt on or off in about five minutes.
Dipping my toe into the gravel pool... certainly not the sexiest, lightest, or best-outfitted option on the market, but it's a comfortable ride for a great price (2018 closeout, the best way to buy, IMHO).
Likes For travelerman:
Easily one of the better $20 investments I've made in my bikes.
Since all of my tires are tubeless, and I cycle between riding my bikes, sometimes several days will go by between rides on a particular one. What I find frustrating on my pump (Bontrager dual pump for both HP and HV tires) is that attaching and detaching the pump often results in significant air loss. With the JACO, there's almost no loss of pressure at attachment or detachment, what little there is, it's just a small fraction of what happens with the floor pump. This lets me check my air pressure quickly, and if it's within the desired range, I know it will still be there even when I detach it.
Also the bleed valve is cool because, as I mentioned with the Bontrager pump, if I want to pump something up to 65psi, I have to overshoot it by a bit and hope that it's a clean detachment, otherwise I may bleed out more air than intended. With the JACO, if I slightly overshoot the PSI with the pump, I can accurately bleed it down to exactly where I want it, knowing the JACO only loses a tiny amount of air.
For those who are interested in buying, there is a warning on the Amazon page that this is intended for higher pressures up to 160psi, "if you want 60psi or less you should buy the 60psi version". The problem there is that the 60psi version maxes at that pressure. So if you're like me and have a gravel bike you run at 45, and road bikes you run at 65 or higher, it seems you have to buy both. You don't. This measures my gravel bike tires just fine and lines up well with the Bontrager measurement (within 1psi of each other) whether I'm doing the gravel or road tires. Maybe at sub-60 psi the other device is more accurate, or has finer measurement gradations, but I find this to be good enough for all my tires. Now if you are a MTBer perhaps the lower psi model makes sense...since I' m not I can't speak to that.
Quoted: 942 Post(s)
Liked 526 Times
just having fun
Bought this little bike wall mount. I wanted something small and clean looking, and this fits the bill nicely. Only downside is you have to keep the tires inflated or your bike will fall out of the rack. Not a big deal for me though. I found one on craigslist for $10 after seeing them in a bike store for $25.
Quoted: 4717 Post(s)
Liked 1,882 Times
I like the way you describe the bike here. It’s not exciting, but it’s gonna be a fun gateway drug.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Likes For burnthesheep:
+1. I don't use any wheel/pedal reflectors. Powerful headlight and tail-light, and if you can get a head- and tail-light with the "viewable from the side" feature, that's better than reflectors.
Quoted: 4559 Post(s)
Liked 2,802 Times
For now my compromise is helmet lights, little but bright USB blinkies strapped front and rear. I got 4 years of regular use, several times a week, from a Blackburn 2'Fer before its runtime per charge significantly decreased.
Likes For canklecat:
Quoted: 451 Post(s)
Liked 364 Times
Best side visibility at night is with wheel mounted LEDs. Nothing else makes a bike pop out of the background clutter of other cars and city lights like rotating LEDs. They add a little weight and I use 'em only on my hybrids for casual rides and errands. But I may add some to my steel road bike since it won't add significant weight.
The helmet light has proven to be very effective for me as a 'be seen' measure as well as a 'see' measure. I wouldn't give it up for the world.
Likes For bpcyclist:
Quoted: 173 Post(s)
Liked 57 Times
Coming from the motorbike world, I know how important correct pressure can be. I picked this up too. It works well and accurately tells me how far off my Lezyne floor pump is (~8psi over). I adjust pressure before every ride.
To give Bontrager's pump credit, it was within 1psi of this, so it's pretty accurate. It just is annoying that the way it attaches and detaches is so finicky, sometimes I'll only lose 1psi or less, others a lot more. And I could never use the Bonty to check pressure because of the loss both ways, so even if my psi was close to where I wanted it, by checking it I'd lose maybe a combined 3psi. So now the JACO gives me confidence in checking knowing that I'll lose less than half a PSI (probably much less) in the process. This helped me confirm that my new tubeless GravelKings sealed properly overnight after the first ride because I lost only 1 psi overnight vs. the first night I set them up (and prior to my first ride) where I lost 4-5 psi and I thought I screwed it up.
EDIT: I will say this, as a slight amendment to my previous post. If you do primarily live in the sub-60psi range, the other version does make sense, because the gradations here are 2psi with each hash mark. I know people running in the 20s and 30s may want hash marks that are down to a single psi point. In fact, I'm so happy with this one that I'm contemplating getting that specifically for the gravel bike (and any future MTB I might decide to buy) and reserve this one for my road bikes.
2nd EDIT: I see on Amazon's page the 60psi version's hash marks still equal 2psi jump (so there are 5 hash marks between 10 psi differences) but the hashmarks are much further spaced apart, so it would be easier to tell when you're at an odd-number PSI than on the 160 version. So their recommendation is accurate, if you primarily do sub-60, buy that version, but this one will do both, it's just that the hash marks are closer together which will give you less fine readings at lower pressure.
Blast from the Past
Picked up lightly used RD-9000 front and rear derailleur's for my Felt DA. Replacing the 105 that I'm taking off for another bike, at least that's my excuse/justification.
Quoted: 451 Post(s)
Liked 364 Times
Just ordered a Cookie Monster jersey. Ha!
Likes For sempre1:
Picked this up for Christmas. Little bit of an upgrade from my 12 yr old Motobecane.
Likes For Genaro:
Quoted: 641 Post(s)
Liked 1,517 Times
Don't actually have it yet but ordered this on Saturday. 2019 Roubaix Comp DI2. Looking forward to my first new road bike.
Likes For Ogsarg:
Quoted: 451 Post(s)
Liked 364 Times
Quoted: 641 Post(s)
Liked 1,517 Times
2019 Synapse
2019 Cannondale Synapse Carbon Disc Ultegra. Sadly it's winter so I just get to look at it until the snow is gone. I got a great deal so it's well worth it.
I got a red bike because,,,,, you know... faster...
Quoted: 641 Post(s)
Liked 1,517 Times
The only requirement I had for color was that it not be matte black. While it appears to be wildly popular, I really dislike it.
Liked 1,882 Times
