Tapered alu/steel/carbon fork that takes front panniers?
Bikes: cross check, trek 6000, salsa warbird ti, spesh awol transconti
I'm having trouble finding a fork to replace the Enve CX Disc fork on my Warbird TI.
I need some front panniers for this summers adventures.
I've got the Thule Pack'n'Pedal tour racks, but I am a bit concerned about putting weight on the Enve fork.
So, a tapered steerer disc fork with either mid fork eyelets or canti studs for mounting a rack.
And one that doesn't mess up the Warbirds geometry.
I've found an alu one on a Stevens bike, but they wont sell it to me separately.
Likes to Ride Far
That's going to be really tough to find. A had a look at a few sources and manufacturers that I know of, but couldn't find anything that meets all of your criteria.
Pennylane Splitter
Bikes: Yes
Quoted: 1748 Post(s)
Liked 1,421 Times
Is it the steerer tube on the fork that's tapered on the Warbird, or the headtube/headset in the Warbird's frame (larger bottom bearings, but it'll still take a standard 1 1/8" steerer)?
IF its the latter, try looking at the Soma Saga, Soma Double Cross Disc, the Surly LHT Disc, Surly Straggler. All are steel forks, will take a disc brake, and have mid-blade rack mounts. Might have to call Soma about the Saga fork, as its not listed on their website as being a separate item from the Saga frameset.
Did you found a solution for this problem!.. I have exactly the same dilemma on my warbird ti, I want to fit a rando bag, and the thule rack looks like a good solution, I'm just skeptical to put it on the enve fork... Cheers
