Wheel lacing too long
I had to change my hub and i uses the same spokes and nipples i got which were good before i removed them. When i lace 3 cross pattern, the spokes seem too long. I have a photo of before and pretty sure it was 3 cross before too. I think i am making a mistake when lacing. But what mistake could cause the spokes to remain too long even though they are the correct length?
Just grasping at spokes, I mean straws... The spokes where they cross, close to the hub they just pass each other, but at one of the crosses further out they are "laced", i.e., they actually press against each other (which helps keep the wheel in true), check that is the case, because if not, the spokes have a tiny bit more direct path to the rim so might seem too long.
Really Old Senior Member
What size wheel, how many spokes and how much too long?
For more typical wheels, 5-7mm would indicate you only did cross 2.
Shimano hb-rm35 hubs 28' 36h rim idk the spoke length or anything about nipples but it was ok before i removed them to change the hub cuz it was broken. Hub was exactly the same before too.
(above) Yeah that sounds way off, from 3cm too long, to gap between spokes where I think there should be interference. Another thing that could be off is phasing of spokes from left and right sides. Perhaps go to Sheldon Brown and their wheelbuilding articles, try to go thru step-by-step, to find error.
They do press against each other once and i think it looks quite the same of the video i watched. When i look at the before photo of my wheel i see that spokes in the same side of hub which is in opposite directions(some come from inside of the hub some outside) the ones which comes from inside of the hub almost goes over the other. But when i lace there is a one hole size space between them. I thought i should twist the hub more but couldnt. Spokes seem more than 3 cm too long and nipples go out of the second hole in a double aluminum rim.
3 CM is over 1".
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3111 Post(s)
Liked 6,709 Times
Likes For cb400bill:
Quoted: 6330 Post(s)
Liked 4,919 Times
The replacement hub has the same flange diameters as the old hub?
Quoted: 4556 Post(s)
Liked 1,697 Times
36 hole wheels are sometimes laced 4 cross instead of 3. If you throw some average parts into a spoke calc program you can see approximately how much difference there is between 3x and 4x in final spoke length. Is that your number?
Likes For Kontact:
Quoted: 5909 Post(s)
Liked 2,777 Times
Measure a spoke. If it's something like 300mm or so, odds are the original wheel was 4x, and that's your problem.
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3922 Post(s)
Liked 6,560 Times
Likes For SurferRosa:
On that hub, the calculated spoke length would result in the Right side (DS) spokes being 1.1 to 1.2 mm longer. I'm a bit surprised they even bothered with 2 different lengths.
From the chart, you can see the result of using the wrong number of crosses.
The ERD reflects the diameter of the spoke bed. I don't have a clue to what rim you have, but I used a "generic" length for a 622 mm (700C) double wall rim.
https://bike.shimano.com/en-EU/produ...o/HB-RM35.html
Quoted: 2581 Post(s)
Liked 3,093 Times
Many if not most of us here have decades of reflexively thinking in terms of rim brake wheels for bikes, certainly in the absence of data specifying otherwise. Analogously, if you and I read a thread where the OP asked for advice regarding frequent flats, only to find after several rounds of backing and forthing (with mentions of tubeless versus tubed tires, etc.) that the bike had sewup tires, we'd likely be surprised. It happens.
Quoted: 403 Post(s)
Liked 940 Times
I’m still curious to see if there’s confirmation that the same hub is being used for the rebuild. Also, does it seem like all of the spokes are uniformly too long? Any pictures of the build in its current state?
Liked 2,777 Times
Side note for the OP.
I believe that the 3x vs.4x theory is probably right.
However, for future reference, please don't take and post photos against a camo background.
FB
Chain-L site
FB
Chain-L site
