Front hub cones damaged - replace the cones, replace the hub, replace the wheel?
Old 12-02-23, 07:03 PM
nathand
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times in 62 Posts
I'm refurbishing a 1992 Trek Multitrack. The front cones are pitted. I'm trying to decide the best path to a smoother-spinning wheel. Options seem to be:
1) Replace the cones. They're available from Wheels Mfg but two cones + shipping is going to cost me $40!
2) Buy a new, similar hub, and rebuild the wheel. Random Bike Parts has a Deore LX hub, similar to the current one but a bit newer, for $14 with free shipping. However, then I have to confirm the existing spokes are the right length and rebuild the wheel. I can true a wheel but I've never built one, and I don't own a truing stand.
3) Find a random usable front wheel on Craigslist/eBay/etc for probably ~$60.
Any recommendations?
nathand is offline
Old 12-02-23, 07:54 PM
veganbikes
Clark W. Griswold
Quoted: 4369 Post(s)
Liked 4,008 Times in 2,676 Posts
I would probably just buy a nice new wheel and know it is of good origin and not have to a do a bunch of work rebuilding. Unless the rim is something super special and those spokes are really top notch and in good condition I wouldn't want to rebuild a wheel on it and replacing cones is fine but I would be curious the condition of the rest of the hub and the wheel itself.
veganbikes is offline
Old 12-04-23, 07:13 PM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times in 570 Posts
To confirm, it's the thread-on cones that are pitted, not the races internal to the hub, yes?
This sounds far more expensive than it should be. Are you at all near a bike shop, where you could bring one of your existing cones in and they can match them up? (Your location suggests you're in the Bay Area, which means you likely have many good bike shops nearby.) Even if not, it seems like there should be less expensive options online (though I admit I haven't bought cones online before).
This route will almost certainly also require new spokes, as the length needs to be pretty precise. The Deore hub is unlikely to match your existing hub exactly, though it may indeed be close.
For the price you pay for a new or used wheel you probably won't find one that's up to the quality of the original wheel (presuming the one you're working with is the factory Trek/Matrix wheel).
Even if it did cost $40 for new cones, that's the route I'd take. It's both the least expensive route (again, presuming you'll need different length spokes with that new hub), and the approach that'll likely give you the best results in the end. (I do think a bike shop should be able to source you new cones for $5-10.)
hokiefyd is offline
Old 12-04-23, 09:20 PM
nathand
Quoted: 87 Post(s)
Yes, it's the cones threaded on the axle. The races inside the hub look and feel fine.
The cones are these https://wheelsmfg.com/products/hub-p...s/cn-r040.html. $14.52 each plus $10 shipping.
Thanks, I'll check with some local bike shops and see if I get lucky. Buying new cones appeals to me for both reusing as many parts as possible and easy of installation.
nathand is offline
Old 12-04-23, 10:53 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Quoted: 62 Post(s)
Liked 116 Times in 66 Posts
If the rim is in good shape, may as well replace the cones. If it's not in great shape, may as well find a different wheel. $14.52 is MSRP, so I'd expect most shops to charge than much per cone, but you could save on shipping if you find a shop that already has them in stock.
Arrowana is offline
Old 12-05-23, 07:04 AM
CadenceBoy
CadenceBoy's Avatar
Quoted: 16 Post(s)
Liked 5 Times in 5 Posts
Go to local bike shops with the used cones and axle, you'll probably find a replacement for a few $ ...
Replaced the cones and axle on my hybrid (front wheel) a few years ago, no issues.
CadenceBoy is offline
Old 12-05-23, 06:59 PM
nathand
Quoted: 87 Post(s)
Thanks for the suggestions! Closest local shop I tried couldn't help. The second one - which has been around a lot longer - didn't have the exact cones, but sold me an axle assembly that looks like a very close match for $10.
Meanwhile I also picked up a damaged bike to scavenge the components for this rebuild. I wanted the shifters and derailleurs (Shimano 5600) and got a decent wheelset, with Shimano hubs, in the deal, so now I've got two options.
nathand is offline
Likes For nathand:
