Help! pack rat - rear wheel axle problems - cup and cone bearings keep coming loose
hi, a little help needed (this is driving me nuts)
On my surly pack rat the rear wheel regularly develops a bit of a side-to-side wobble (I can move it side-to-side relative to the seat stays, but it's NOT moving in the dropouts, only on the axle), so I remove the wheel, tighten up the nut on the drivetrain side of the axle (pictured below), replace wheel, and ...do that again every few days it seems.....
I'm generally a tad unhappy with the pack rat rear wheel setup, in addition to the above issue I have to crank the QR super tight, basically at the limit of my hand strength (the original skewer broke within a year, maybe from clamping it so hard???) or the axle slips forward under hard pedaling. Surly said the hurdy gurdy would work, or a dual cam skewer, tho I'm not quite sure what one of those is....(google hasn't helped me). Does anyone have any other suggestions?
All this said, no problems on the front end, and it does what it says on the tin: carries a heavy load really well on the rack, perfect for my commute (120km a week).
Here's some photos in case they are useful:
Thanks for any help, this is reaaaallly annoying me now....
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
At the cost of pointing the obvious: you need to tighten the locknuts against the cones (how to service cup-and-cone hubs and adjust bearing preload).
For the QR, make sure you use a high-quality QR with the mechanism inside its "head" ("internal cam mechanism").
Relja
Relja
Really Old Senior Member
Generally, when we service the bearings, we "over tighten" the DS lock nut because it's less accessible. It looks like yours is loose.
IMO- your best solution is-
Remove the cassette.
Service/inspect the cones/bearings. Repeated loosening may have damaged the cones/balls.
When reassembling, do you final preload adjustment on the NDS.
thanks for the replies!
Bikegremlin - great write up and very detailed video, thanks! I basically think that's what I'm doing (tho I love the idea of using spacers, such a pain putting the wheel on and off to test!) but I can give it another go tomorrow morning....
Bill - yeah my DS side seems to come loose, feels like it needs a locknut as well as the NDS side.....I just did an overhaul and regrease last month, I'm no mechanic but it basically looked ok (no obvious damage to the cones or bearings). Tomorrow I'll try tightening the DS side then adjusting on the NDS side (i think I tried that when I did my overhaul, but ....... I've watched bikegremlin's video now so maybe it'll make more sense and I'll do a better job when I try it again....
thanks for the advice, I'll have a look at it again tomorrow...
Likes For eggnoggbubble:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
As above advice, the only thing I could think to add is replace the spacer with a nut(s) of the same spacing so that you can tighten them against each other, or a drop of Loctite 243 on the outer nut thread, (243 is oil tolerant which is why I recommend this one, but get it as clean as you can).
Or replace the axle and nuts, maybe they are worn or not manufactured to close enough tolerance and are a poor grade?
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
In addition to rebuilding the rear axle correctly, and getting a good skewer, be sure the rear dropouts are parallel to each other, and straighten if needed. There's a tool made for that, but an avid DIYer could rig something up. If a dropout is bent, it's difficult to clamp the hub securely.
Likes For andrewclaus:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Make sure that the threads on the axle, cone, and locknut aren't stripped. And consider getting a closed-cam quick release if the current one is an open cam QR.
Quoted: 6202 Post(s)
Liked 4,816 Times
On every bike I've ever had that used cup and cone bearings. I'd not loosen the locknut of the cone on the drive side. I'd just remove the cone entirely from the other side and then pull the axle out the drive side. With the cassette or freewheel in the way it's sometimes just too difficult on the drive side to tighten those locknuts properly.
It doesn't take much grease to hold all the loose ball bearings in place while you reinstall the axle after cleaning everything. Just be sure you don't have shaky hands and hit a bearing as you insert the axle. And of course the drive side cone and lock nut should already be tight before you do this.
Likes For Iride01:
Quoted: 5793 Post(s)
Liked 2,595 Times
Pardon any dupes (I didn't read every post)
Keyless bolted cup/cone hubs are especially prone to loosening.
Be sure to tighten lockouts to the max. And be sure BOTH sides are tight. If that doesn't end this, you might consider an adhesive for added reliability.
FB
Chain-L site
FB
Chain-L site
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
have you removed the axle completely, cleaned everything etc ?
What I suspect is that you have a loose nut under the cassette. Take the axle out and tighten the cone and nut on that side, then install and set the NDS cone for minimum play and no drag.
/markp
/markp
Quoted: 366 Post(s)
Liked 275 Times
My limited experience is that there is a bit of an art to these - the process of tightening the locknut against the bearing can create a wee bit of wobble.
thanks for the help everybody, not working until after lunch today so I went out after my morning coffee and had another go at it, I think my key error (pointed out by several people above) is that it was the DS side that was coming loose so that was what I tightened to remove wobble, but it would come loose again.
This time I tightened the DS locknut good and tight, then went over to the NDS side to make all my adjustments. I used bikegremlin's tip of using some spaces (washers taped together to make the same thickness as my dropouts) to test each adjustment, tho in the end I had to make some fine adjustments with the wheel on the bike (QR tightened) to remove wobble with the wheel spinning freely. Which I haven't seen in any videos but it seemed to work... Took me nearly 2 hours but I THINK I've got it dialed: wheel spinning freely but no wobble. (hope it lasts...).
Andrew - thanks for the tip re checking the dropouts are parallel, if they're not they've been out of alignment since I bought the bike, first thing that happened a couple of km from the shop on the day I bought it was the wheel slipped, I had no idea what was going on so just cycled back to the shop and he tightened the QR (with profuse apologies) but it's been an ongoing issue, I might well take it to the shop and ask him to check the alignment...
According to this I have an external clamp QR, I'll go shopping for an internal one
Finally, on an additional happy note, my test ride round the neighborhood took my odometer over the 10,000km mark (in 2.5 years = an average of 76km/week) - kind of happy about that! (during semester I'm riding about 120~150km a week, but less during the school vacations as I mostly work at home)
Quoted: 334 Post(s)
Liked 753 Times
One point that’s still unclear - are you tightening the locknut against the cone in each side, using a cone wrench and regular wrench simultaneously? If you’re just tightening the locknut without bracing the cone, that could explain both the hub coming loose and the wheel slipping in the dropout. Still a good idea to switch to an internal cam skewer though.
Likes For bboy314:
Reuse the bearing?! I was taught not to do it at two different shops. One is an LBS (summer job) and the other is my college bike shop (doing school and as basic as it comes). They're cheap and why allow potential problem(s) to fester?
(thinking about this I'm wondering if the inside nut might have moved, I think I considered zip-tie-ing the cone spanner to a spoke to hold the inside nut immobile (or call my wife....) but it seemed to be working with the pliers trick. In the end it seemed to be fine, and I did 30km yesterday and the wheel was fine, but....
...I did another 25 today and when I got home the wobble was back.....frustrating.....guess what I'm doing tomorrow....
kcjc - I had intended to replace the bearings, but when I got into it I realized I didn't know what size they were, do I just measure them and buy something that seems like it's the same size? How wide are tolerances?
EDIT: never mind, I just did a quick amazon search and ordered a set of lots of different sizes ...why didn't I think of this before???
Ordered an internal QR from bluelug yesterday evening and it arrived this evening, damn bluelug are efficient (I'm in japan),
Last edited by eggnoggbubble; 01-11-24 at 04:13 AM. Reason: thoughts occur slowly...
Quoted: 676 Post(s)
Liked 741 Times
Have you read Bike Gremlin's tutorial? Pay special attention to Part 7, section b, which talks about fine-tuning. Don't use pliers.
(in my defense: I think it was a GCN video that advised putting the axle in a vice to hold it immobile, I didn't have a vice at the time (but I do now - slowly equiping the tool shed....) but I do remember Bikegremlin accomplished it all without a vice....
BTW thanks for the help everyone, I'm a novice mechanic (if I am any mechanic at all.....) , when I got a new bike and committed to bicycle commuting a couple of years ago I also committed to learning how to work on my bikes, I'm finding it a bit of an uphill struggle at times, I appreciate your patience and detailed help!
Quoted: 334 Post(s)
Liked 753 Times
It sounds like you’re going about adjusting bearing preload correctly, but the hub continues to loosen after riding. At this point I’d remove the axle and bearings entirely, clean everything well, and inspect. It’s possible the cup on one side of the hub is cracked or collapsing, or some threads on the axle are damaged. It’d be a good time to look for any bad pitting on the bearing surfaces as well.
thanks, yeah, my method may have been a bit weird but I feel like I got it adjusted correctly and it was riding fine for a day, I'll try to take it apart again over the weekend (tho my bearing kit won't arrive yet, amazon is no bluelug....), I'll post pictures....
Quoted: 676 Post(s)
Liked 741 Times
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I post all that, not sure if your challenge is not getting the preload right initially, or if you are able to get preload correct but find that it loosens up after riding. I do hope it helps regardless.
Quoted: 676 Post(s)
Liked 741 Times
...is to set too much preload with the NDS cone...more than you can set by hand. In other words, tighten that cone maybe 1/8 or 1/4 turn past "perfect." The bearings will likely feel crunchy. Then tighten the NDS locknut as you usually do, which will pull the cone loose some. This will open the preload some and, hopefully, get it back to "perfect." This will likely require some trial and error on your part, to get it just right...
thanks for the extra comments everyone!
I watched the whole of bikegremlin's video (not just the preload bit) last night, and I realized that at 17:01 or so he tightens the DS side cone and locknut pretty tight with two spanners - this is a step I have been missing (I tightened it, but not nearly as tight) so that's my current working theory of what is going wrong, I'm hoping to have a look at it this afternoon.
bikegremlin - by the way it's a great vid - as a novice mechanic, just watching someone work in real time is very valuable, thanks, I subscribed!
andrewclaus and hokiefyd: yes, what you're describing sounds exactly like what was happening, and your method sounds completely rational - I'll give it a go!
I watched the whole of bikegremlin's video (not just the preload bit) last night, and I realized that at 17:01 or so he tightens the DS side cone and locknut pretty tight with two spanners - this is a step I have been missing (I tightened it, but not nearly as tight) so that's my current working theory of what is going wrong, I'm hoping to have a look at it this afternoon.....!
When you buy 100's of bearings at a time, they get pretty cheap.
2. You don't have to trust employees who may not have the best judgement of what's good/bad. Besides, if it's iffy, you're going to toss anyway.
